| The Tot |
 The Tot World Chat Champion
 Posted: 13:32 - 19 Dec 2020 Post subject: Home tyre changes |
I've been deliberating as to whether or not to pull my finger on the trigger and start doing my own tyre changes. Between my R1 and Fazer, I tend to go through 2 sets of tyres per year on each bike.
I'm constantly remounting and mounting tyres quite frequently on my enduro and downhill mountain bikes, but 190 section tyres are a different kettle of fish.
So if any of you do your own changes, what kit you've been using. I can get my tyres mounted for a tenna at my local tyre place but they don't do motorcycle tyre balancing. Not that it'll be an issue since I'll be using a kit that converts your paddock stand to wheel balancer.
I was considering using the Motion pro tyre levers and bead breaker
https://www.dirtbikexpress.co.uk/images/products/15653_med.jpg
or the Pro Works Tyre Machine once it's back in stock
https://pierce-images.imgix.net/images/8/8/7/8/8878f627e3b28b5cabcef3cdb23789715c10b7a2_2_PW_GTM_B_0_01.PNG?h=1200&auto=format&q=50&fit=crop&bg=F0F1F2&fm=jpg&auto=compress&w=1200
Secondly, what's the minimum compressor flow rate that is recommended to bead the tyre. Has anybody seated their tyres using a dual cylinder foot pump. I'm approaching this from a convenience and excuse to get my hands dirty and tinker point of view rather than short term cost savings. The missus would like to convert the old tyres into flower beds and hanging baskets in a section of our garden.
My local tyre shops are only 3 miles away and I get on well with them, but I'd want the convenience of doing an evening job, fettling in the garage. ____________________ The Tot 2019 Z1000SX - 2007 R1
Never argue with autism |
| doggone |
 doggone World Chat Champion
 Posted: 13:54 - 19 Dec 2020 Post subject: |
There are ways to get the initial seal, I have used a ratchet strap round the circumference several times, but some lube is your best friend.
The most difficult part at home is breaking the bead, with low profile tyres you might have barely two inches to work on.
The tool you suggest looks much better than my techniques which have involved a big vice, door jambes, spades and running over with another vehicle  |
| The Tot |
| doggone |
| Riejufixing |
 Posted: 14:20 - 19 Dec 2020 Post subject: Re: Home tyre changes |
I don't ;like the look of those. They look like rim harmers and bead shaggers to me.. I prefer something altogether more rounded than angular and sharp. |
| Nobby the Bastard |
| yen_powell |
 Posted: 15:24 - 19 Dec 2020 Post subject: |
Buzzetti levers (the long ones are good). Had mine for about 20 years now. They are very good for not pinching inner tubes and when I switched to tubeless they carried on doing good work. Note I am talking about the long ones, I use three, I have the short ones as well, bought them for carrying on the trail but I am not a fan.
https://www.amazon.co.uk/BUZZETTI-Professional-Lever-Dismantling-Tyres/dp/B077JXQL3X ____________________ Blackmail is a nasty word........but not as nasty as phlegm!
XT1200Z and a DR350 in bits |
| The Tot |
 Posted: 15:34 - 19 Dec 2020 Post subject: |
I was looking at something from MAX2H.
https://www.youtube.com/channel/UCSvbI6Nqb_DM5FgYf3kpscQ
They also had something similar from XLmoto too. If that's the consensus, I probably won't mind investing in it, since it would probably pay for itself after a season of riding.
I think the only outstanding question is compressor tank volume and pump capacity. Will I get away with a 24L that delivers >8CFM or would a 50L reservoir be required to bead the tyre with the valve core removed? On my tubeless downhill casing tyres, I've got a booster reservoir on my track pump that I can get to 100PSI (probably about 1L volume) that I use to bead the rims, but I don't know what the equivalent volume/pressure would be. Obviously will have other uses for the compressor in and around the house.
I guess for me, it's the satisfaction of doing things done myself, even if it means perseverance and swearing, so that I can sort out my mates out for tyre changes too. I'm already the go to mountain bike mechanic on my estate for tyres and drivetrain and suspension setting. ____________________ The Tot 2019 Z1000SX - 2007 R1
| ThatDippyTwat |
| steve the grease |
 Posted: 17:28 - 19 Dec 2020 Post subject: |
Changing cold tyres in cold weather is a nightmare, in comparison, warm rubber falls off the rim and is lovely and flexible whether removing or fitting. As everyone else has said - considerations around breaking the bead, nipping tubes, getting the tyre to seal , etc all apply.
Get a big tub of tyre fitting paste and split it with your mates- its like 12 quid for 5kg enough to fitt half a dozen resealable ice cream tubs. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| oilyrag |
 oilyrag Nova Slayer
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 21:00 - 19 Dec 2020 Post subject: |
I've used this to change about a dozen tyres, saving me about £120 so far. Off ebay for £75, so it's easily paid for itself. Nice to not have the hassle of taking the wheel down to the tyre shop, or being limited to their opening hours.
https://www.planetash.net/bcf/tyrechanger.jpg
Had to bolt it to a paving slab as i haven't anywhere solid to bolt it to, which stops it from spinning around when levering off/on the tyres.
Before i do another i'll be welding some better, wider fingers on it, as the existing ones tend to scrape the rim if it's not in tight enough and the wheel moves, but apart from that it does a reasonably good job. The arm is a bead breaker that works very well too. ____________________ A Guide To Powerbands |
| Riejufixing |
| doggone |
| Robby |
 Robby Dirty Old Man
| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:55 - 19 Dec 2020 Post subject: |
Have tried spoon style levers and big 450mm jobbies.
But have easier success with 240mm motox levers like these
Get 3.
Rim protectors are often quite thick (for good reason). A plastic bottle does the job a bit easier as its thinner, but will move about.
Bead breaker. If you have another bike, can use sidestand while sitting on bike.
I did get one of these though
Works well enough, but fairly cheaply made.
Wheel balancer works well.
Fairly liquid makes the job much easier.
I've managed to inflate all tyres just using a twin piston foot pump.
But might have used a cheap 250psi ebay compressor on one set thinking about it.
Spent £100. Changed 6 tyres. Then decided, it wasn't worth the slips and dings in the rim. Or the time.
If you have a shop that close, that charges that little. I'd stick with it.
But if you want to save money over years of changing tyres, then  |
| sickpup |
 sickpup Old Timer
| colink98 |
 colink98 Could Be A Chat Bot
 Posted: 09:52 - 20 Dec 2020 Post subject: Re: Home tyre changes |
not as easy to break the bead as suggested.
while you can get under the lip of the rim the other leaver slips down the wall of the tire as opposed to pushing it off the rim.
while like yourself i do like to have a go at all these things.
this is one of them areas that seems more hassle than its worth. ____________________ PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week. |
| droog |
 droog Spanner Monkey
| A100man |
 A100man World Chat Champion
 Posted: 11:40 - 20 Dec 2020 Post subject: |
Its a job I hate but I persist because I'm mean. I only do teh tubed tyres on my 550 and 250 the worst bit is trying to feed the valve stem in (lots of trapped an bruised fingers) then trying to make sure the bead sits properly 'circular'. That said I have tyre fitters not do tat properly too. 75 quid for a tool seems cheap if it works well and doesn't scratch teh rims
My local place used to be 12 quid (10 plus dreaded) but last time it was 18 quid which is a but tall IMO. ____________________ Now: A100, GT250A, XJ598, FZ750, SL1000
| yen_powell |
| Riejufixing |
 Posted: 12:40 - 20 Dec 2020 Post subject: Re: Home tyre changes |
| ColinK98 wrote: |
while you can get under the lip of the rim the other leaver slips down the wall of the tire as opposed to pushing it off the rim |
That's what I don't like, the possibility of rim damage. There are lots of easy ways to break the bead (online videos interesting), and once that's done, the job's easy enough, with some care. Me, I use ground-down cheap levers (ground because the elongated "8" cross-section of the levers was damaging), and break the bead in my press, so it takes no effort. Were I to buy levers I'd get the "spoon end" type, like the old Dunlop ones.
Edit: Motion Pro T-6 have similar ends to the old Dunlop ones, and a practically useless spanner on t'other end, buyt are expensive. Maybe they're silver-plated or specially tuned up, who knows. |
| droog |
| Fizzer Thou |
| Bhud |
 Bhud World Chat Champion
 Posted: 00:35 - 21 Dec 2020 Post subject: |
Nice little upgrade - I think I'll switch to these. I've been using horrible ones (like Riejufixing's). |
The last post was made 5 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
