spongey brake front brake?
CorriganJ
PostPosted: 15:34 - 25 Dec 2020    Post subject: spongey brake front brake? Reply with quote
(Hyosung GT125 disk brakes)
I'm a noob with bikes but recently my front brake has gone "spongey". It was a day or so after an emergency brake, so, as I say I'm a noob but I'm wondering if the heavy braking forces caused the brake line (quite old) to bubble or stretch in one area?
The brakes do still work and stop me, but less quickly than before, and there is a noticeable loss of feedback in the lever. It feels floppy instead of engaging straight away, and gives less feedback while stopping.
Does my diagnosis sound correct? Am I looking at replacing the brake cable? I took it to the garage where I bought the bike from, because I have a waranty, and they said it was fine, but I don't believe them because yes, it does still stop the bike, but there is a noticeable change in how it feels. I think they are just shrugging it off because they can't be bothered to fix it and I don't have any way to force them to honour the warranty.
Thanks in advance for any help!
1991 RD04
NJD
PostPosted: 15:59 - 25 Dec 2020    Post subject: Reply with quote
Remove calliper from disc, clean and lube appropriately and reattach; do the same with the brake lever pivot point and report back after a ride.
Dust and road salt at this time of year will reduce efficiency in stopping power after not very many rides if regular attention is not played as the salt will just sit in every part you never want it to and corrode away at parts.
Also take into account the effect that air temperature, road temperature and tyre temperature alongside weather conditions will have on your ability to stop on the whole (any problems aside). Its not difficult to ride this time of year and think there's a problem when there's not, but as above clean calliper and report back.
The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶
Kawasaki Jimbo
PostPosted: 16:29 - 25 Dec 2020    Post subject: Reply with quote
Inspect it.
When it comes to brakes it's unlikely even the most unscrupulous workshop would tell you they were fine when they weren't.
I've been deceived by "feel" where you start to think about an aspect of riding or maintenance and become convinced something is wrong when it really isn't. Have you just noticed slack that was there before but which you had no cause to think about until now?
Nobby the Bastard
Harley Gaydar
PostPosted: 16:37 - 25 Dec 2020    Post subject: Re: spongey brake front brake? Reply with quote
As you mention both hydraulic pipe and cable, I suggest you have a very close look to work out which your bike actually uses.....
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 17:33 - 25 Dec 2020    Post subject: Reply with quote
Chances are that the brakes need a good clean, and the heavy stop has got something that is meant to move around bound up on some rust.
jeffyjeff
PostPosted: 21:01 - 25 Dec 2020    Post subject: Reply with quote
Check the brake fluid level on the front brake reservoir. You might need to add fluid and bleed air out of the brake line.
History shows again and again how nature points out the folly of men - BOC
Pete.
PostPosted: 21:15 - 25 Dec 2020    Post subject: Reply with quote
First thing to do is remove the reservoir top, and the rubber diaphragm, then re-fit and try the brakes again. As the pads wear the level drops in the reservoir and the space is supposed to be filled with air from outside, but often the little bleed hole gets clogged and it pulls a bit of a vacuum in the reservoir.
a.k.a 'Geri'
CorriganJ
PostPosted: 23:40 - 25 Dec 2020    Post subject: Reply with quote
Thanks everyone for the responses! I will see what I can find.
1991 RD04
pepperami
PostPosted: 01:19 - 26 Dec 2020    Post subject: Reply with quote
My Hyosung gt125 has hydraulic brakes ( reservoir, hose, & caliper).
Once you have cleaned up the caliper and made sure everything can move as it should .
Try replacing the hose with a braided jobby.
It worked a treat on my GT250R Thumbs Up
MCN
PostPosted: 08:42 - 26 Dec 2020    Post subject: Reply with quote
Sand Paper the disc/s and pads.
Brakes can get a build up of brake pad material and road crap bonded to their 'working' surfaces.
Buy a packet of wet and dry medium grit paper (600 grit).
Remove the pads.
Place a sheet of the wet and dry on a flat surface.
Put the pad on the wet and dry and make 'Figures of Eight' on the paper to rub any build up off the surface friction material of each pad.
Take the paper and rub the surfaces of the disc to remove any discoloration.
It's a simple job, creates a bit of dust and requires the el ow to be well greased.
It will help the pads grip the disc.
It's a good habit to now-and-again do a bit of heavy braking after heating up the brake disc and pads.
Do it on a clear road, fairly slow speed (until you get acquainted with the procedure, so you don't fold the front wheel under the bike. Shocked )
If it continues to worry you, then upgrade the brake hose to a HEL Stainless Steel Braided hose.
https://www.helperformance.com/hyosung-gt125r-gt250r-2006-2007-full-length-race-braided-brake-lines
Many OEM machines use rayon/fabric braid reinforced hose. (Cheaper).
Some maintain that it makes no difference to brake performance.
Those are folk who probably did not have issue prior to fitting a SS Braided hose.
I fitted to a Honda CG125 which had Rubber hose from new.
The difference was exponential.
(And it shifted the power band 25% Degree BTDC. 👍)
CorriganJ
PostPosted: 19:44 - 10 Feb 2021    Post subject: Reply with quote
This was all I needed to do! Finally got around to looking at it today and fixed them up good and proper. Thank you
1991 RD04
The last post was made 5 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 73.3 Kb
