how would you describe the character of a single?
trevor saxe-coburg-gotha
PostPosted: 17:41 - 12 Nov 2020    Post subject: how would you describe the character of a single? Reply with quote
How'd you describe the character of a single cylinder bike lump? I suppose to a large extent it depends on the displacement - a 125 won't have those traits that e.g. 650 will. Anyway - in general, how would you explain it?
arry
PostPosted: 17:52 - 12 Nov 2020    Post subject: Reply with quote
'Thrummy' on the testes.
PostPosted: 17:54 - 12 Nov 2020    Post subject: Reply with quote
Varies immensely depending on bore, stroke and state of tune.
Peak torque low down in the rev range? Relatively flat torque curve (although to be fair, that doesn't always follow either).
Which would make them "Lazy"?
A single could cover anything from a slope-engine panther 650 which would pull itself and sidecar out of set concrete at tickover to a CR250 that'll pull a wheelie and flip over backwards at a touch of throttle.
Vibration? Most of them are pretty vibey.
Low revving? Again , not necessarily.
Most of them are narrow compared to multi-cylinder bikes Smile
Usually they have big flywheels to keep them going, so they are usually grunty, thumpy slow revving, but have good low end punch.
PostPosted: 17:58 - 12 Nov 2020    Post subject: Reply with quote
You'd probably want to make a distinction between long and short stroke motors (under and over-square?)
wr6133
PostPosted: 18:05 - 12 Nov 2020    Post subject: Reply with quote
Torquey low down making them quicker than expected off the mark, bit gutless as you get faster. I'm generalising though my pre-unit 350 feels very different to my unit 535 though I'd struggle to quantify exactly how they feel different in words (other than the obvious power/speed).
Robby
Dirty Old Man
PostPosted: 18:37 - 12 Nov 2020    Post subject: Reply with quote
Thuddy, but you end up changing gear a lot.
PostPosted: 18:38 - 12 Nov 2020    Post subject: Reply with quote
And yet the blue line is the power curve for a standard 500cc Enfield bullet. The green one is for a road tuned 612cc conversion to the same engine. (red is a race tuned motor).
So the tuned motor is actually torquey high up. No point lumping about on it unless you like the noise it makes.
Easy-X
PostPosted: 19:32 - 12 Nov 2020    Post subject: Reply with quote
There's also only one carb (no balancing, easier tuning) less valves to check if 4-stroke, back-to-basics biking! You don't go into tinkering with an in-line 4 with quite the same gusto as a simple single Smile
Riejufixing
PostPosted: 20:19 - 12 Nov 2020    Post subject: Reply with quote
Why's it so poor?
arry
PostPosted: 21:06 - 12 Nov 2020    Post subject: Reply with quote
Riejufixing wrote:
Why's it so poor?
Because stuck in 60s.
PostPosted: 21:41 - 12 Nov 2020    Post subject: Reply with quote
I'm trying to think how many singles I've actually ridden - I think it's only three, or five if I include 125s (which I don't). The three are an old i.e. original MT03, then my CRM250, then my KLX250. The MT03 was a strange bike - I felt like I had to nurse the clutch a fair bit under 20mph. Then, once able to apply some proper throttle, there was the satisfying feeling of getting 'power for free' - i.e. increasing speed while revs and engine note don't seem to change much. But it seemed to sign off a bit abruptly. Meanwhile the KLX is just flat and shit everywhere (not actually a bad thing for what I use it for - but outside of green lane type riding, you wouldn't ever really feel particularly inspired by it. to say the least). The CRM had several different sides to it - a decent "tractor factor", happy to plod and pull through mud in second; a viable road brain that seemed to work in and out of town; thirdly, a slightly bonkers frantic 2t side to it that was always a pleasant surprise.
None of the three bikes is really very much alike apart from for that single cylinder.
PostPosted: 22:19 - 12 Nov 2020    Post subject: Reply with quote
arry wrote:
Riejufixing wrote:
Why's it so poor?
It was a pretty dated design even in the 60's.
The first 350 bullet came out in 1949. The first 500 bullet was 1953.
pepperami
PostPosted: 22:32 - 12 Nov 2020    Post subject: Reply with quote
My Bultaco 250 Pursang was just nuts! Shocked Wub and as strong as an Ox Smile , from low down revs, all the way to insane top whack Smile .
A friend lent me a DR 350 for 11 months and that was a proper thumper and a fugger to start!
It was cracking for the back lanes around here.
My little DR 125 was a buzzy little thing.
Ditto my little CG 125 of lovelyness.
One carb, no electronical nonsense and all were easy to work on Thumbs Up
Keithy
PostPosted: 22:43 - 12 Nov 2020    Post subject: Reply with quote
“Fires every lamppost”
My Dad, many, many years ago.
Robby
Dirty Old Man
PostPosted: 23:14 - 12 Nov 2020    Post subject: Reply with quote
This thread is exposing the key problem I have had with singles for years.
Do I like them? Yes. Tends to always have one in the garage, keep getting tempted by other ones more than any other engine type.
Can I put it into words? Not really. And if I really try, I just make them sound shit.
Tdibs
PostPosted: 23:56 - 12 Nov 2020    Post subject: Reply with quote
My Dr650 is some kind of farm machinery. Loud, clattery, and a bunch of fun.
RhynoCZ
PostPosted: 00:00 - 13 Nov 2020    Post subject: Reply with quote
The XBR that I ride, has a 498.00 ccm, short stroke, 4 valve head, single spark plug 33kW/43Nm engine with single 40mm CV carburetor with acceleration pump (the carb is huge!). It does Ton-up worthy 100 mph quite effortlessly, tops out at 106.3mph with the standard gearing. The 4th gear is 1:1 ratio. So, I guess having a shorter final drive gear ratio would push it even further (the CB-1 had definitely higher top speed with shorter final drive gear ratio). Not that I would need higher top speed.
Now, compared to an in-line four and twin cylinder four stroke engines (I've never riden a triple cylinder), every throttle input on the ''big single'' is rather dramatic and aggressive with very strong engine braking. I don't really use the brakes that much, when cruising around. The rear wheel will lock up if you are careless, though. You just don't spin the engine up to gain the torque. It's always there, very low down, mind you these engines don't rev that high up.
I also enjoy the sound the engine makes. Acceleration, high revs, closing the throttle at high speed, or just listening to it at idle... love it, especially when I kick start it. Not as lovely as a long stroke engine would sound, but still nice and it is more user friendly. When you are in let's say 4th gear doing 30mph and open the throttle, the engine doesn't care and with a V8 like rumble acclerates the bike forwards, with no hesitation what so ever. By the way, car alarms love the engine rumble. The engine is great in city traffic, crap on the highway (vibrations). My ZX7R was the other way around, horrible in city, amazing at high speed (legal) riding.
Also, listen to this: https://youtu.be/rhQUWTk7kDU?t=18 Razz
TL; DR: Big singles are all the drama without the triple digits speed. I enjoy mine very much. The fuel economy of the XBR is also very nice, compared to my previous bike (ZX7R). I wouldn't travel far on the XBR though, after awhile the vibrations get tiring. But, my bike might be missing some bits. I still find missing stuff all the time. It's 1987 bike after who knows how many owners, so it's not ideal, but I'm working on it.
TL; DR II: Just get one (again), if you won't like it, sell it and buy something else. Although, if I had to commute or cover long distances in one sitting, I'd buy a four cylinder instead, the ''big single'' is a great short blast around bike.
#singlesaregreatinsmalldoses Thumbs Up
EDIT: I bet modern single cylinders are way smoother and higher revving than the 30+ years old ones. Thinking
Shaft
PostPosted: 01:25 - 13 Nov 2020    Post subject: Reply with quote
I bought my XL600 thinking it would make a great allrounder, maybe even good for a bit of touring, on the basis you could probably load it up the eyeballs and it wouldn't notice the weight.
It turned out to be not as torquey as I was expecting, so you had to rev it to get anywhere, which was fine because it revved up pretty sharpish, except it's comfortable operating range was quite small - below a certain point it didn't do much, then you got to where it was producing, but quite quickly it all turned into a boat load of vibration.
I would like to say it was a peculiarity of that bike, but most of the 4T singles I've ridden have been the same - great at point and squirt (that XL was one of the best bikes I've ever owned for carving through traffic, which is saying something for an ex London courier) a bit asthmatic at average cruising speeds and no bloody good at all for maxing out.
If I had unlimited funds and space, I would probably buy one again, but it had such limited abilities, I don't consider it a very practical real world choice.
blurredman
PostPosted: 09:07 - 13 Nov 2020    Post subject: Reply with quote
Damn annoying if you have sparking/misfire issues.. Laughing Laughing Laughing
Riejufixing
PostPosted: 11:11 - 13 Nov 2020    Post subject: Reply with quote
stinkwheel wrote:
arry wrote:
Riejufixing Why's it so poor?
It was a pretty dated design even in the 60's ... first 500 bullet was 1953.
I was comparing it with a '50s AJS 500, which was ~28hp @ 5600 rpm.
arry
PostPosted: 11:31 - 13 Nov 2020    Post subject: Reply with quote
The Bullet 500 is about the same.
I'd guess the graph is showing rear wheel horses rather than engine which is what the AJS number will represent.
Riejufixing
PostPosted: 12:48 - 13 Nov 2020    Post subject: Reply with quote
arry wrote:
The Bullet 500 is about the same. I'd guess the graph is showing rear wheel horses rather than engine which is what the AJS number will represent.
The AJS would have to have an appalling drive system if that's the case. Normal drive train losses seem to be IRO 10% (this is gear dependent), and 28 hp to 20 hp is coming up to a 30% loss. I don't believe it, so I reckon that the Bullet was simply less powerful.
PostPosted: 12:55 - 13 Nov 2020    Post subject: Reply with quote
Indian bullets are lower bhp than the British ones were. Lower compression engines and non-interference heads to cope with shite fuel and general fuckwittery when it comes to maintainance and use by squaddies in the Indian Army.
One of the most entertaining singles out there was the SZR660. A a 5-valve 660cc, twinport, liquid-cooled single with a dry sump 50-ish bhp all in a razor-sharp TZR250 rolling chassis. They kept the motor smooth buy using a clever twin-carb setup, a slide carb does all the slow running up to about 1/4 throttle openign then above that a huge CV carb with no idle circuit is picked up and gives it full-bore-roar.
All makes for a bike which is smooth off the throttle under all circumstances and goes round corners like it's on rails. Only does about 110mph flat-out but I've seen one of my mates -who is a highly competant motorcycle racer- handed his arse in a sling by one over about 100 miles of Scottish twisties, said mate was on a ZX9R.
The main problem with them is they did them in "disco" colours. Didn't sell well, which is a shame because they are a whole load of fun.
wr6133
PostPosted: 13:01 - 13 Nov 2020    Post subject: Reply with quote
Stinkwheel probably knows the figures better but I believe a stock pre-unit Indian Bullet claimed around 22BHP at crank. The 2008 onward unit engine claims 28BHP and the 535 version claims 29BHP.
They don't feel low powered until you are on a motorway and try rolling on at 70.
The last post was made 5 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 134.42 Kb
