Yamaha SR 125 starts but won't take throttle
Byker 1127
PostPosted: 16:21 - 04 Nov 2020    Post subject: Yamaha SR 125 starts but won't take throttle Reply with quote
Hi all in need of a little help, i have a 1998 Yamaha SR 125 that will start and idle although roughly but it won't rev. The cylinder head has been rebuilt valves lapped in, new valve springs, stem seals the works. Head fitted back on the motor with new gaskets, valve timing is spot on. compression tested (105psi) Has had a replacement carb fitted (chinese ?) this has been stripped and cleaned (although new you never know) and an original carb has been fitted as well just in case the new item is somehow faulty. Brand new battery also fitted, has a good spark (New plug D8EA) pulse coils checked (238-240 ohms). I am at a loss to find the problem, any help would be appreciated.
This aint no dress rehearsal
Suntan Sid
PostPosted: 17:19 - 04 Nov 2020    Post subject: Reply with quote
Wrong carb or incorrect carb settings would be my first guess!
I've had mixed results with "new" chinese carbs, the same with carb repair kits. Try using the old needle in the new carb and see what happens, try the needle in the different positions.
Having said that, we all know that most fuel problems are actually electrical problems and vice versa.
Good luck!
jaffa90
PostPosted: 17:29 - 04 Nov 2020    Post subject: Reply with quote
If you have a good spark and give it more revs (air) then it needs more fuel. What about the choke operation or part blocking the air intake to give it more fuel?
steve the grease
PostPosted: 17:34 - 04 Nov 2020    Post subject: Reply with quote
My mate spent ages looking for a similar fault. The clip holding the need le had failed and the needle wasn't coming up with the slide in the carb. Result - weak , wouldn't take throttle.
Byker 1127
PostPosted: 11:56 - 05 Nov 2020    Post subject: Reply with quote
Thanks for the reply guys, Suntan Sid, Steve and Jaffa i know Chinese carbs can be a problem that's why i sourced an oe carb but had the same results, both carbs were cleaned and checked needle set at factory spec mixture also, i was thinking more on the electrical side so pulse coils checked ht coil also both read ok new spark plug etc. I've played with mixture settings starting off with the factory recommended 11/2 turns out and going in and out but still no joy. Choke appears to be working correctly as it needs it for initial start up and then i can clear it after a few seconds as it starts to run worse if i leave it on. Real head scratcher for me this one !!
jaffa90
PostPosted: 12:52 - 05 Nov 2020    Post subject: Reply with quote
Are you sure about the 105 psi, it should be 150 +.
https://www.manualslib.com/manual/882832/Yamaha-Sr125-1997.html?page=56#manual
Suntan Sid
PostPosted: 22:53 - 05 Nov 2020    Post subject: Reply with quote
Are you absolutely sure the valve timing is correct and is not 180 degrees out?
Byker 1127
PostPosted: 09:26 - 06 Nov 2020    Post subject: Reply with quote
Hi guys all sorted, it was a blocked exhaust pipe !! although there was smoke coming out when it was running ?? once i got the exhaust off and compared it to another exhaust borrowed from a mate the weight difference was quite noticeable, banged it on and hey presto idles and revs out no problem.
Thanks everyone for your input Thumbs Up
The last post was made 6 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 55.45 Kb
