Cagiva Mito Oil Spits
Litwos7
PostPosted: 00:27 - 06 Jan 2021    Post subject: Cagiva Mito Oil Spits Reply with quote
Welcome. I have a problem with my mito because, in August, she got a new engine top and connecting rod, the squish is set correctly, the ignition is also good, the shaft seals are also good. The kit includes a mikuni tm 35 carburetor (which was used with this cylinder) italkit v force diaphragm valve and a turbokit carrera gp exhaust. The carburetor is factory set, I tried to adjust the mixture screw to zero effect, I reduced the main jet from 310 generations to 270 zero effect, it still spits oil on the back of the motorcycle and, worst of all, the tire and brake. Due to such a low degree of mixture I have rubbed the motorcycle ... I make the oil mixture myself 1:50 oils which were Motul 800 710 ipone samourai and castrol power 1 on each the same, pb95 fuel. I don't have enough strength anymore, does anyone know what the problem may be? Best regards and have a nice evening: D
oilyrag
PostPosted: 00:40 - 06 Jan 2021    Post subject: Reply with quote
Love it. Do you have any videos of riding it? Can you rotate the exhaust to point further away from the bike? Or use a different exhaust? Maybe it's too short.
Litwos7
PostPosted: 00:48 - 06 Jan 2021    Post subject: Reply with quote
Well i got videos with riding without any changes from july and the soundcheck on turbokit, I can't rotate this exhaust... For me its not even for this motorcycle... Because if I mount on bottom mounting secondary near passager foot peg in not fiting and vice versa. Now I searhing for help and new cylinder barrel... The piston ended really bad ( It has a hole So). Tommorow I post some videos
With the exhaust i writed to turbokit 3 times no response... on original exhaust there is no problem still spits oil but only license plate, On the march I will try to re-weld and rotate the exaust mor "outside" if there will be not response from turbokit.
oilyrag
PostPosted: 01:30 - 06 Jan 2021    Post subject: Reply with quote
I don't know much about 2 strokes so I can't really help with the technical part. Hopefully there's a 2 stroke guru on here. I'll be interested in your project. Good luck with it
Litwos7
PostPosted: 09:22 - 06 Jan 2021    Post subject: Mito movies Reply with quote
Hey Everyone I send you some video with Mito Very Happy Have a beatiful Day
https://drive.google.com/drive/folders/1CpgkwOhdNdf_UkRGtobjGZwSNEerq74q?usp=sharing
Those films are with 350 min jet in carb XD
https://www.youtube.com/channel/UCsA8Okfme05Hfc_JFjIujkA
Those with dellorto 28 and stock exhaust
PostPosted: 09:46 - 06 Jan 2021    Post subject: Re: Mito movies Reply with quote
You can't ruin a 2 stroke video with music. That is heresy.
Have you considered using the original end can...
Litwos7
PostPosted: 10:34 - 06 Jan 2021    Post subject: Reply with quote
If I choose the original end cam I need to change all rear of the exhaust from the diffuser beacuse turbokit exhaust don't have any posibility to mount end can, wool in turbokit was also replaced but I got a question because in my book muffler is showed in different way than I done to my exhaust, I done it that way because it jus fitted into stinger with just some help. Is it good or not ? Pictures in attachment
Easy-X
PostPosted: 12:05 - 06 Jan 2021    Post subject: Reply with quote
I'd have to say you generally want to direct a 2-stroke exhaust output as far away from the back wheel as possible - high up and far back. Is this an all round thing or just on choke?
Step 1 I would say is get the jetting right for performance. On an old dirt bike I'd just play about with as I went along but this thing really would benefit from a dyno tune.
Step 2 is look at the exhaust design/placement but obviously that feeds back into Step 1, doh! Getting hold of a stock exhaust setup for reference would definitely be worth considering.
PostPosted: 12:56 - 06 Jan 2021    Post subject: Reply with quote
I...
*breathe*
I...
*Be polite Mark, be polite*
You are aware that two strokes rely on the shape of their exhaust to scavenge gases and to keep fuel inside the cylinder, right? The exact shape and volume of the exhaust is absolutely critical to the functioning of the engine? You also are aware that turboing a two stroke is fairly pointless because of the way the ports open and close, all you're doing is pressurising the crankcase rather than providing any extra compressed air into the cylinder. The movement of the piston is what opens the inlet and exhaust ports, and if you turbo the engine, all that will happen is the excess pressure will escape via the exhaust and transfer ports, pumping fresh charge out. You'll also probably blow the crank seals because of extra pressurised air going through the transfers.
You clearly have some technical ability, but absolutely no knowledge of two strokes. Two strokes spit out oil. That's why their exhausts tend to push gases and liquids away from the rear wheel. Modern 'GP' style exhausts are spectacularly inappropriate for engine performance and safety reasons. It probably is possible to build a turbo two stroke, but it won't be bolt on and probably not a single cylinder. The engine would need to be designed from scratch with the turbocharger in mind.
A100man
PostPosted: 13:04 - 06 Jan 2021    Post subject: Reply with quote
MarJay wrote:
I...
*breathe*
I...
I think the OP is smarter than that. 'Turbokit' is just the name of his expansion chamber style exhaust..
https://moto125.pl/p/195/1500/sportowy-wydech-turbokit-gp-carrera-2t-125cm3-tuning-mechaniczny-cagiva-mito-sp525-125-cagiva.html
Lucky you exercised your restraint.
A100man
PostPosted: 13:06 - 06 Jan 2021    Post subject: Reply with quote
Which book is that please?
PostPosted: 14:07 - 06 Jan 2021    Post subject: Reply with quote
It's a dumb name for an exhaust, and it looks like a very poor design.
Easy-X
PostPosted: 15:12 - 06 Jan 2021    Post subject: Reply with quote
Just to kick off a great Internet argument you can and should turbo a 2-stroke...
...if it's a snowmobile you're using at altitude to compensate for the lower air pressure Wink
Robby
Dirty Old Man
PostPosted: 21:54 - 06 Jan 2021    Post subject: Reply with quote
Two strokes spit oil. Either fit a different exhaust, or get used to cleaning it.
Litwos7
PostPosted: 22:26 - 06 Jan 2021    Post subject: Reply with quote
Two stroke performance tuning second edition A. Graham Bell. (pic in attachment)
Yes turbokit is name of exhaust I should write this firstly, on stock exhaust she still spits oil but only on back of lincense plate. I know that 2 strokes are spiting oil but this is dangerous because of oil on tire :/
Tommorow I'll take the exhaust to the welder and see what response I get.
c_dug
PostPosted: 10:00 - 07 Jan 2021    Post subject: Reply with quote
I agree with others, I've owned a few 2 strokes and they have all spat oil out of the exhaust - it's part of the charm.
I'll admit, your exhaust looks kind of cool, but it is also clearly designed for form over function. The exhaust won't look half as cool when you come off of the bike due to oil all over your back tyre!
A100man
PostPosted: 11:54 - 07 Jan 2021    Post subject: Reply with quote
Thanks.
I wonder if the final tail-piece can be 'slash-cut' and the end cap modified to suit.
Riejufixing
PostPosted: 12:25 - 07 Jan 2021    Post subject: Re: Cagiva Mito Oil Spits Reply with quote
Litwos7 wrote:
Welcome. I have a problem with my mito ( 8< ) spits oil on the back of the motorcycle and, worst of all, the tire and brake.
You won't get it so that it burns all the oil, leaving you with an exaust smelling of violets. It's a total loss lubrication system, and you can assume that whatever oil you put into the exhaust will come out of the end (or any joints...), there's not much you can do about that. Don't reduce the ratio to try and cure the problem, use what's recommended.
The problem is your exhaust pipe. It's too short/angled so it deposits oily smuts and droplets all over the back end. Note, most of the function of your exhaust system is in the various dimensions of the belly of the expansion chamber, and between the exhaust port opening and the start of the stinger (=outlet). Perhaps you have something that's more of a fashion accessory than a functional item? The only way to tell would be to test it! You could probably extend or shroud the outlet without much problem, but it might not look so fashionable.
Riejufixing
PostPosted: 12:33 - 07 Jan 2021    Post subject: Reply with quote
It looks as though the baffle cone/outlet could be cut through, the outlet rotated, then welded back, and the supporting lug repositioned. I do wonder, though, what (if any) advantage this system has over "stock". Maybe, maybe not. Measurement/trial is the only way to know.
GSTEEL32
PostPosted: 12:57 - 07 Jan 2021    Post subject: Reply with quote
Given how critical exhaust design is on these types of 2 strokes, I'd be massively in favor of returning to stock, or an established JM or Arrow complete unit.
I'm not an expert in 2 strokes, but I think there is a reason that the later 125 versions, all had silencers well clear of the rear drum/disk etc.
My own 2 strokes (125's and 250's) tend to foul the bottom corner of the license plate, rather than anything else on the bike...
Robby
Dirty Old Man
PostPosted: 15:07 - 07 Jan 2021    Post subject: Reply with quote
Of course, there is the possibility to reduce the amount of oil getting spat out, by having the oiling an fuelling set up properly.
In one of the posts you mentioned the mixture screw. This is red flag, the mixture screw is only for adjusting the air/fuel ratio at tickover. Everything under power is set up by correctly adjusting the jet sizes, needle height, and (to a degree) float height.
My preference would also be to use the autolube system rather than pre-mix, unless the autolube has a particular reputation for failure on this model.
It sounds like the engine is extensively modified, which means the fuelling needs to be set up properly. The only way to get this right is to get the engine on a dyno and air/fuel ratio monitoring and fiddle about with the carb settings until its right.
Litwos7
PostPosted: 17:29 - 07 Jan 2021    Post subject: Reply with quote
Well the welder said me the same thing : cut rotate weld and this we are going to do and see what it will change.
But guys I'll repeat my question about muffler, is it good how its done by myself or change to it what is showed in book (attachment) ? My regrats Very Happy
RhynoCZ
PostPosted: 17:48 - 07 Jan 2021    Post subject: Reply with quote
Buy this type of silencer and your troubles will go away.
NOT A SPAM: https://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2334524.m570.l1313&_nkw=cagiva+mito+exhaust+arrow&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=cagiva+mito+exhaust
https://www.motops.cz/photos/original/248155-arrow-kevlar-approved-silencer-arrow-kit-cagiva-mito-125-1994-2006.jpg
EDIT: Also, what Robby says. Two strokes spit oil. There's also a lot of turbulent air behind you, so some of the oil also ends up on your back/jacket.
Riejufixing
PostPosted: 18:01 - 07 Jan 2021    Post subject: Reply with quote
It'll look a little different, though, depending on how much you rotate the outlet. It might not need much rotation for the spatter of grot to miss the back of your bike. Hard to say how much.
EDIT: Merely rotating the pipe should not affect anything. I notr that the supporting lug is not used!
So you have continued the outlet (stinger) in perforated tube, and wrapped that in rockwool or something, rather than ofsetting the "silencer tube" from the exhaust end of the the outlet? I can't see that making much difference in real life. You use this machine on the road?
Edit again: Is this exhaust exactly as indicated by a previous poster, or something you've made up yourself, or have you modified a "bought" version (which, how)?
Litwos7
PostPosted: 19:21 - 07 Jan 2021    Post subject: Reply with quote
Edit again: Is this exhaust exactly as indicated by a previous poster, or something you've made up yourself, or have you modified a "bought" version (which, how)?[/quote]
This exhaust is like it was going out from factory I bought it new and only changed wool (athena) I use it on road. I think that the book option will cause swirls in the system and the accumulation of oil "in the silencer - wool, to a greater extent), whereas in the case of which I used gases they have a simple way to go. Exhaust is just like on photos.
The last post was made 5 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 136.96 Kb
