Glasses and Full Face Helmets.
smokin joe
PostPosted: 22:00 - 13 Nov 2020    Post subject: Glasses and Full Face Helmets. Reply with quote
I've just upgraded from an open face lid to a flip front for the winter. Now getting glasses on with an open face is bad enough, but a painful nightmare on a full face and sooner or later I'll probably break one of the arms.
I am just about legal without glasses, but I'd rather wear them. Anyone know where I can get a pair of prescription specs that are made with bikers in mind?
doggone
PostPosted: 22:18 - 13 Nov 2020    Post subject: Reply with quote
You might be able to slightly modify the helmet padding to make it easier, how about alternative glasses with thinner arms.
Contacts out of the question?
smokin joe
PostPosted: 22:24 - 13 Nov 2020    Post subject: Reply with quote
Contacts are definitely out of the question. Any tips on how to modify the padding without ruining it?
doggone
PostPosted: 22:34 - 13 Nov 2020    Post subject: Reply with quote
They all vary but you can often at least get cheek pads out often held in with poppers or velcro.
The actual padding is like polystyrene it might compress a few mm with a bit of gentle force.
Shaft
PostPosted: 00:06 - 14 Nov 2020    Post subject: Reply with quote
I'm slightly surprised you didn't figure this out before you bought, it's the first thing I check when I try a new lid - doesn't matter how much I love the way it fits, what it looks like or how much it costs, if I can't comfortably put on and wear my glasses, I don't buy it.
What you need is a bit of a slot going across your temples to the top of the ears.
If you have a removable lining, then take it out and use something like a needle file to put a groove into the polystyrene, not too deep, just enough.
Or, if you've only just bought it, go back and change it for something else, quite a few manufacturers include spectacle slots into their designs.
Or, get different frames that will work better.
ThatDippyTwat
PostPosted: 06:43 - 14 Nov 2020    Post subject: Reply with quote
Yup, You're right, you can break your glasses. Done that, always carry a spare pair now, as I'm full on Mr Magoo without them. It seems that with my head shape, Arai lids and glasses do not mix even with the tiny frames that I wear, but HJC work well for me (current main lid is an IS-17). You need to check this before you buy, which may be tricky in the current climate. Use your old lid again if it's usable until you get a new lid.
Skudd
PostPosted: 08:22 - 14 Nov 2020    Post subject: Reply with quote
When I get new glasses I take my lid in to see if they fit and I can put them on with my lid on. The arms to my glasses are very bendy.
Fogging is my main issue. Have never found a satisfactory method to stop fogging.
Kentol750
PostPosted: 11:31 - 14 Nov 2020    Post subject: Reply with quote
+1with skudd, mine have very straight arms and slide in fine.
Some bikes.
ZebraDriver
PostPosted: 11:42 - 14 Nov 2020    Post subject: Reply with quote
A mate of mine used to cut the arms of his glasses in half to use them with a FF helmet. Does mean that you need two pairs though
Freddyfruitba...
PostPosted: 13:22 - 14 Nov 2020    Post subject: Reply with quote
+2 - very straight, flat arms which are right up against the side of my head. No probs at all
Keithy
PostPosted: 16:09 - 14 Nov 2020    Post subject: Reply with quote
https://www.championhelmets.com/en/blogs/motorhelmen-en-kleding-wereld/best-glasses-friendly-motorcycle-helmets-2020-guid/
When I was trying helmets I’m sure the chap at the shop said quite a few are designed with a narrow furrow in the lining where the arms of your glasses go?
Wonko The Sane
PostPosted: 18:21 - 14 Nov 2020    Post subject: Reply with quote
yup, this.
helmet goes with me when buying glasses, glasses come in different widths depending on the style which can affect things, however across HJC and Shark I've never had an issue with my glasses fitting or being broken in 7 years.
I have had one or two pairs of glasses I decided against though.
My latest shark (D-Skwal I think) advertises itself as being glasses friendly.
PostPosted: 18:44 - 14 Nov 2020    Post subject: Reply with quote
My favourite helmet is an HJC CL max that was advertised as having a glasses groove. It's utterly brilliant and I get very little pressure on my temples wearing glasses.
That doesn't help you I know, but what were you thinking of, not trying with glasses before you bought.
Triumph Trophy Launch Edition
smokin joe
PostPosted: 19:00 - 14 Nov 2020    Post subject: Reply with quote
Because when I last had a bike (In 2012) I did not wear glasses and the thought that they might be a problem now I do didn't occur to me.
The cheek pieces do pull out, so hopefully I'll be able to modify them.
PostPosted: 19:08 - 14 Nov 2020    Post subject: Reply with quote
I tend to go for Oakley frames which have straight arms with no hooks. I also check my lid before I buy one, my Shoei GT-Air is really good, as were the HJC's I've had recently.
Tdibs
PostPosted: 19:24 - 14 Nov 2020    Post subject: Reply with quote
I know some people are set in their ways or cant have them due to prescription, but contact lenses are the only real answer. Worn glasses all my life, but I only wear contacts when I ride, I hate the feeling of glasses on in a lid, feels like I lose all peripheral vision and the fogging is a pain.
Having a monthly pair of contacts makes it all super easy.
Fisty
PostPosted: 19:26 - 14 Nov 2020    Post subject: Reply with quote
The road ahead is clear........ you need a REDACTED we all know that REDACTED stops fogging.
Fatter and faster than Fret
smokin joe
PostPosted: 17:12 - 21 Nov 2020    Post subject: Reply with quote
Problem solved!!!
Found an old pair of plastic framed reading glasses, dipped the arms in hot water to soften them and straightened the ends so they don't point inwards and they slid straight into the helmet no bother.
A pair of prescription glasses now ordered from Select Specs, cheap enough at £16.95 delivered so I can bend them to shape without worrying about losing a small fortune if they break Smile
Ian193
PostPosted: 18:36 - 24 Nov 2020    Post subject: Reply with quote
I manage to get my viper flip front helmet on and off with my glasses on
https://badges.fuelly.com/images/sig-uk/858437.png
xX-Alex-Xx
PostPosted: 22:06 - 24 Nov 2020    Post subject: Reply with quote
Best solution to this problem: Photorefractive keratectomy. Best money you’ll ever spend. Thumbs Up
DILLIGAF
to v or not to v
PostPosted: 22:58 - 24 Nov 2020    Post subject: Reply with quote
i have been told that lazer treatment is as likely to be only a temporary improvement as not?
my partners mum paid out quite a bit for it a few years ago with poor results.
the company that did the treatment pretty much just fobbed her off after they had her money.
growler
PostPosted: 09:27 - 25 Nov 2020    Post subject: Reply with quote
I Have a Caberg Flip and the same
DILLIGAF
ThunderGuts
PostPosted: 13:22 - 25 Nov 2020    Post subject: Reply with quote
I find contacts dry out really quickly on the bike, even with the visor shut; I think there's quite a draught still via the vents / neck and it's enough to make it uncomfortable. Put it this way, I tried and turned back home 100 yards down the road. Maybe I should try again? I was using soft daily disposables though if that makes any difference.
TG.
MCN
PostPosted: 20:39 - 04 Dec 2020    Post subject: Reply with quote
You need Visionpal.
https://divesightltd.com/collections/prescription-dive-masks/?gclid=Cj0KCQiA2af-BRDzARIsAIVQUOdssJQquP3rOnvw9iOkTTpX8v2otam1rl-fjQxAuI7MgC8cNHm3kZgaAtk_EALw_wcB
Shaft
PostPosted: 00:21 - 05 Dec 2020    Post subject: Reply with quote
Unless this isn't a suitable treatment for an individual, as it isn't for me.
I'm also not a suitable candidate for contacts, so for some of us, specs are the only option.
The last post was made 5 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 127.31 Kb
