Fitting internal wheel sensors/TPMS
kramdra
PostPosted: 10:45 - 23 Oct 2020    Post subject: Fitting internal wheel sensors/TPMS Reply with quote
I have test fit the TPMS sensors and fitting the valve is no problem, but I notice the sensor is a couple milimeters above the rim, unsupported, which may stress the valve.
I'd like to know if thats normal for the BMW type. Ive watched a couple of YT videos and the bmw seem the same, smooth rims, sitting above, but cant be sure.
I can make up a plastic spacer to glue onto the sensor if its needed.
PostPosted: 14:03 - 23 Oct 2020    Post subject: Reply with quote
It looks like it just sits on the rubber/plastic sealing grommet Confused Does it not go tight when you do the outer nut up? If it does I wouln't make it more rigid just incase you set up more stresses.
For what it's worth, Triumph have a spring in theirs to do the same thing so theirs won't be totally rigid either.
https://img.joomcdn.net/349dcfc43e4be325eeca44214f238b7f9b4664e2_original.jpeg
Triumph
https://uploads.tapatalk-cdn.com/20160305/d8f9b9e4f7002729dd274bc4abca65e8.jpg
Nobby the Bastard
Harley Gaydar
PostPosted: 18:20 - 23 Oct 2020    Post subject: Reply with quote
No doubt it will end up welded to the wheel rim because some people are just completely lacking in sense.
Triumph Sprint ST 1050
PostPosted: 19:56 - 23 Oct 2020    Post subject: Reply with quote
PostPosted: 23:23 - 23 Oct 2020    Post subject: Reply with quote
Come on then, enlighten us as to what you mean.
Skudd
PostPosted: 02:47 - 24 Oct 2020    Post subject: Reply with quote
On my GSA they just fit snugly, tighten up the tube type locking nut.
If it was the battery that went duff, then it is easy and far cheaper to replace the battery and use the old sensor. the UKGS forum has loads about it and there are easy to follow videos.
sickpup
Old Timer
PostPosted: 10:15 - 06 Nov 2020    Post subject: Reply with quote
So obvious stupid question, you are fitting these to BMW wheels that are designed for this type of TPMS sensor aren't you or is this another one of your bodges?
The last post was made 6 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 51.72 Kb
