Honda 95 xl250r starting problem
tristo
PostPosted: 22:32 - 06 Nov 2020    Post subject: Honda 95 xl250r starting problem Reply with quote
Hi all. I’ve pulled out a xl250r from god knows where, I’ve cleaned out the carby and put it back in. I’ve come into a problem where it’s wanting to push fuel into the air filter. First time working with a carby. Anyone able to lead me in the right direction?
94' Ducati 600SS
95' Honda XLR250R
18' Honda CBR650F
steve the grease
PostPosted: 23:09 - 06 Nov 2020    Post subject: Re: Honda 95 xl250r starting problem Reply with quote
Possibly the inlet valve isnt seating properly if the bike is a 'barn find', is there much in the way of compression? With something that has stood for ages a good old spray of wd 40 down the inlet and exhaust ports will help the valves seal as the valve seats tend to go rusty and not seal if they have been open for ages. Valve could also be rusted open a little bit. Generally clears after extensive kicking.
All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of.....
jeffyjeff
PostPosted: 06:28 - 07 Nov 2020    Post subject: Reply with quote
Looks like the fuel is leaking through the idle air port. Remove and disassemble the carburetor. Check the float height and make sure the float needle is not stuck open. The location of your leak suggests that the float needle is stuck, overfilling the float bowl and leaking through the idle air port.
Be careful to shut off fuel to the carburetor until the problem is fixed, else fuel could pass into the cylinder, resulting in hydrostatic lock.
History shows again and again how nature points out the folly of men - BOC
yen_powell
PostPosted: 09:32 - 07 Nov 2020    Post subject: Reply with quote
Is it a metal or plastic fuel tank. My XL250R used to feed rust particles through to the carb and make it overflow until I put a new fuel tap plus and inline fuel filter in after cleaning the carb for the umpteenth time.
XT1200Z and a DR350 in bits
Robby
Dirty Old Man
PostPosted: 17:15 - 07 Nov 2020    Post subject: Reply with quote
Stuck float or knackered needle valve.
The last post was made 6 years, 6 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 43.16 Kb
