Wiring Problem with Sinnis 125
simon364
PostPosted: 18:17 - 10 Jan 2021    Post subject: Wiring Problem with Sinnis 125 Reply with quote
I have come into possession of a 2015 Sinnis 125.
I was told the indicators did not flash and just needed a relay (previous owner put new indicators on). I have fitted a replay however when the indicators turn on they just come on as a solid orange light.
The rear light only works on P setting and numberplate light only comes on when applying front brake leaver, which will also illuminate the display.
It looks like the kiddy run a supply from battery to indicators and only indicator wires are freely hanging and there are lots of waggo connectors everywhere.
I am really confused and lost on how I can try and get this working as I have tried connecting back up to original loom and also reconnected the side stand cables.
Any help and advice please apart from burn the bike.
Thanks
oilyrag
PostPosted: 19:07 - 10 Jan 2021    Post subject: Reply with quote
What model is it?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:10 - 10 Jan 2021    Post subject: Reply with quote
The indicators problem is probably because they fitted led indicators. They don't work with a standard relay.
Triumph Sprint ST 1050
Easy-X
PostPosted: 21:25 - 10 Jan 2021    Post subject: Reply with quote
Normally the cheap relays flash at odd speeds when paired with LEDs. From the OP it sounds like it's completely mis-wired Sad Wiring diagram + multimeter job.
ThatDippyTwat
PostPosted: 07:01 - 11 Jan 2021    Post subject: Reply with quote
If it's an adjustable "relay", you can easily turn them on constantly, or not at all, and actually need to for the "flowing" type indicators. Takes a few seconds to eliminate the relay having an adjustment screw and turning it midway to see if that changes anything.
The last post was made 5 years, 243 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 44.05 Kb
