| smmi10 |
 smmi10 L Plate Warrior
| Bhud |
 Bhud World Chat Champion
| Robby |
 Robby Dirty Old Man
| stinkwheel |
 Posted: 22:33 - 15 Nov 2020 Post subject: |
Top tip. If you put it back in the bike, you can use a 2 or 3-leg puller hooked under the edges of the top yoke to compress the fork cap. It even has a dimple in the centre for the bolt of the puller. One it's compressed, you'll be able to lever the circlip out of the groove with a flat bladed screwdriver, it's just a thin circle of wire.
I would advise wearing eye protection because the stopper is under spring pressure, You want to ease tyhe tension off slowly but if the puller slips off once the circlip is removed, it'll fire the stopper out like a bullet.
Remember to loosen the bottom damper rod bolts before removing the cap if it is your intention to strip the fork down. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 5 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
