Bandit 600 exhaust - requires welding?
Kris
PostPosted: 12:53 - 04 Apr 2005    Post subject: Bandit 600 exhaust - requires welding? Reply with quote
Hey all Very Happy
Was underneath the Bandit yesterday and noticed the exhaust clamp (the one with shiny chrome plate attached) had rotted away and was not supporting the link pipe properly. I've managed to use some large jubilee clips to hold this area together but have come across a slight problem. Just a bit futher back from this area I've noticed a crack where the pipe gets thicker and the pipe has come loose here too. I've done a very shitty sketch to show you what I mean... Look for the cracking on my sketch..
Is this fixable by welding etc? Is it just the link pipe?
www.prisonplanet.com
PostPosted: 22:31 - 04 Apr 2005    Post subject: Reply with quote
From your picture, I would weld it then grind it smooth again so the weld doesn't interfere with the fitting. Or braze it.
A lot of people just blank off the ends of balancer pipes when they rot through, I just don't know how appropriate this is for your bike.
PostPosted: 22:47 - 04 Apr 2005    Post subject: Reply with quote
Can probably be welded.
They rot like crazy around the joint. People like Bandit Mania will do repairs, but you might be able to find someone local.
Kris
PostPosted: 14:19 - 05 Apr 2005    Post subject: Reply with quote
Okay cheers guys I'll see if the local bike shop can weld it for me.
I didn't see the extent of the rust at first because of that bloody chromed bracket - only when it fell away in my hands did I realise just how rusted it was there Sad
The last post was made 21 years, 228 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 41.01 Kb
