how to remove headlight cover on a Suzuki Scooter FX50 1998
wineprovider
PostPosted: 13:35 - 12 Jan 2021    Post subject: how to remove headlight cover on a Suzuki Scooter FX50 1998 Reply with quote
I'm old but stuck. Just started a barn find restoration and am having difficulty understanding the manual. It has instructions but they are not clear.
The headlight cover has one screw and some other fixture holding the top 2 corners.
Can anyone help please?
A DAY WITHOUT WINE IS A DAY WITHOUT SUNSHINE
oilyrag
PostPosted: 19:50 - 12 Jan 2021    Post subject: Reply with quote
Are you sure it's a Suzuki FX50? Have a look here. If you click on the correct model you will see a diagram showing the head light unit.
https://www.cmsnl.com/suzuki-scooter-and-step-through_model33742/
wineprovider
PostPosted: 04:05 - 13 Jan 2021    Post subject: Reply with quote
Thank you for your reply.
Since my posting I had my suspicions that the model name was incorrect so I found out from the DVLA that it is an AY but with you link I also found out that it`s full description is an AY50W50 .
I now have a starting point and have ordered the Haines workshop manual.
Once again sincere thanks and please stay safe
oilyrag
PostPosted: 19:14 - 13 Jan 2021    Post subject: Reply with quote
No problem. There's the Suzuki service manual https://www.manualslib.com/manual/1082902/Suzuki-Ay50.html
wineprovider
PostPosted: 19:30 - 13 Jan 2021    Post subject: Reply with quote
Grateful Thanks.
Just gotta figure out how to start it.
IS THERE A DEAD SWITCH SOMEWHERE?
Thanks again,
wineprovider
WD Forte
PostPosted: 19:35 - 13 Jan 2021    Post subject: Reply with quote
No idea what the scoot is but on most/many
you have to pull at least one brake lever in prior to pressing the
button/kicking them over to start the motor
bikers smell of wee
oilyrag
PostPosted: 19:41 - 13 Jan 2021    Post subject: Reply with quote
Yes that's it. Turn the key on, pull the front or rear brake lever and press the start button. That should turn the engine over.
wineprovider
PostPosted: 09:06 - 14 Jan 2021    Post subject: Reply with quote
The scoot is a Suzuki Katana AY50W.
I followed the advice and Eureka it turned over.
I didn`t try for long as I want to change all fluids and spark plug.
My next difficulty is removing the panels for accrss and cleaning and painting or covering but the removal instructions are very difficult to follow/
Thanks to all...................you are brilliant
WD Forte
PostPosted: 15:18 - 14 Jan 2021    Post subject: Reply with quote
So many scoots buzzing about nowdays so still means nothing to me
I do work on a local guys delivery scoots from time to time and
often had to remove the plastics at times.
Around the bars there are usually screws but some of the plastics are also clipped together as well as screwed.
most screws are accessed from behind or underneath and in the black plastic areas not the shiny painted stuff.
Many screws are recessed and some may have plugs covering them
which needs levering out to get the heads
To get at panels around the engine area, I've often had to start by lifting the seat and unbolting/removing the seat and bucket assembly first
bikers smell of wee
wineprovider
PostPosted: 15:47 - 14 Jan 2021    Post subject: Reply with quote
You are so correct
The trouble is I can`t see them.
The illustrations are not clever but I`ll keep trying.
Thanks for the reply.
Kind regards,
wineprovider
WD Forte
PostPosted: 19:21 - 14 Jan 2021    Post subject: Reply with quote
Pages 91 for panels
and pages 110-111 for bar covers in the link
Oilyrag posted seem to cover it.
looks pretty straightforward to me and not unlike most
scoots I've worked on
Be aware that some panels may have 'hooks and eyes'
where they fit together as well as screws
P91
https://www.manualslib.com/manual/1082902/Suzuki-Ay50.html?page=91#manual
P110
https://www.manualslib.com/manual/1082902/Suzuki-Ay50.html?page=110#manual
P111
https://www.manualslib.com/manual/1082902/Suzuki-Ay50.html?page=111#manual
bikers smell of wee
oilyrag
PostPosted: 23:07 - 14 Jan 2021    Post subject: Reply with quote
Are you sure that the engine is in good running condition? It's a 2 stroke I'd make sure the engine ran ok before investing time and money in the cosmetic work.
wineprovider
PostPosted: 06:21 - 15 Jan 2021    Post subject: Reply with quote
It`s a bit cramped but I managed to remove the spark plug and clean it which produced a good spark.
I am now in the process of draining the 2 stroke oil and petrol which I will refresh and then see if it starts.
In the occasion of it not starting I shall return here and ask for what I can check before any more expense is incurred.
I`ve checked the MOT history and the last time was 04/2014 this is why I`m changing the fluids as I`m sure they will be stale.
Thank you for your input.
Kind regards,
wineprovider
wineprovider
PostPosted: 15:50 - 24 Feb 2021    Post subject: 1998 Suzuki Katana Scooter AY50W starting help.....UPDATE Reply with quote
I have replaced the carb after cleaning and squirted fuel into the chamber and eureka it fired but soon died and would not attempt a start again.
Is there an easy way to find out if fuel is reaching the carb?
I think there maybe one or more components faulty......ANY IDEAS?
Nobby the Bastard
Harley Gaydar
PostPosted: 15:55 - 24 Feb 2021    Post subject: Reply with quote
Have you turned on the fuel?
Triumph Sprint ST 1050
WD Forte
PostPosted: 00:09 - 25 Feb 2021    Post subject: Reply with quote
https://static-data2.manualslib.com//pdf5/109/10830/1082902-suzuki/images/ay50_71_bg.jpg
bikers smell of wee
wineprovider
PostPosted: 12:54 - 25 Feb 2021    Post subject: Reply with quote
Is there a way of testing the fuel valve?
I don`t think there is an on/off petrol valve/switch.
If an administrator can see this .....I'm not getting notifications of replies
Be safe all
jeffyjeff
PostPosted: 16:11 - 26 Feb 2021    Post subject: Reply with quote
1. Remove the fuel line from the carburetor. Direct it into a container.
2. Key switch on. Hit the starter button.
3. Observe fuel flow into container as the engine is cranking.
4. Reconnect fuel line to the carburetor.
Engine vacuum must be sufficient to operate the fuel valve.
If the fuel valve does not work, check for a vacuum leak. Check for a fuel line restriction. You can also use a vacuum pump (such as a Mightyvac brake bleeder pump) to apply vacuum to the fuel valve. Bottom line; if engine vacuum cannot open the fuel valve, the engine won't run.
wineprovider
PostPosted: 16:14 - 26 Feb 2021    Post subject: Reply with quote
Not feeling to good today so will follow your instructions tomorrow and get back.
Very grateful thanks,
Martyn
Nobby the Bastard
Harley Gaydar
PostPosted: 17:41 - 26 Feb 2021    Post subject: Reply with quote
Probably some sort of font issue.
wineprovider
PostPosted: 16:31 - 30 May 2021    Post subject: Panel replacement Reply with quote
Has anyone got a link to a guide of how to replace all the panels.
I have repaired some damage and its now time to reassemble but I can`t remember where everything goes.
I do hope someone can help.
Kindest regards,
Martyn
WD Forte
PostPosted: 17:45 - 30 May 2021    Post subject: Reply with quote
https://external-content.duckduckgo.com/iu/?u=https%3A%2F%2Ftse2.mm.bing.net%2Fth%3Fid%3DOIP.oOZVG_c0Xouow7QA-SEiPQHaF5%26pid%3DApi&f=1
bikers smell of wee
wineprovider
PostPosted: 18:08 - 30 May 2021    Post subject: Funny Reply with quote
A GREAT HELP
The last post was made 5 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 117.11 Kb
