Opinions on tyre repair
Bhud
PostPosted: 16:26 - 05 Jan 2021    Post subject: Opinions on tyre repair Reply with quote
Hi, just wondering what you guys' thoughts are on this tyre repair:
https://i.ibb.co/mXTLtdJ/tiptop-tyre-repair.png
It's a Rema Tiptop tyre repair almost in the dead centre of the tyre tread. The puncture was caused by a pyramid-shaped (although with jagged edges) piece of flint, meaning that the damage to the tyre was greater on the external side than the internal. The tyre repair plug was done as per the manufacturer's instructions.
I don't know what to think, because the instructions say it's only good for 30 miles (although people say they get much more mileage out of them). Also, it was very easy to fit the figure-of-eight-shaped plug - very little reaming was required. I was expecting it to require more elbow grease. The tyre is a Michelin, it's a rear tyre, and the carcass is believed to be kevlar rather than steel. I wanted to go for a tyre repair rather than a new tyre, as this one is itself fairly new. I've reinflated the tyre and will check to see if it's lost any air over the next few days.
What do you think? Will it last? Is it dangerous?
Tankie
PostPosted: 17:10 - 05 Jan 2021    Post subject: Reply with quote
It's a get you home repair, which has done it's job .
Dismount the tyre from the rim check for damage from the inside and repair with a patch if it possible .
Kawasaki Jimbo
PostPosted: 18:09 - 05 Jan 2021    Post subject: Reply with quote
If you're asking us to comment on the quality of the repair that's hard to say. It looks like you used plenty of rubber glue, which is good. Rema Tiptops with the 'figure of 8' mushrooms are my favourites. In my experience once you've got the tool through the tyre the reaming (to clean/rough up the edges) isn't hard. Inside the tyre you'll have a mushroomed plug so it's not going to fall outwards. On the outside you'll have cut the other mushroom off, leaving a 'bum crack' as shown, but the two sides will be pressed and glued tight all round. I probably shouldn't say this but I treat them as fit-and-forget, however Tankie's advice about getting it patched internally if possible is good.
steve the grease
PostPosted: 19:56 - 05 Jan 2021    Post subject: Reply with quote
The problem with these types of repair is that even though there is a mushroom head on the plug the rubber inside the tyre has dirt and the remnants of a mould release agent on it - so nothing will stick to the surface properly. If the tyre is off the rim the rubber can be burred up so that a proper vulcanised repair can be done to raw rubber. This would be a 100% reliable repair - the patch is now part of the tyre- effectively welded.
Remember Murphys law-states that if anything goes wrong it will do so at the worst possible time - not what you want with a tyre.
it's a Michelin tyre , so worth the effort and right in the middle of the tread , should be straight forwards
Kawasaki Jimbo
PostPosted: 20:12 - 05 Jan 2021    Post subject: Reply with quote
But it's no different from a 'string' type plug except it has a mechanical element to it in the mushroom. The glue fixes either plug within the walls of the hole.
Oh, but if you mean in comparison to an internal patch then yes.
oilyrag
PostPosted: 20:15 - 05 Jan 2021    Post subject: Reply with quote
No one can say if that is a good repair or not. You are the one that did it and you are the one riding on it so it's up to you to make the call. I have always used string plugs and ridden on them for thousands of miles and never had one fail but that doesn't mean yours won't. You have to decide yourself if the risk is worth it or not.
Wull
PostPosted: 20:39 - 05 Jan 2021    Post subject: Reply with quote
I think the very fact that you are asking means either repair it correctly or replace the tyre.
"Scooters are for men who want to ride motorcycles but prefer to feel the wind on their vaginas"
Bhud
PostPosted: 20:42 - 05 Jan 2021    Post subject: Reply with quote
Quite right, yes.
The only thing that gave me pause for thought was the fact that the puncture hole was already surprisingly wide (it didn't look that way from the outside), and the bung went in straight, with hardly any exertion involved. I pushed the supplied abrading tool in and out a few times as directed, with some of the glue applied to it, before inserting the bung. This exercise didn't take much effort, and the whole business took about 3 minutes. That's why I'm a bit Confused about this repair. The kit says it will temporarily fix holes up to 4mm in diameter - the hole appeared to be far less than that, yet I would say it's about the maximum width for that plug.
In any case, it looks like it might be new tyre time. I'll keep an eye on it over the next few days (I won't be riding) and see if it's losing air anyway.
oilyrag
PostPosted: 20:53 - 05 Jan 2021    Post subject: Reply with quote
Bhud wrote:
Quite right, yes.
Right then I'm deciding for you. This is final no going back. A new tyre will be bought and while you're at it new oil and filter will also be bought.
PostPosted: 00:59 - 06 Jan 2021    Post subject: Reply with quote
I've brerached 150mph on a tyre with THREE tip-top inserts in, then proceeded to run the main tread all the way down to canvas, the inserts were the last bit of rubber present.
In conclusion. it's up to you. Motorbikes are dangerous.
jaffa90
PostPosted: 01:22 - 06 Jan 2021    Post subject: Reply with quote
From memory, my tyres were removed and inspected from the inside for damage before mushroom plugs were vulcanised and fitted from the inside. Smile
Also i passed Stinkwheel as well. Shocked
MCN
PostPosted: 01:31 - 06 Jan 2021    Post subject: Reply with quote
If you have any concern then read the BTMA advice on tyre repairs for road vehicles.
If you think it fails to meet safety margins then don't read the BTMA advice on tyre repairs for road vehicles.
There are a few rules and advice which can be followed.
Too many to spend time explaining here.
PostPosted: 01:42 - 06 Jan 2021    Post subject: Reply with quote
Do I know you or do you fly an aeroplane?
Kawasaki Jimbo
PostPosted: 09:56 - 06 Jan 2021    Post subject: Reply with quote
Ah... in my experience that stage of the repair is a struggle.
droog
PostPosted: 10:29 - 06 Jan 2021    Post subject: Reply with quote
Bhud; The only thing that gave me pause for thought was the fact that the puncture hole was already surprisingly wide (it didn't look that way from the outside), and the bung went in straight, with hardly any exertion involved.
I agree with some of the opinions above.
I would get the tire checked out by a decent tire shop and see if it can be professionally plugged or not - for the reason you state (that the bung went in easily and is presumably not a tight fit).
I've had great success using DIY 'strings' and rubber glue and got up to another 3k miles out of the tire with no deflation or any other problems - but this was on tyres that were holed by nails/screws - which meant a very small, perfectly round entry hole - consequently the string had to be forced through the hole and I got a nice tight fit.
Your observation and gut feeling is telling you that this repair is probably not up to snuff due to the extent of the original damage - so definitely get it checked out.
doggone
PostPosted: 10:39 - 06 Jan 2021    Post subject: Reply with quote
What looks a bit concerning is the missing rubber round the plug which might give coarse road surfaces something to grip and pull it completely out which would not be good.
A more typical nail/screw type hole would be fine with a DIY plug for the life of the tyre most likely, though they can go in at a tricky angle sometimes.
If running about fairly local for the next few weeks you have chance to keep an eye on it and at least get some more wear from the newish tyre.
MCN
PostPosted: 17:22 - 06 Jan 2021    Post subject: Reply with quote
If there is any cord/wire damage it shouldn't be plugged or patched.
The cords/wire can fret the repair and fail suddenly.
Pin holes are fixable, if the plug dreamer tool flies through the hole it's only a temporary patch and the tyre should be replaced ASAP.
Worn tyre puncture more than newer tyres as the thicker tread is more difficult to penetrate.
stevo123
PostPosted: 20:44 - 09 Jan 2021    Post subject: Reply with quote
Get that shit changed. It's bad enough on 2 wheels, don't add to it
Islander
PostPosted: 23:21 - 09 Jan 2021    Post subject: Reply with quote
^^^This.
I've used sticky string repairs and stop 'n go mushroom type repairs. In each case I've repaired and treated it as permanent. I've never had a failure or problem (I've used stop 'n go to plug car tyres a couple of times too). Thumbs Up
Bhud
PostPosted: 16:19 - 10 Jan 2021    Post subject: Reply with quote
Cheers guys. I've bought a new tyre and will be fitting it some time over the next few days, so I don't have to think about it any more.
The last post was made 5 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 109.51 Kb
