What have you done to your bike today? Archive.
This topic is locked: you cannot edit posts or make replies.
Bike Chat Forums Index -> General Bike Chat Goto page Previous  1, 2, 3 ... 392, 393, 394 ... 407, 408, 409  Next
Easy-X
PostPosted: 00:04 - 04 Nov 2020    Post subject: Reply with quote
wr6133 wrote:
Finally put a new neutral lamp bulb in the Continental GT, almost 12 quid for a bulb the size of a bloody rice grain Shocked . Don't know why I actually bothered I'd got used to not having one.
BA9s? A generic LED replacement would be fine for neutral (indicators not so much.)
wr6133
PostPosted: 06:53 - 04 Nov 2020    Post subject: Reply with quote
Unfortunately some weird little thing built in to a plastic base. never seen one before and despite searching could only find being sold by Hitchcocks (RE Nirvana) or MotoGB (RE Importer). Couldn't even bodge something else as the base doesn't go in to a "holder" but wedges directly in to the PCB where, when turned it locks and 2 little metal poles (built in to the base) line up to the PCB.
Easy-X
PostPosted: 10:59 - 04 Nov 2020    Post subject: Reply with quote
Have you got the link to the part or a photo? Curious to see this fancy base/holder.
wr6133
PostPosted: 11:08 - 04 Nov 2020    Post subject: Reply with quote
This is where you link me 10 for a quid Laughing
At first when I removed the dead one I thought the bulb and the plastic bit were separates but after yanking the dead bulb out of the base it became apparent one is not meant to do that.
https://accessories.hitchcocksmotorcycles.com/31329?qty=5&continue_url=https%3A%2F%2Fwww.hitchcocksmotorcycles.com%2Fpartsbook-pages%2F4191
https://live.staticflickr.com/65535/50565992841_7ffb0653dd_h.jpg
It slots in to that hole on the bottom left of the image, you then turn it 90 degrees with a screwdriver and the metal legs make contact
https://live.staticflickr.com/65535/50565244668_fafc71c6ab_h.jpg
Tankie
PostPosted: 13:23 - 04 Nov 2020    Post subject: Reply with quote
This is a common bulb normally found in instrument clusters on cars and lorries, if you need any just go into a motor factor
Easy-X
PostPosted: 13:35 - 04 Nov 2020    Post subject: Reply with quote
Yeah, I think Tankie is onto something Thumbs Up I'm looking at dashboard bulbs and the buzzwords seem to be T3, T4, T4.7, T5, etc. (T for twist I assume) bet it'll be one of those Smile
Shaft
PostPosted: 16:26 - 04 Nov 2020    Post subject: Reply with quote
Yup, one of the R509 family, fiver tops.
wr6133
PostPosted: 16:27 - 04 Nov 2020    Post subject: Reply with quote
Quick look on fleabay suggests similar but they seem to lack the upper metal tangs that mine has. Next time it goes pop I'll look more seriously.
wr6133
PostPosted: 16:29 - 04 Nov 2020    Post subject: Reply with quote
You Sir win the microwave, would you like to play for the fridge-freezer? Very Happy
Written down in the workshop book (which fails to name the bulb type, neither does Haynes). Thanks you've saved me a few quid next time.
Pigeon
PostPosted: 21:45 - 04 Nov 2020    Post subject: Reply with quote
XR250 has a 320mm front disc (on road rims), so has an aftermarket bracket / extender.
Removing bolts that hold caliper/bracket to fork so could remove caliper and pump out piston / clean etc
A bunch of copper looking threads came out with the bolt.
Then found torquing up front caliper and it just spun.
Looks like remains of a previous thread insert.
https://i.imgur.com/yaQBQwY.jpg
Drilled, tapped + Hellicoil
https://i.imgur.com/PZzFdjh.jpg
https://i.imgur.com/kfeP1q0.jpg
https://i.imgur.com/xWHK7kP.jpg
Done about 20 miles on it, so far so good.
Shaft
PostPosted: 23:57 - 04 Nov 2020    Post subject: Reply with quote
I'm actually a bit disappointed in myself, back when I was running spares shops, I could've given you the entire generic part number for your particular fitting off the top of my head, but with age comes senility, or as I prefer to call it, a reduced nerd quotient.
Just put '509 bulb' into the search engine of your choice and a suitable picture will appear.
wr6133
PostPosted: 19:17 - 05 Nov 2020    Post subject: Reply with quote
Fitted a headlamp peak, underside edge is surprisingly sharp.
https://live.staticflickr.com/65535/50570571471_06920f900b_h.jpg
PostPosted: 21:36 - 05 Nov 2020    Post subject: Reply with quote
Are those peaks actually meant to do anything useful or is it just a pedestrian disemboweler?
Triumph Trophy Launch Edition
wr6133
PostPosted: 21:44 - 05 Nov 2020    Post subject: Reply with quote
Errr that is useful? Very Happy
I've actually named this bike so she needs to look pretty Laughing
blurredman
PostPosted: 10:42 - 06 Nov 2020    Post subject: Reply with quote
Uach. You're one of those..
Current: 1973 MZ ES250/2 - 18k, 1979 Suzuki TS185ER - 10k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 40k, 1989 MZ ETZ251 - 50k.
wr6133
PostPosted: 11:21 - 06 Nov 2020    Post subject: Reply with quote
Only this one, never named a bike before Laughing
pepperami
PostPosted: 12:46 - 06 Nov 2020    Post subject: Reply with quote
Took the Honley RX3 out of the garage.
After 8 months of sitting there , it started first time Thumbs Up Smile .
Ran it for 20 minutes , rode around the driveway for 5 minutes.
Blew the dust off it ready to go back into the garage until I get time to use it after Christmas.
Pleased Smile
hellkat
PostPosted: 13:55 - 07 Nov 2020    Post subject: Reply with quote
Bashed it with a hammer, but the cheap handlebar brake lock is well and truly jammed on.
Have requested attendance by the sinister fiend with an anglegrinder or crowbar or some other arcane piece of male wizardry to get the damn thing off.
Skudd
PostPosted: 14:38 - 07 Nov 2020    Post subject: Reply with quote
Well yesterday I took the BMW Adventure in to have the ABS sorted, now on the little Cagiva Canyon and learning how to use indicators again.
NJD
PostPosted: 15:32 - 07 Nov 2020    Post subject: Reply with quote
Pictures?
Worth noting you may end up having to replace brake lever unless you can remove it to slide the half of the lock that will be stuck onto it down towards the thinner end, not forgetting the bit that will still be stuck on the handlebar.
hellkat
PostPosted: 16:00 - 07 Nov 2020    Post subject: Reply with quote
NJD wrote:
Pictures?
Well the jammed gubbins is going on inside the lock, so pix are pointless at this juncture. It just looks like normal but inside the barrel, all the little bits of lock metal are all chewed up, rolling around in there.
https://photos.google.com/u/1/direct/AF1QipNxAO8bkB0TrF4L2JI76z0zIgTNglwndrnlK4ssMMkUF0l16rdgPkTZ73OLvqskRw/photo/AF1QipMzDbCXKJ-27zm-sBt5UYAqAu2ZBrR0EjxhMj5G
ThatDippyTwat
PostPosted: 16:05 - 07 Nov 2020    Post subject: Reply with quote
Swapped the (4th gen) Viffers forks out for 3rd gen spares so I can do the seals on the Gen 4 ones. Remarkably trouble free.
https://i.imgur.com/Tek87qEl.jpg
The dust seals are properly toast, but the oil seals seem to be doing their job... might as well do both while I'm at it.
https://i.imgur.com/JfE9QzLl.jpg
Swapped back to the boring can as I need to leave at 05:30 for a while, and while my neighbours don't currently care about the can, they would at that time. Also cleaned her, she was filthier than a pricey hooker.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:14 - 07 Nov 2020    Post subject: Reply with quote
hellkat wrote:
NJD wrote:
Pictures?
It's your usual picture fail but just get the lock drilled out. get whoever is doing it to use several drilll sizes starting with the smallest to make it easier.
Triumph Sprint ST 1050
hellkat
PostPosted: 22:50 - 07 Nov 2020    Post subject: Reply with quote
Well he came and Dremelled it off.
Very skilful job.
Didn't even cut through the handlebar thingies.
Handy chap, that one.
Shifty
... has his uses.
hellkat
PostPosted: 22:52 - 07 Nov 2020    Post subject: Reply with quote
Nobby the Bastard wrote:
I don't know how to fix what I am doing wrong Crying or Very sad
I try to understand it, but the instructions just won't stick Crying or Very sad
The last post was made 4 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   This topic is locked: you cannot edit posts or make replies.    Bike Chat Forums Index -> General Bike Chat All times are GMT
Page 393 of 409
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 9.95 - MySQL Queries: 13 - Page Size: 136.56 Kb
