| Micmac |
 Micmac L Plate Warrior
| doggone |
 doggone World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 08:04 - 21 Oct 2020 Post subject: |
Did your three mechanice check the battery with a battery tester? Did they check the charging vltage?
My suspition is one or both essential checks were missed! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| stevo123 |
 stevo123 Nitrous Nuisance
| davebike |
| stevo123 |
| doggone |
| steve the grease |
 Posted: 19:09 - 21 Oct 2020 Post subject: |
When I started mechanicing I rapidly came across what I have called 'The starting circle'.
Vehicle won't start, so is it
A forked battery?
A forked charging system?
A forked starter?
And how to prove what is defective.
If it will start on a jumpstarter then its not the starter , so now we are down to 2
Ok the battery is flat , is it flat cos it's fucked and its lost its charge or is it flat because it's not charging up.?
Charge the battery up off the vehicle, then try and start the bike. Probably it starts. leave the battery overnight and try again, if it struggles or is dead then for sure it is the battery that that is at fault, a good battery will hold it's charge for months. A cheapish battery will last maybe 3 winters in use, by the forth it's tired. Especially at this time of year an older battery is suspect.- cold weather slows down chemical reactions.
Another test , with the suspect battery in place use the jumper to start the bike, check the voltage - * if the battery is no good, it will rapidly come up to about 14 volts, this proves 2 things - that the charging system is working ok, and that the battery is knackered as it appears to reach full charge so rapidly. If however the charging voltage never gets over 12 ish volts then its the charging system, that is the problem.
An analogy :
Imagine a battery is a water tank, like in your loft. A good battery is like a tank full of water, lots of useful capacity. A knackered battery is like a water tank full of mud except the top 2 inches, which has water laying over the mud . When you turn on the tap , the tank very rapidly runs out of water... when you try and refill it , it reaches the full level very rapidly , or at least appears to, because it no longer has any useful capacity. " Hey this must be a good battery , because it charged up so rapidly" Sadly no.
* https://www.ebay.co.uk/itm/Digital-Battery-Alternator-Tester-12v-LED-For-Car-Van-Motorbike-Vehicle-Small/392314387879?epid=28037885052&hash=item5b57c27da7:g:SPUAAOSwUrNdoQZ8 Dead Handy ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
The last post was made 5 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
