| buzzer1955 |
 buzzer1955 Nitrous Nuisance
 Posted: 11:47 - 12 Dec 2020 Post subject: |
| arry |
 arry Super Spammer
 Posted: 18:09 - 12 Dec 2020 Post subject: |
Just had a look at your blog. You've had some mega cars  |
| buzzer1955 |
 Posted: 18:56 - 12 Dec 2020 Post subject: |
| Shaft |
 Shaft World Chat Champion
 Posted: 00:17 - 13 Dec 2020 Post subject: |
Given your penchant for Italian iron, I'm surprised you didn't pick one of your Lancias - the Monte was a bit 'difficult', but Themas were great cars, I did very well with them (and Cromas) when I was trading, so much cheaper than Saab 9000s.
Having said that, I do have a soft spot for Scimitars, in fact pretty much anything with a 3.0 Essex, except for my Gilburn Invader, which was a dog with fleas  ____________________ Things get better with age; I'm close to being magnificent........
| buzzer1955 |
 Posted: 20:07 - 14 Dec 2020 Post subject: |
[/quote]
Having said that, I do have a soft spot for Scimitars, in fact pretty much anything with a 3.0 Essex, except for my Gilburn Invader, which was a dog with fleas [/quote]
I had a couple of Scimitars, a 3.0 and also a 2.5 straight 6 with a raymond hayes head and triple SU carbs.. my other favourite car was the BMW 7 series...
Started the rebuild… first job was to put the frame on the engine, easy job, I held it, my wife popped the bolts in! I then fitted the headstock bearings, which I have replaced as there were small sighs of pitting, and they are cheap. I pulled them in rather than use a hammer, which also means you can give them a good tighten and bed them in nice and hard against the register. Its starting to come together… Was also playing around with the image of the engine…
https://jtccc.files.wordpress.com/2020/12/50716400947_c5ed40a295_o-copy.jpg
https://jtccc.files.wordpress.com/2020/12/head-stock-copy.jpg
https://jtccc.files.wordpress.com/2020/12/50720213611_0717096a72_o-copy.jpg |
| buzzer1955 |
| buzzer1955 |
 Posted: 12:00 - 18 Dec 2020 Post subject: |
Its funny how to me progress seems slow, but when you come to put it all together you realise that all the little jobs you have been doing over the months are now paying off as it becomes an assembly job! One thing I have done in the last few days is to check the loom over… its in great condition apart from one area… It looks like someone has fitted an alarm at some point…, and someone has subsequently removed it! they didn’t do a bad repair, but I hate the tape over bare wires, and I wanted to check the integrity of the joints, so I pulled the soldered wires apart and re-soldered them, and covered the join with shrink wrap. To finish it off nicely I took the terminals out of the blocks with my terminal removal tool. this is a fantastic little set of tools, and very cheap to buy.. I have lost count of the times I have used them over the years! that meant I could use some braided expandable sheathing which most cars seem to use these days. it means it can go over the terminals and then fit tight on the wires. this is finished off with some hear shrink, and if you use the glue lined stuff it makes a good repair.
probably my last update this side of the holiday... Merry Christmas!
https://jtccc.files.wordpress.com/2020/12/wireing-copy-small.jpg
https://jtccc.files.wordpress.com/2020/12/engine-in-frame-3-small.jpg
https://jtccc.files.wordpress.com/2020/12/engine-in-frame-1-small.jpg
https://jtccc.files.wordpress.com/2020/12/engine-in-frame-4-small.jpg |
| struan80 |
 struan80 World Chat Champion
 Posted: 16:18 - 18 Dec 2020 Post subject: |
Nice mate. |
| Easy-X |
 Easy-X Super Spammer
 Posted: 17:26 - 18 Dec 2020 Post subject: |
https://media.giphy.com/media/huyVJYSKcArLiu8J5g/giphy.gif ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| buzzer1955 |
 Posted: 13:17 - 26 Dec 2020 Post subject: |
back after the break... I did relent and have a few hours in the workshop next the hydraulics … I stripped everything down and cleaned the callipers and master cylinder up. the callipers came up well, but the anodizing on the master cylinders were poor… so I bead blasted them and have decided to leave them silver… All the seals were perfect, so I have reused these. I cleaned the callipers up in petrol with some very fine scotchbrite, being very gentle, they came up a treat.
looked at the switchgear and although its in great condition, the plastic sleeving was tatty… so I used some of the braided stuff, and some glue lined shrink wrap to finish it off… the braided stuff expands a lot, so no need to remove the terminals off the wire which is a bonus.
https://jtccc.files.wordpress.com/2020/12/hydralics-copy.jpg
https://jtccc.files.wordpress.com/2020/12/50750513308_79f484eae3_o-copy.jpg |
| buzzer1955 |
| buzzer1955 |
 Posted: 16:28 - 13 Jan 2021 Post subject: |
Time to start up soon… I am always aware that a rebuilt engine needs oil at first start-up, and while I always fill the filter before I screw it on, the oil cooler and pipes are empty, as are the oil ways, and the oil pump. I have therefore always used this method of giving the engine the best start in life I can and inject some oil into the system via the oil pressure switch port.
I used to do it on many of the race engines I have built in the past and it was always satisfying to take the oil filler cap off and see oil seeping out the rocker shafts or cam bearings. Either way I always turn it over until the oil warning light goes out… which unless you prime the oilways can be a worrying amount of time!
https://jtccc.files.wordpress.com/2021/01/oil-fill-copy.jpg |
| buzzer1955 |
| buzzer1955 |
 Posted: 17:59 - 28 Jan 2021 Post subject: |
been out of action for almost 2 weeks... strained my left hand, taking off a lid off a jar of all things, so thought it better to rest it... getting there now... sigh of getting older I guess...
Started preparing the tanks and bodywork for painting… I know the tank hinge on the monster is a weak point, and it did show evidence of being strained… I didn't want to paint the tank and find out it soon failed, so I decided to take the bracket off and strengthen the area and TIG weld the bracket back on… I normally have tanks blasted but the guy who does it for me is off with Covid at the moment, so it may be a while before he is back, and I don’t trust anyone else after having some shocking jobs done in the past….
https://jtccc.files.wordpress.com/2021/01/tank-repair-copy.jpg
https://jtccc.files.wordpress.com/2021/01/50884995047_09d1c77c07_o-copy.jpg |
| buzzer1955 |
 Posted: 18:06 - 29 Jan 2021 Post subject: |
things didn’t go well with the painting… the seat cowl had rattle can paint on it by the look of it... and it reacted badly to the base coat. going to have to do it all again. the other parts came out well though… two coats of clear on the mudguard and fairing, one coat on the tank before I put the decals on and then hit it with one and a half coats…
https://jtccc.files.wordpress.com/2021/01/50887295223_1e1c7db056_o.jpg |
| arry |
 arry Super Spammer
 Posted: 18:26 - 29 Jan 2021 Post subject: |
Wow that's come on amazingly  |
| buzzer1955 |
| buzzer1955 |
 Posted: 18:44 - 04 Feb 2021 Post subject: |
One of the few fabrication jobs I have done on this bike… I have decided to fit an ignitech ignition… Most people seem to fit them next to a smaller battery, or move the coils over, but I wanted to keep the unit away from the heat of the engine… So I made a bracket to fit it under the LH side panel. it just fits nicely…
https://jtccc.files.wordpress.com/2021/02/ignitech-mounting.jpg |
| buzzer1955 |
 Posted: 16:14 - 06 Feb 2021 Post subject: |
well apart from a few snagging jobs, and replacing the rear brake hose which is too long… its finished. I need to tweak the ignitech unit and enable one of the output channels to limit the revs to 2500 when the stand is down… When I was 19 a good mate rode away from the pub with the stand down… just up the road he came off, and the accident resulted in him losing an arm… those things stay with you…
Need to find another project now! if anyone in the UK has anything... let me know!
https://jtccc.files.wordpress.com/2021/02/side-2-copy.jpg
https://jtccc.files.wordpress.com/2021/02/side-1-copy.jpg |
| Easy-X |
 Posted: 17:41 - 06 Feb 2021 Post subject: |
Fancy a CBR1000F from the '80s?
Stunning work on the Ducati  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| buzzer1955 |
| arry |
 arry Super Spammer
| buzzer1955 |
| buzzer1955 |
 Posted: 13:06 - 22 Feb 2021 Post subject: |
I was looking at the picture of the bike the other day and thought” those silencers are too long”… and its too quiet… Well I had the original silencers which were quite marked, So I looked at shortening them and removing part of the baffle… not a bad job… by removing the bracket I was able to slide the sleeve down enough to remove the end with a cutting disc. I then cut 100mm off the inner and sleeve (both ends to preserve the stampings) , and welded it all back up again. One thing I learned many years ago when welding exhausts is to clean the carbon off the inside… or it leaches through the weld and the joint cracks! They polish up really well…you just have to remove the original finish with a DA sander with some 120 grit, followed by some 400, then polish…
https://jtccc.files.wordpress.com/2021/02/silencer-h.jpg
https://jtccc.files.wordpress.com/2021/02/silencer-i.jpg
https://jtccc.files.wordpress.com/2021/02/silencer-a.jpg |
| buzzer1955 |
 Posted: 16:51 - 23 Feb 2021 Post subject: |
well my builds have come to an end for this year... and one must go to make way for a new project which I will hopefully start next winter. not sure what it will be yet... time to think, and find something suitable...
https://jtccc.files.wordpress.com/2021/02/4-bikes-copy.jpg |
The last post was made 5 years, 184 days ago. Instead of replying here, would creating a new thread be more useful? |
