Gear problems!
WaveyNSR
Guest
PostPosted: 03:30 - 08 Nov 2002    Post subject: Gear problems! Reply with quote
Never been on a chat forum before so here goes....
I've recently started riding and own a NSR125R, & have lately discovered that my gear lever is playing games. For instant I could have it running & it will fail to get in gear and I can't put it in Neutral, and therefore sometimes can't start the thing after. Has anyone else had this happen? Or heard about it? My Mum has same bike and finds the same problem.
Let me know if u can help??? Wink
TiN
Pocket Tin
PostPosted: 09:12 - 08 Nov 2002    Post subject: Reply with quote
Your mum has an NSR?...interesting...Razz
Anyhoo, you can start the bike when it's in gear (as long as your don't have the side stand down) by just holding the clutch in when you press the starter button.
I can't seem to make out whether your problems arise when you're actually riding the bike, or just after leaving it to idle?...is there any particular gear that it doesn't like?
There a few "tricks" to help you change down (or up) through the gears at a standstill...my personal fave is to:
1) hold the clutch in
2) step down on the gear lever...keep your foot on the lever
3) then slowly release the clutch up to the biting point
4) if all goes well, you should feel and hear the gear going into place.
5) release your foot from the lever, and repeat the process if necessary Smile
I can't offer you any mechanical explainations I'm afraid, but I'm sure that there are a few peeps here who can.
TiN
dotgems.net
PostPosted: 10:07 - 08 Nov 2002    Post subject: Reply with quote
Is this just first and second gear you're having problems with?
To add to tin's list, to get it into neutral; from first I sometimes find it help to (use the engine to) move the bike forward slightly.. only about half a metre. Then knock it up.
and don't worry.... most of us aren't as scary as we may seem Very Happy
Ropehead
PostPosted: 11:44 - 08 Nov 2002    Post subject: Reply with quote
My gearbox was getting a bit ropey so i changed the oil and it just slid in to gear ofterwards,
real Smooth Laughing
worth a try
Demonic69
The Pink Rhino
PostPosted: 12:01 - 08 Nov 2002    Post subject: Reply with quote
Your bike's a bit ropey mate. So're you Wink
Back on a Blade. Just feels so right.
Phoenix
Twisted Firestarter
PostPosted: 12:20 - 08 Nov 2002    Post subject: Reply with quote
I tend to find my gearbox gets a bit clunky and sometimes misses neutral or gives false neutrals in the period just after an oil change actually. But on the whole the kawasaki gearbox is very good compared to my previous 2 yamaha ones which were pretty shoddy.
Scotty
Scooter Boi
PostPosted: 13:09 - 08 Nov 2002    Post subject: Reply with quote
I havent had any problem with the gears on my bike. but i did find when the clutch was a bit slack maybe a mm or 2 out, it was a bitch getting it to idle in first and then trying to get it into neutral to start it again.
Definetly a bit of a git at the lights, but a quick adjustment sorted that little problem out.
Have a look at your clutch adjustment and make sure when you pull the clutch its actually moving the thing fully out.
(much eaier to see on an unfaired bike....)
Regards
Scott
tanner18
PostPosted: 13:51 - 08 Nov 2002    Post subject: Reply with quote
the gearbox on my nsr was really good. very smooth!
inline 4's rule
Phil.S
PostPosted: 18:08 - 08 Nov 2002    Post subject: gears Reply with quote
check that your selector isn't loose aswell
i took mine in to carnells (err Riossi) with the same problem and he tightened it up and hey presto like new again.
Opinions are like assholes,
Everyone has got one.
(Dirty Harry)
PostPosted: 18:32 - 09 Nov 2002    Post subject: Reply with quote
How old is the bike? If its under 2 year, just go back to the shop you got it, or a nearby honda dealer, and they should do it for you.
Before my bike was serviced, it wouldnt go into neutral easily, and then i guess they changed something, ands its easy as pie now Smile
By problems starting, what do you mean exactly?
The last post was made 23 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 63.07 Kb
