Minarelli am6 flywheel removal?
BenR
PostPosted: 12:39 - 06 Jan 2021    Post subject: Minarelli am6 flywheel removal? Reply with quote
Ok it's not a genuine minarelli I think it's a clone from a generic trigger but before Xmas I bought a flywheel puller to remove said flywheel. I did it up but as I started to do the bolt up to get the flywheel off it's stripped the thread inside it's also made a mess of the crank pin. Is there anyway of getting the flywheel out without a puller? Cheers in advance.
oilyrag
PostPosted: 00:09 - 07 Jan 2021    Post subject: Reply with quote
If the crankshaft has a tapered fit it can take a serious amount of force to get a flywheel off. Most flywheels have threaded holes that allow removal with a puller like this. You just have to make sure you get one that fits your flywheel https://yambits.co.uk/images/tls030.jpg?osCsid=7nrm3qea0u28peg315cu597ep3
Or you can make one with some steel plate and a few bolts
https://i.ytimg.com/vi/vdUW6EJtIyc/maxresdefault.jpg
bikenut
PostPosted: 15:01 - 09 Jan 2021    Post subject: Post a picture of the mess Reply with quote
Post a picture of the mess....can't access the picture of the flywheel puller you used, bet it was a 3 leg variety ?
Always use the proper flywheel puller...else distort the flywheel/wreck something like delicate stator windings underneath, unless of course it's an outsider stator...even then use the proper puller.....
nuts about bikes
Riejufixing
PostPosted: 15:21 - 09 Jan 2021    Post subject: Re: Post a picture of the mess Reply with quote
As above. Post picture of flywheel, damage, and puller.
It sounds as though you have a puller with the wrong thread, or did not screw it in far enough.
BenR
PostPosted: 23:51 - 09 Jan 2021    Post subject: Re: Post a picture of the mess Reply with quote
This is the one I bought https://www.ebay.co.uk/itm/Minarelli-AM6-flywheel-puller-magneto-extractor-50cc-19-x-1-r-h-thread/302854627529?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2648&redirect=mobile
BenR
PostPosted: 23:53 - 09 Jan 2021    Post subject: Re: Post a picture of the mess Reply with quote
Hi thanks for the comment however I'm not totally new to this. When I did it up it seemed to be tight.
bikenut
PostPosted: 10:20 - 10 Jan 2021    Post subject: Puller Reply with quote
Your picture does not open so no idea what the puller you bought looks like.
Post a picture of it please as well as the mess your left with, flywheel and crank wise.
nuts about bikes
Riejufixing
PostPosted: 10:56 - 10 Jan 2021    Post subject: Re: Post a picture of the mess Reply with quote
It's hard to see what can go wrong, then. Either it wasn't done up properly, or the thread size was wrong, or the flywheel magneto centre was knackered, or the tool was knckered when you bought it, or one or both things were made of cream cheese.
What damage was done to the crankshaft nose (end)? I do hope you have not somehow damaged the crank pin, that's the bit that the con rod bears on!
Photos would be useful to work out what's happened and what to do. The used (damaged?) tool, the flywheel and (damaged?) threads, the end of the crankshaft.
Riejufixing
PostPosted: 10:59 - 10 Jan 2021    Post subject: Re: Puller Reply with quote
Seems like an ordinary single-ended puller. Edit: Yes, pictures of damage needed (reply/add attachment or upload somewhere accessible).
BenR
PostPosted: 11:05 - 10 Jan 2021    Post subject: Reply with quote
All I can say is I did the puller up tight & when I started doing the bolt up the threads just gave way the puller is still intact it's just the threads on the flywheel itself. I'm not bothered about the crank as I'll be fitting a bigger one anyway. I'll try to get a photo later.
Riejufixing
PostPosted: 11:32 - 10 Jan 2021    Post subject: Reply with quote
Pics would be really interesting. At a *guess*, the inside of the puller fouled something, making it feel as if it was tight, but was only done up a thread or two. Still, that doesn't explain a damaged crank nose. Pics! Good luck with it, by the way.
BenR
PostPosted: 14:28 - 11 Jan 2021    Post subject: Reply with quote
Doesn't really show much but here's a photo of the flywheel.
https://i.postimg.cc/25cFW9sy/20210110-134818-1.jpg
I've looked at other pullers & on some of them the bolt has a little nipple on the end which I'm assuming is to sit in the end of the crank? The one I bought doesn't have this it's just a normal bolt. Anyone got any ideas how can remove the flywheel now? Cheers.
Riejufixing
PostPosted: 15:17 - 11 Jan 2021    Post subject: Reply with quote
Can't see the state of the threads inside, nor of the puller itself. An end-on pic of the flywheel is not all that useful. Can you get any other pics (side-on internal flywheel threads, tool external threads, tool bolt end)?
Perhaps a 2-leg puller through the holes? Tighten it up until there's some force on the thing, then give the centre puller bolt a sharp tap with a lightish hammer.
bikenut
PostPosted: 15:54 - 11 Jan 2021    Post subject: Flywheel Reply with quote
I assume the flywheel hub had a fine LEFT HAND THREAD ?
You say you are not new to this sort of stuff so know what is meant by a left hand thread ?
Ever attended to a loose pedal or fitted a new one ( you first have to get the old one off ! ) On a pedal bike left hand side ?
Your avatar suggests..........?
You did remove the washer/washers that where under the flywheel nut before you screwed in the extractor, similar to the one in riejufixing's picture ?
Which way did you screw the puller in, clockwise ?
By the way, why do you want to remove the flywheel ?
nuts about bikes
Easy-X
PostPosted: 16:08 - 11 Jan 2021    Post subject: Reply with quote
Much as I try and avoid tooting my own trumpet (back problems) if you scroll half way down pg11 of my DT thread I take the flywheel off - pics, explanations... standard stuff really.
https://www.bikechatforums.com/viewtopic.php?t=328912&start=225
bikenut
PostPosted: 16:12 - 11 Jan 2021    Post subject: Slide hammer Reply with quote
You know what a slide hammer is ? DONT ! DONT ! DONT !
As asked post a pic of the tool used, the mess on the threads of the flywheel hub and a better pic of the end of the crank please.
nuts about bikes
BenR
PostPosted: 22:46 - 11 Jan 2021    Post subject: Re: Flywheel Reply with quote
https://i.postimg.cc/YqT6fyqy/20210110-134831.jpg
Hi no it's a righthand thread.
Yep.
Yep.
So I can get to the bolts underneath the stator plate so I can get the cases apart.
Riejufixing
PostPosted: 23:14 - 11 Jan 2021    Post subject: Reply with quote
Well, you do not seem to have damaged your tool (!) during the procedure, and M19 metric fine (assuming it is as marked) seems to be correct.
So, what could it be?
Again, perhaps the inner of the tool fouls the crank nose before screwing in far enough. Are there marks to indicate this is happening? Again, perhaps, there was some sort of grot in the flywheel's threads. Is this the case?
How many threads (or is it all) in the flywheel are damaged/missing? A careful close-up with good light might illuminate (!) the problem. It's difficult diagnosing over the 'net.
BenR
PostPosted: 23:54 - 11 Jan 2021    Post subject: Reply with quote
Hi thanks for the comment I think the flywheel is made of cheese personally, crappy Chinese metal? I'll try & find a twin prong puller when I next get paid give that a go. Thanks for the input everyone. Thumbs Up
bikenut
PostPosted: 09:01 - 12 Jan 2021    Post subject: Stuck Reply with quote
Hi Ben,
So your in the shit now, but how do you get out ?
Your pictures are opening today, and it looks as if the flywheel extractor was screwed into the flywheel deep enough....
The engine is out of the bike.
The starter ring gear is welded to the flywheel.
If you look thru the larger flywheel holes, how thick is the metal that makes the flywheel "outer", 6mm or so ?
A two leg puller is a no-no, so is a three, even six leg. Why ?
The flywheel is riveted to the flywheel hub, which has the internal thread for a puller.
The thinish flywheel "outer" is not designed to be "pulled", it will just distort especially on a stuburn "client".
Can the hub internal threads be cleaned up so the oe puller can be screwed in for an other go ?
The hubs can be stuburn sometimes being well and truelly "locked" on the taper.
If you can screw in the puller for an other go, think about warming up the hub so it expands slightly to help releasing the taper.
When the puller is in and loaded, a sharp tap on the bolt can help as well, but Remember that pushing the flywheel towards the engine will "load" the big end crank pin etc..
So, threads goosed, what to do ?
Get a spare pair of hands, maybe some levers, a soft thick pad for the engine to "fall onto", a brass drift of about 17mm and a selection of hammers, with about a 17mm face.
The spare pair of hands holds the engine above the thick pad by the flywheel. Kettle of hot water, pour over hub so no hot water goes onto stator.
With the engine raised above the protective pad held by the flywheel, just by the flywheel, only by the flywheel, flywheel held, brass drift in contact with crank, a sharp tap with hammer, and with a good prey, god will allow the taper to release.
Think about this for a while..
Brass drift and the right hammer, you want to shock the taper, not rivet over the end of the crank.
Heat expands hub a bit, shock and gravity act like a slide hammer ( think about that one ) , taper releases and engine drops 2 inches onto soft protective pad.
If it doesn't work first time, go have a pannad.
Try again.
May be a heavier hammer....start light.....
If it doesn't come off, go for a pannad and try again.
Let things ( including you )cool down.
Don't forget, a "please god......" Can only help. When it does come off, a thank you God is a good thing........
Don't rush, take your time.
nuts about bikes
BenR
PostPosted: 11:10 - 12 Jan 2021    Post subject: Re: Stuck Reply with quote
Not a "for Christs sake come on!"? Laughing
Thanks for the assistance I'll have to have a think about the next plan of attack. The only problem with your hanging method (good idea btw) is the engine weighs about the same as a rizla paper so doesn't really have the weight to seperate itself also there's very little room/metal to tap with anything as the flywheel butts right up against the cases. I'm thinking sticking the bottom end in a vice & see if I've got an attachment for my slide hammer that I could use as a drift. As previously stated I'm not too bothered about either the crank or the flywheel as these will be getting replaced with uprated aftermarket items but I don't want to damage the cases themselves. Cheers.
bikenut
PostPosted: 11:56 - 12 Jan 2021    Post subject: No Reply with quote
Vice, slide hammer, no, no, no ,no, no ffs no !!!!!
Get someone to hold the engine up by the FLYWHEEL and use a brass, ally or even a hard hard wood drift ( brass best ) and hammer, heat hub then try hitting drift to shock locked taper free.
If it don't work, walk away and have a pannad ( cuppa ). Then when calm and cool, try again with a slightly heavier hammer.
Using this method you employ gravity, and if everything "in line" all the hammer kinetics go thru crank flywheel stub, a more efficient "hit".
If your scrapping flywheel and crank, your last last last option is a drastic drastic drastic one, get the grinder out.
Saying oh come off you zdcnyitasmd! Is defeatist.
nuts about bikes
Riejufixing
PostPosted: 12:10 - 12 Jan 2021    Post subject: Re: Stuck Reply with quote
The two larger holes in the rotor look good for a 2-leg puller. They are hard by the centre, and the puller's feet would bear on it. Depending on the rivets on the inside of the rotor, it should be possible to use either the puller's legs, if the feet are suitable, or a pair of bolts "upside down" in the puller, with their (shaped?) heads secured or jammed sideways in the holes.
Riejufixing
PostPosted: 12:20 - 12 Jan 2021    Post subject: Re: Stuck Reply with quote
If you're not too bothered about the flywheel, you could try geting some gas on it if it needs it while you have a puller attached and with some strain on it, and then give the puller centre bolt a sharp tap with a steel hammer to see if it parts.
The big problem with your slide hammer idea is where the force goes. When you have a strain on a puller, it's "contained" within the components (crank, flywheel); the puller outer or legs pulls on the rotor, and the puller centre bolt pushes on the crank nose, and that's it. If you attach a slide hammer to the rotor, yes, it will be applying force to the rotor, but that force is not contained locally - imagine that the crank and rotor are a solid one-piece component, which they effectively are right now - when your slide hammer is used, it will be trying to pull the whole crank out through the side of the cases, which if you care about your crankcase is not what you are wanting!
Have all the threads been pulled out of the rotor?
bikenut
PostPosted: 12:26 - 12 Jan 2021    Post subject: Statir Reply with quote
Will you be changing/scrapping the stator as well ?
Some mspecially made "T" bolt that slip into the holes may work, but only 2 would encourage "tip"...
Try the drift and gravity method first...if it don't work the first time, walk away, try again, and again.
If you can't grip the flywheel, use large diameter worm drive clips ( use small diameter clips joined together if no large clip available ) around the flywheel periphary, you could even use these to clamp a "handle or two" between flywheel and clip bands.
This flywheel is well and truelly on tight.......tapers well and truelly locked, remember the days of cone clutches ? Anyone ? Apart from me that is.....
nuts about bikes
The last post was made 5 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.19 - MySQL Queries: 15 - Page Size: 134.94 Kb
