 DrBob L Plate Warrior
 Posted: 02:06 - 23 Nov 2020 Post subject: |
Sounds like you need a workshop manual.
I wouldn't undertake a job like that without one.
The answer to your question is almost certainly yes for most of it.
If you are going to want to mess with gears, the clutch will probably need to come off the end of the shaft anyway and that is a much easier job with the engine in the frame and the chain still on so you can lock the transmission up. Loosen the final drive sprocket while you're at it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
 bikenut World Chat Champion
