| Chazzman_bm |
 Chazzman_bm Derestricted Danger
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 23:05 - 11 Jan 2021 Post subject: |
You might have some luck with something like Boyer Bransden, or Pazon ignitions. Best to pop them an email.
https://www.boyerbransden.com/
https://www.pazon.com/ignition-system/Altair-universal-12v-6v ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Easy-X |
 Easy-X Super Spammer
 Posted: 23:54 - 11 Jan 2021 Post subject: |
Funny, 6V to 12V conversions as kits are quite common on the ol' DT but then magnetos are much easier to work with. The consensus on the Interwebs is find a 12V stator and associated electronics from a similar/newer model. What that model is I couldn't say  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stinkwheel |
| Chazzman_bm |
| oilyrag |
 oilyrag Nova Slayer
| Easy-X |
 Posted: 15:27 - 12 Jan 2021 Post subject: |
| oilyrag wrote: | Does the bike run with the setup that it has now? If you don't have any knowledge of electrics I would start by trying to understand the system that it's got now before trying to change all of it. |
A 12V setup does seem to make sense but something like "I want to charge my phone!" is not a good enough reason. There's something to be said for preserving a bike in its original state, necessity > whim
Points vs electronic ignition. Again, what do you want out of this, are you having problems that you believe an electronic might solve?
RPM pickup can be done by wrapping a wire around the spark plug lead and counting the pulses. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Chazzman_bm |
 Posted: 21:01 - 12 Jan 2021 Post subject: |
No the bike doesn't run; it's been in pieces for the better part of a decade. I am reviving an old hobby of building classic custom motorcycles and very little of the bike is still stock. Basically, I want to modernise the bike technically but still keep the old school look (sort of).
I plan on running LED lights and indicators with "classic" digital gauges so a decent 12v system is a must. The original wiring loom and electrics are shot anyway so I'll be making the loom from scratch and replacing whatever needs to be replaced.
I know what I want to accomplish, it's the how to get there that I am working on.  |
| Easy-X |
 Posted: 22:06 - 12 Jan 2021 Post subject: |
Ah, fair enough.
Well you know what you need for 12V, a stator that fits and then conjure up all the associated bits like reg/rec, indicator relay, switch gear, etc.
The electronic ignition though... I suspect you'll need a plate with some optical or inductive pickup to sit in place of the gubbins where the points used to be. You can then feed that onto a CDI. Sounds expensive given Google mostly showing Americans making such things "off the peg."
By all means crack on with the 12V upgrade but you might just want to get the original ignition system going for now. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| stinkwheel |
| steve the grease |
 steve the grease Crazy Courier
| Chazzman_bm |
 Posted: 15:45 - 14 Jan 2021 Post subject: |
| stinkwheel wrote: | Mind you, if I had a CB100 the very first thing I'd change is the front brake. |
That's already been taken care of my man. That was indeed one of the first things to go. I've had a two piston hydraulic system fabricated for it. The new setup is more than enough to cope with the engine moifications that have been done. There was a time I had more money than sense and had the engine capacity maxed out to it's limits, and fully built by a reputable engineering shop. Who knows, it might even be faster than my wife's KTM Duke 125
| Easy-X wrote: | Well you know what you need for 12V, a stator that fits and then conjure up all the associated bits like reg/rec, indicator relay, switch gear, etc. |
| stinkwheel wrote: | You do know 6v switchgear and wiring is rated for double the current load of 12 stuff (assuming the same power draw)?  |
Let's just assume I know nothing because it's not far from the truth. It's a labour of love though so I am fully empbracing the challenge.
| steve the grease wrote: | The CB100 shares it's heritage with the XL185 which had a cdi ignition, the points box/ cdi is a straight swap.
However the electrics were still 6v , but it's a start - |
I did find a couple of posts talking about the XL185 and XR200 motors having electronic ignition but I am not sure if every one of them had EI or only models made after a certain year.
The motor is a bit of a frankenstein now. The bottom end has been modified to take a much larger crank, the bore has been significantly increased to accept a 65.5mm Wiseco piston to mate with a 2-port head from an XL185 or XR200. |
| stinkwheel |
| Chazzman_bm |
| oilyrag |
 oilyrag Nova Slayer
The last post was made 5 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
