Oil level window.
steve the grease
PostPosted: 11:14 - 23 Dec 2020    Post subject: Oil level window. Reply with quote
Has anyone got experience of removing and refitting these clear plastic parts successfully. I want to get my engine covers powder coated , during the off season/lockdown, ready for 2021. Thanks.
oilyrag
PostPosted: 16:11 - 23 Dec 2020    Post subject: Reply with quote
I think they're just an oil seal with a plastic centre so getting them in and out is basically the same as doing an oil seal. If you have a look on youtube you should find videos of people replacing them.
Nobby the Bastard
Harley Gaydar
PostPosted: 16:13 - 23 Dec 2020    Post subject: Reply with quote
What is 'off-season'?
Triumph Sprint ST 1050
yen_powell
PostPosted: 16:33 - 23 Dec 2020    Post subject: Reply with quote
Christmas day, boxing day if stretching it.
XT1200Z and a DR350 in bits
Nobby the Bastard
Harley Gaydar
PostPosted: 16:41 - 23 Dec 2020    Post subject: Reply with quote
What about if you realise you've run out of AA batteries and need to go to the nearest 24 petrol station to get some?
jeffyjeff
PostPosted: 20:24 - 23 Dec 2020    Post subject: Reply with quote
I recently replaced the sight glass on my 2002 BMW oilhead. The old one was plastic. "Heat a nail with a propane torch, melt through the plastic and simply pry out." So I was told. It took way more force to remove the old sight glass than I was led to believe; my slide hammer buggered it up more than it helped remove it. Unbeknownst to me, behind the sight glass backplate (left side) is an internal oil pipe. I'm lucky the prying force I applied did not damage it. Pried out the old part using a flat blade screwdriver and cleaned up the bore with a shop towel.
Installing the new sight glass was way easier than removing the old one. I used glass cleaner to lube the rubber seal, than tapped it into place with a plastic lead-shot hammer, using a socket as a driver.
steve the grease
PostPosted: 20:32 - 24 Dec 2020    Post subject: Reply with quote
Thanks guys.
MCN
PostPosted: 08:49 - 26 Dec 2020    Post subject: Reply with quote
The season when Steve the Grease falls off most.
I hope that helps?
steve the grease
PostPosted: 17:28 - 26 Dec 2020    Post subject: Reply with quote
I hope that helps?
Nah mate , can't get off the chair-- after 50 years of bikes , I don't fall off very often, although like stocks and shares past performance is no indicator of future behaviour.
The last post was made 5 years, 148 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 60.09 Kb
