minimum tread depth
White Noise
Mr Dudwee
PostPosted: 20:52 - 03 Apr 2005    Post subject: minimum tread depth Reply with quote
Right i am being really lazy but cound someone tell me the minimum tread depth for tyres, i have been told that its 1 mm but i thought it was at least 2mm over 75% of the tyre, i have measured it with a depth gauge and its 1.46mm so i hope the minimum is 1mm, i have my MOT in may so i will get replaced for that! by the way its the rear, the front is fine.
WN
Quote Me Happy
PostPosted: 20:55 - 03 Apr 2005    Post subject: Reply with quote
I'm fairly sure it is 1mm Thumbs Up
tatters
Exxon Valdez
tread must be over 2mm for motorbikes in the centre, most tyres have wear inducators in the centre tread.
as long as there is visable tread on the tyre for mopeds
Jrod
Page 3 Girl
PostPosted: 21:00 - 03 Apr 2005    Post subject: Reply with quote
The legal limit for motorcycle tyre tread depth is 1.0mm
Retro-Man
PostPosted: 21:07 - 03 Apr 2005    Post subject: Reply with quote
The legal limit for motorcycles is 1.0mm and 1.6mm for car tyres. In both cases you must have minimum tread depth across the central 3 quarters of the the tread, throughout the whole circumference of the tyre.
Retro
p.s. not all tyres are born equal in the case of car tyres new tyres can have between 7mm and 10mm of tread although the usual is 8mm.
motorcycle tyres tend to have 3mm of tread when new.
https://domharnessphotography.webs.com
DanceLikeAMon...
PostPosted: 21:41 - 03 Apr 2005    Post subject: Reply with quote
Yup, if you look a the side of your tyre, you will see a series of small arrows at regular intervals, these point to where the indicator is on the centre of the tyre (I think that's on all tyres anyway Confused )
Retro-Man
PostPosted: 21:45 - 03 Apr 2005    Post subject: Reply with quote
or in the case of michelin it will be the michelin man "bibendum"
Johnny GSX-R
PostPosted: 17:28 - 04 Apr 2005    Post subject: Reply with quote
The actual legal requirment for motorcycle tread depth is 1mm across 2/3rds of the trye and constant visible tread across 100%.
So, if your tyre is wearing thin in the middle don't panic, as long as there IS visible tread around the full tyre and at least 2 thirds of the tyre are 1mm or over then you should be fine.
However, if you let your tyres get in such a state then you want a slap Confused
JonT
PostPosted: 17:32 - 04 Apr 2005    Post subject: Reply with quote
You have to have 1.0mm but I would seriously considering replacing tires before that, probably at 1.3mm.
map
Mr Calendar
PostPosted: 17:33 - 04 Apr 2005    Post subject: Reply with quote
Johnny 'XX' wrote:
The actual legal requirment for motorcycle tread depth is 1mm across 2/3rds of the trye and constant visible tread across 100%...
...but if you ride a moped then there's no minimum tread requirement - go figure Rolling Eyes
Finglonga
PostPosted: 17:46 - 04 Apr 2005    Post subject: Reply with quote
The realy frightening thing is that as well as motorcycle tyres bieng 1mm minimum tread depth. HGV's also only require 1mm of tread to be legal. Shocked
Andy Sez....
F.Y.Y.F.F.
White Noise
Mr Dudwee
PostPosted: 19:42 - 04 Apr 2005    Post subject: Reply with quote
Cheers for that guys, there is plenty of tread off the centre, i blame the previous rider! Laughing
Will keep a very close eye on it, and get it changed well in advance of 1 mm.
dam scary about HGV's will be giving them a very wide berth in the wet!
WN
Retro-Man
PostPosted: 20:10 - 04 Apr 2005    Post subject: Reply with quote
https://ukrm.net/faq/Bikes_and_the_Law.html
section 5.17
https://www.tyres-online.co.uk/techinfo/tread_depth.asp
https://www.superbiketyres.com/faqs.htm
https://www.etyres.co.uk/uk-tyre-law
https://driveradviser.com/tyre/faqMotor.shtml
https://www.legislation.hmso.gov.uk/si/si2003/20032695.htm
as noted in above link be aware mopeds do have tread requirements.
binge
Emo Kiddy
PostPosted: 20:22 - 04 Apr 2005    Post subject: Reply with quote
Actually Jonny Wink
He is correct. On a moped (Im sure it only applys for 50cc) then aslong as the tread is visible, you are legal. There no minimum requirement.
They told me this at the MOT center...
<|Ben|>
kasandrich
PostPosted: 11:05 - 05 Apr 2005    Post subject: Reply with quote
And mopeds don't need a number plate light either Confused
Richard
CBR1000FM
dodsi
Dirty Carny
PostPosted: 11:10 - 05 Apr 2005    Post subject: Reply with quote
And moped riders dont requre any road sence.
map
Mr Calendar
PostPosted: 13:05 - 05 Apr 2005    Post subject: Reply with quote
Johnny 'XX' wrote:
The actual legal requirment for motorcycle tread depth is 1mm across 2/3rds of the trye and constant visible tread across 100%....
Everything I've read on this says 1mm over 3/4 (75%) of the tyre width (not 2/3 - 66%) with tread visible over the whole circumference.
For mopeds and motorcycles under 50cc the original tread pattern must be visible.
Penalties are a Fixed Penalty Notice or report for prosecution, maximum £2500 and 3 penalty points. This can be per tyre.
So if stopped by 'Johhny XX' you've a 9% margin for error, unless you're on a moped when you'll be done anyhow Very Happy
The last post was made 21 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 96.74 Kb
