78 GS550 Carb Issue
motomurray
PostPosted: 04:28 - 10 Oct 2020    Post subject: 78 GS550 Carb Issue Reply with quote
Hey All - I was gifted an old 78 GS550 and started tearing it apart to start fresh. After removing carbs and opening them up, I found the tube pictured in attached broken off in carb #1. I've been searching all over the internet and can;t find this part in the diagrams, for sale, ANYWHERE... I was able to use pliers to pull out the remainder of the tube from the carb, just straight out no twist needed, so weird to me I can find this anywhere..
Needing some help, anyone know what I'm looking at here? Going to head to a moto junkyard this weekend to try and find a new (used) set I can open up and salvage parts from, unless buying something new is an option.
Any help would be great!
oilyrag
PostPosted: 13:41 - 10 Oct 2020    Post subject: Reply with quote
Are there any numbers or letters stamped on the side carb? That would tell you what model it is. You should be able to get parts based on that
Easy-X
PostPosted: 15:41 - 10 Oct 2020    Post subject: Reply with quote
Worst ways find a knock-off or second-hand carb and strip the pipe from that.
PostPosted: 17:08 - 10 Oct 2020    Post subject: Reply with quote
Pretty sure that's just the fuel pickup for the fuel enrichment (choke) circuit. If so you have a few choices:
Plug it and suffer the bike not running on that cylinder when you first start up from cold.
Find or make a similar tube, fix the new one in place of the old.
Make a thin brass sleeve and soft solder the two halves together using the sleeve as a joiner. Fix the tube back in with fuel-safe retainer.
oilyrag
PostPosted: 17:30 - 10 Oct 2020    Post subject: Reply with quote
There's a single carb
https://www.ebay.com/itm/SUZUKI-GS550-1978-CARB-CARBURETOR-MIKUNI-CARB-BODY-4-Four-Right-Outer-OEM/283869646004?hash=item4217f30cb4:g:UqYAAOSw~6BessuR
oilyrag
PostPosted: 17:47 - 10 Oct 2020    Post subject: Reply with quote
According to that link you've got a 77-79 GS550L and the carb is a Mikuni vm22ss.
https://www.thegsresources.com/_forum/showthread.php?73723-Carb-OEM-specs-as-per-factory-manuals
motomurray
PostPosted: 03:41 - 11 Oct 2020    Post subject: Reply with quote
Thanks everyone!! Talked to a shop today and, although they were uncertain, they said that piece was likely part of the carb and could only be 'replaced' through getting a new carb. I think otherwise, so gonna take a shot at repairing the copper tube. Also heading to a moto junkyard tomorrow in hopes of finding an old set of carbs to swap out, as a nice backup plan.
Either way, appreciate the research and recommendations. big help!
Robby
Dirty Old Man
PostPosted: 13:47 - 11 Oct 2020    Post subject: Reply with quote
CMSNL don't list it as a separate part, so it looks like you are going to have to get another carb to harvest the part, fix it, or ignore it.
If it is on the choke circuit then it's the least critical part in terms of precise fuel metering, so I would be tempted to try fixing it. See if you can very carefully remove one of the intact ones first to see what the whole thing is meant to look like.
motomurray
PostPosted: 16:49 - 12 Oct 2020    Post subject: Reply with quote
One more question for everyone while I (hopefully) have your attention. Moving slightly forward, wanting to see if you're on the same page with jetting.
This bike now lives with me in Denver so needing to account for altitude (5k+ ft). I'm running 4 air pods and a 4 to 2 exhaust on here. Stock main jet is 80, so the mods above bring it up 6 points (to 95), then altitude knows it back down 2 points, leaving me at a main jet of 87.5.
Does all that sounds right?
I currently only have main jets, so was going to give that a shot (+ vacuum syncing carbs) before trying to replace anything else. Let me know if you think otherwise!
Thanks again
Nobby the Bastard
Harley Gaydar
PostPosted: 17:35 - 12 Oct 2020    Post subject: Reply with quote
Thanks again
You'll need a dyno and a days pay for the guys who know what they are doing, and not a bike forum to try and get it fuelled correctly.
Triumph Sprint ST 1050
A100man
PostPosted: 10:13 - 13 Oct 2020    Post subject: Reply with quote
I agree with this 100% - carb is very similar to my (same era) XJ550.
The last post was made 6 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 68.71 Kb
