 Posted: 13:11 - 11 Oct 2020 Post subject: Question about vacuum/diaphragm fuel pumps |
Do they allow fuel to pass through by gravity as normal when there is no vacuum applied?
I've noticed I get fuel flow issues on my 612 bullet when the tank is below half full (the engine is much closer to the tank than on a standard one so there is less head of pressure). I was thinking one of those little diaphragm pumps might give it an extra "push". It's not having to lift the fuel at all, just help it along.
It's especially an issue at idle, the idle circuit gets fussy if the carb isn't totally full and it can cut out. I think there isn't quite enough pressure to poke that last few mm of fuel in. It's am Amal MK1 concentric which are fankly a disaster area but I don't have the time and mental space to set up a Mikuni TM32 from scratch which is the ultimate aim.
My concern is it would need to allow fuel to flow when the engine isn't running because the carb needs to be tickled for it to start. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Robby |
 Robby Dirty Old Man
| oilyrag |
 oilyrag Nova Slayer
| Tankie |
 Tankie Crazy Courier
| Easy-X |
 Easy-X Super Spammer
 Posted: 14:28 - 11 Oct 2020 Post subject: |
Might be worth looking at it the other way: are there any places that might offer a restriction? Petcock, fuel pipe diameter, tight pipe bends, air flow into the tank (i.e. very slight airlock) that sort of thing. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
 Posted: 15:10 - 11 Oct 2020 Post subject: |
The issue is it's an amal carb and they are -and always were- shite but all the enfield folks insist on using them. The height of the engine just makes the problem worse. You daren't mention this to any brit bike enthusiasts because they go off on one.
I think the main problem is inherant to the design, the float bowl fills from a spigot on the bottom meaning the fuel HAS to go down then back up into the carb. The needle valve closes by dropping down into its seat, not by being pushed up into the fuel flow like on a japanese carb. (the float see-saws, the needle is the opposite side of the pivot to the float). There is no spring on the needle, it's a solid piece with a viton tip.
It has an OMG fuel tap and a straight drop of red-line karting fuel hose to the carb. No inline filter, just the gauze in the tap and I removed the internal filter in the carb. The tank is POR15 lined anyway so no sources of rust and crap.
I had similar problems with an amal on my 350 bullet and as soon as I put the mikuni copy back on, they all went away. It's just setting one up for this bike with no point of reference will be a ball-ache. Fitting a mechanical fuel pump would be very simple. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Tankie |
| Easy-X |
 Posted: 17:15 - 11 Oct 2020 Post subject: |
Sounds to me like someone wants to say "fuck you, purists!" and put a proper carb on
I put a flat-slide on the DT. No kittens were killed in the process  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| dynax |
 dynax Trackday Trickster
 Posted: 17:34 - 11 Oct 2020 Post subject: |
| WD Forte |
 WD Forte World Chat Champion
| yen_powell |
The last post was made 6 years, 1 day ago. Instead of replying here, would creating a new thread be more useful? |
