H100s seat help
Gruttz
PostPosted: 11:00 - 22 Jan 2021    Post subject: H100s seat help Reply with quote
Hey all,
I am helping a friend get an old 1985 H100s up and running.
The seat is in a real bad way, the cover definitely needs replaced.
The only problem is that the seat pan is really badly corroded, so there is no way to attach the cover.
We have been looking to buy a seat, but cannot find a one anywhere.
Does anybody know of any alternative seats that would fit this bike?
Or any other advice to get this sorted is much appreciated.
Thanks.
blurredman
PostPosted: 11:55 - 22 Jan 2021    Post subject: Reply with quote
That model looks very similar to the Brazil CG125's.. Could a seat from that maybe fit?
PostPosted: 13:50 - 22 Jan 2021    Post subject: Reply with quote
I've seen people fibreglass an old seat pan before today.
A100man
PostPosted: 14:19 - 22 Jan 2021    Post subject: Reply with quote
Yes Fibreglass - always good on Viva wings too back in the day. Lets have pic so we can assess the damage.
PostPosted: 15:24 - 22 Jan 2021    Post subject: Reply with quote
You could do a layup mould and make a new seat base out of carbon fibre...
steve the grease
PostPosted: 18:04 - 22 Jan 2021    Post subject: Reply with quote
Fibre glass and then these things which you poprivet around bthe seat base edge. They work , but watch your fingers: https://www.ebay.co.uk/itm/CLASSIC-CAR-UPHOLSTERY-AID-FORD-AUSTIN-MORRIS-VW-TRIUMPH-JAG-BMW/174337203783?hash=item28974e9e47:g:nKUAAOxyaTxRJ44I
PostPosted: 19:07 - 22 Jan 2021    Post subject: Reply with quote
Incidentally, if you decide to use fibreglass, invest in some bias weave cloth and epoxy resin instead of that nasty chopped strand and polyester resin shite they use for patching up cars. It goes on neater and finishes up stronger.
Easy-X
PostPosted: 20:35 - 22 Jan 2021    Post subject: Reply with quote
There are quite a few variations on that theme, some not quite as vicious looking! This is a bit closer to the "teeth" on a seat pan:
https://www.ebay.co.uk/itm/10m-Flexible-Metal-Back-Tacking-Strip-Ply-Grip-Flexcurve-Upholstery/265021129195
Gruttz
PostPosted: 09:05 - 26 Jan 2021    Post subject: Reply with quote
Sorry for the late response, and a huge thanks for all the great advice.
This is the images of the seat pan.
https://1drv.ms/u/s!Ap7IMAKnEPxagfQax6u3wbY6ZJIbLg?e=by3YQ3
I think I will try the fibreglass route.
Thanks for the fixing links, they are really useful to know (That was going to be my next question).
Thanks
PostPosted: 10:44 - 26 Jan 2021    Post subject: Reply with quote
It would be tempting to properly repair that, it's not too far gone, I was imagining much worse.
A decent steel fabricator would be able to cut off the rotten stuff then weld you new stuff in. They do that kind of shit on rotten car sills all the time. It looks like there is solid metal round the whole "flat" part of the seatpan, and in fact, most of the rim. If it were me, I'd throw the whole thing in a big tub of white vinegar/electrolysis bath and get the rust gone then see what it looks like. Might just need patching at the two sides.
Another alternative, depending on how authentic you want it, would be to buy one of the plethora of "cafe racer" seats off ebay designed for people to fuck up perfectly good CG125s with. You'd just need four rubber door stops and to fabricate two 90 degree brackets.
Easy-X
PostPosted: 12:32 - 26 Jan 2021    Post subject: Reply with quote
Even the cheap ones come with brackets and rubbers. The bad news is they're in the wrong place so some adaption would be required e.g. a metal strip with some captive nuts so you can move the brackets from the back to the front.
Riejufixing
PostPosted: 13:18 - 26 Jan 2021    Post subject: Reply with quote
Gruttz wrote:
That's not too bad. I might be inclined to find some gavanised sheet metal, snip it to shape for fitting along the edges, using the original unaltered base as a guide, and then snap rivet the strips over the rusted metal, leaving the whole of the base intact.Spread the load by putting a washer under the rear of the snap rivet, before you pull it up, and make syre the metal is pulled together before you pull it up too.
Edit: Here you are: https://www.wickes.co.uk/Wickes-Metal-Sheet-Galvanised-Steel-250-x-500mm/p/116718 <-- something like that.
The last post was made 5 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.14 - MySQL Queries: 15 - Page Size: 76.39 Kb
