Anyone any good at soldering...
sickpup
Old Timer
PostPosted: 10:46 - 16 Oct 2020    Post subject: Anyone any good at soldering... Reply with quote
circuit boards and up for some work, I'm happy to pay?
Got a few of these controllers for heated jackets and they either need new thermal fuses, top right in the picture or new on/off switches on the left.
Anyone got the skills to sort these out? I can supply the fuses and switches.
https://www.bikechatforums.com/files/20201016_114042.jpg
c_dug
PostPosted: 12:44 - 16 Oct 2020    Post subject: Reply with quote
How many is a few?
If it's literally just 3 or 4 of them I can ask one of my electronics guys to do it when they have a quiet few minutes.
I come through your sort of way on my commute or you could drop them to the museum if you're ever in South Ken.
sickpup
Old Timer
PostPosted: 12:50 - 16 Oct 2020    Post subject: Reply with quote
It would be 2,3 or 4. Got a few each with asingle fault, quite happy to buy your chap a few beers for the work or pay him some cash in an Oliver North style.
Won't be for a couple of weeks, about to start a 12 night shift.
Thanks for the offer, it's appreciated. I'll get back to you over it Thumbs Up
c_dug
PostPosted: 12:53 - 16 Oct 2020    Post subject: Reply with quote
Sure, fyi I'm in Hong Kong for work for the best part of three weeks from the 31st October.
I can probably still sort something out from there as I'll still be in contact with my team, but it would be much easier to arrange before or after then if possible.
sickpup
Old Timer
PostPosted: 13:31 - 16 Oct 2020    Post subject: Reply with quote
After would be fine, I have 12 day shifts all the way through to April so no rush.
Easy-X
PostPosted: 15:59 - 16 Oct 2020    Post subject: Reply with quote
I recently bought myself a Chinesium desoldering iron - hollow tip, solder suck built into the handle - and it works quite well. Any particular reason you don't want to do this yourself?
oilyrag
PostPosted: 17:01 - 16 Oct 2020    Post subject: Reply with quote
With a cheap iron and some lead solder you could easily replace those two parts yourself.
c_dug
PostPosted: 17:25 - 16 Oct 2020    Post subject: Reply with quote
I get the point about DIY being possible, but the alternative I've offered is a repair FOC by one of my very experienced electronics engineers (of which I have 4 working for me), part of our recruitment process is literally PCB component replacement. DIY would seem a silly choice in comparison? Laughing
TbirdX
PostPosted: 17:32 - 16 Oct 2020    Post subject: Reply with quote
Which museum c_dug?
VFR800X - CFMoto 450MT - TTR250
c_dug
PostPosted: 17:59 - 16 Oct 2020    Post subject: Reply with quote
Science
jeffyjeff
PostPosted: 22:48 - 16 Oct 2020    Post subject: Reply with quote
What this? As I recall, Oliver North became well-known for his skill at driving a shredder, lol.
History shows again and again how nature points out the folly of men. BOC
Getting old ain't for wimps. R.S. Hain
WD Forte
PostPosted: 00:30 - 17 Oct 2020    Post subject: Reply with quote
C-dug's guys would probably check and reflow those mosfets as well
some rough looking joints on those.
With all those through holes, I wonder what's on the other side of the PCB,
some PWM control or similar circuitry to drive the mosfets I'd guess.
bikers smell of wee
TbirdX
PostPosted: 08:39 - 17 Oct 2020    Post subject: Reply with quote
c_dug wrote:
Science
Just wondered, I've spent a fair bit of time working in the V&A myself.
ThatDippyTwat
PostPosted: 09:01 - 17 Oct 2020    Post subject: Reply with quote
Thermal fuses can be a royal pain to replace, depending on the temp they're set to blow at. Wave soldering (how they're manufactured) typically doesn't get them hot enough to blow, but your average bloke with an iron will usually kill them outright.
You usually solder in some sort of plug/socket and crimp them into that to effect DIY repairs.
The switches are a straight replacement and commonly available.
Easy-X
PostPosted: 11:13 - 17 Oct 2020    Post subject: Reply with quote
I'm a great believer in self-reliance but then again I'm a great believer in any old excuse for beer to make an appearance Very Happy
oilyrag
PostPosted: 12:23 - 17 Oct 2020    Post subject: Reply with quote
Good point. I didn't think about that
c_dug
PostPosted: 14:12 - 17 Oct 2020    Post subject: Reply with quote
TbirdX wrote:
c_dug wrote:
Science
Ah cool, I know a few of their technicians. What do you do?
colinM
PostPosted: 16:25 - 17 Oct 2020    Post subject: Reply with quote
I see a few people have already replied to this but I do electronics repair as a hobby I have a full setup for doing soldering work (professional irons,hot air stations, microscopes etc)
this looks like a pretty simple job.
I'm in Scotland
ThatDippyTwat
PostPosted: 17:11 - 17 Oct 2020    Post subject: Reply with quote
I'm in Scotland
Thermal Fuses. Probably not straightforward.
Sickpup - What temp is specified on the fuse?
sickpup
Old Timer
PostPosted: 18:34 - 17 Oct 2020    Post subject: Reply with quote
I don't have the soldering skills a the moment or the time to learn due to the excessive hours I'm working.
The controllers can't easily be replaced, they haven't made them for over 10 years so I can't really risk learning on the job with them and to replace with alternatives would cost about £60 each and not work so well.
Oli North was the king of the clandestine back hander.
Islander
PostPosted: 19:37 - 17 Oct 2020    Post subject: Reply with quote
Simple enough, you use a clip on heat shunt on the lead next to the component - a bit like miniature self closing tweezers. You also work quickly. The first precaution is belt and braces, working quickly means that the fuse won't get that hot anyway. Thumbs Up
TbirdX
PostPosted: 19:49 - 17 Oct 2020    Post subject: Reply with quote
Contractor, look after the biometric access control and other security stuff.[/quote]
colinM
PostPosted: 00:39 - 18 Oct 2020    Post subject: Reply with quote
👍 You can also pre-heat the board to make the process quicker, thermal shunt/heatsink like you suggest. They also usually have a few seconds at soldering temp for installation which will be documented in the datasheet.
sickpup
Old Timer
PostPosted: 14:07 - 18 Oct 2020    Post subject: Reply with quote
196
kramdra This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
The last post was made 6 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 130.22 Kb
