| TheGazWaz |
 TheGazWaz Nitrous Nuisance
| Nobby the Bastard |
| TheGazWaz |
| oilyrag |
 oilyrag Nova Slayer
| Nobby the Bastard |
| TheGazWaz |
| oilyrag |
 oilyrag Nova Slayer
| TheGazWaz |
| oilyrag |
 oilyrag Nova Slayer
 Posted: 18:38 - 12 Oct 2020 Post subject: |
There's some pictures of your carb. https://www.ebay.co.uk/itm/Carb-Carburettor-For-Lexmoto-Assault-125-HJ125-J/283332507698?hash=item41f7eef832:g:hckAAOSwMKxcNTJT
The choke is off in the pictures. You can compare the position of your lever to the one in the picture and determine if it's on or off. The idle speed adjuster screw is the brass one that's sticking out on the side of the carb. Only adjust that one. Don't adjust the mixture screw. If you lean out the mixture screw you can damage the engine.
You have to let the bike warm up and turn the choke fully off before you adjust the idle speed. If it won't idle with the choke off give it a small bit of throttle to keep it running and adjust the idle speed screw until the idle speed screw takes over. It should idle at around 1350RPM
If you can't get it to idle with the idle speed screw bring it back to the place you bought it and let them sort it out. If you just bought it they will have to fix it for free. If you take it apart and start messing with it they could say you caused the problem and you would have to pay for the fix. |
| Nobby the Bastard |
| Nobby the Bastard |
| TheGazWaz |
| TheGazWaz |
| Robby |
 Robby Dirty Old Man
 Posted: 15:16 - 25 Oct 2020 Post subject: |
Fuel flow is easy enough to check. Pop the pipe off the carb, direct it into a milk bottle, and turn the fuel on. The fuel requirements of the bike are miniscule, so as long as you have a solid stream of fuel (rather than a weak dribble) then you have enough fuel.
By the sound of it the initial problem was a lot of corrosion on various connectors creating too much resistance (and then heat) in a few circuits. I would be going back over these areas in a bit more detail. If the connector was seriously corroded, chances are the wire leading to it is also burnt or corroded under the insulation. If I find blackened copper wire, I just replace that length of wire. There may also be more frame earth connectors that you haven't found yet, which will be similarly corroded.
Doing the valve clearances is a good idea. I think Haynes do a generic manual for Chinese 125s. Assuming your one uses one of the generic engines, the valve clearance settings will be in there. Otherwise just google it, but you may want to check a few places to find the most common setting - lots of poor information out there for Chinese bikes.
For the price of it, new coil/lead/plug is probably worth doing. I would just do the various bits in stages to find out what the problem is, rather than just knowing it is fixed.
(Dad-mode) If this is your son's first bike, there is also something to be said for giving him a bike that will comfortable do town speeds all day long but not allow sustained higher speeds until he has a couple of months experience, or until the worst of winter has passed. Depends on the roads where you live, and whether being able to maintain 60mph is desirable or not. |
| jaffa90 |
 jaffa90 World Chat Champion
| TheGazWaz |
| Evil Hans |
 Evil Hans World Chat Champion
| TheGazWaz |
| dynax |
 dynax Trackday Trickster
 Posted: 14:52 - 28 Oct 2020 Post subject: |
| Tdibs |
 Tdibs Traffic Copper
| TheGazWaz |
 Posted: 18:30 - 29 Oct 2020 Post subject: |
Gotta get one of them. Just the jobbie ____________________ Went like this.. 43 years old(2013) decided to do CBT to get a 125 for new job. Bought 2011 YBR, loved it for three months then hated it because it was too god damn slow. Did DAS 4 months later then bought RF600 Loved it, sold it bought Bandit 1200(K3). EFFIN lOVED IT. Wanted something a bit more sporty so got Triumph Sprint ST 955i (53). Not sporty enough so now on my GSXR 1000 K3 and absolutely love it. 1 year down the line, nearly died way too many times on this bike. Sold it. Had a 6 month break. Missed biking so now, Aug 2019 have a 1999 ZX9r. What a beauty she is too. |
| TheGazWaz |
The last post was made 5 years, 303 days ago. Instead of replying here, would creating a new thread be more useful? |
