Quickshifting
Easy-X
PostPosted: 02:57 - 04 Mar 2021    Post subject: Quickshifting Reply with quote
After seeing numerous videos with people bang on about this I thought I'd have a go. Clutchless upshifting obviously, blipping the throttle for downshifts sounds complicated Wink
Is this something people actually do day to day? I could see a value if your clutch cable snaps...
jeffyjeff
PostPosted: 05:43 - 04 Mar 2021    Post subject: Reply with quote
A coworker (and former amature road racer) routinely rides clutchless shifts on his Kawasaki ZRX1200R. He's had that bike since 2002; he rides with finesse, and he logs 500 miles a week on his daily commute. I attempted to perfect the technique on my first VFR, and got reasonably consistent on the upshifts. Downshifting takes a little more skill.
MCN
PostPosted: 09:51 - 04 Mar 2021    Post subject: Reply with quote
My litre bike came with a quickshifter.
It simply removes another thought process/memory item.
Cuts ignition until shift lever is released.
I never did much clutchless changing as the crunching always sounded too expensive to make it worth the effort to learn. And no real need for this if riding public roads.
Racing sure. Racing is a lot of things removed/put together consistently for fastest times.
One doesn't win the race with one fast corner or lap but maintaining the savings and quickshifter help ensure that.
Mental loading adds to lap times.
I've not had such a burden if nipping down to Tesco though.
My 2p worth.
xX-Alex-Xx
PostPosted: 11:09 - 04 Mar 2021    Post subject: Re: Quickshifting Reply with quote
Once moving, I only ever use the clutch a handful of times on a ride, and it's usually if there's traffic etc. That's up and down shifts. It's easy enough to get smooth with a little practice.
DILLIGAF
Kawasaki Jimbo
PostPosted: 11:52 - 04 Mar 2021    Post subject: Reply with quote
I shift up with and without clutch. It's not that I make a conscious decision to use one or the other, you just know when the throttle happens to be in the right place to make clutchless work smoothly. I don't shift down without clutch though. I thought there were practical reasons why it was unwise and there seemed to be no advantage.
PostPosted: 12:16 - 04 Mar 2021    Post subject: Reply with quote
There's a point if you have the hammer down where you find you don't have time for the clutch. That's also the time where the clutchless shifting is most effective and smoothest.
You get a feel for it by loading the lever, then when the revs match, it almost shifts itself.
I also clutchless upshift a lot with a pillion, it's smoother, less rocking back and forth and clashing of helmets.
PostPosted: 12:19 - 04 Mar 2021    Post subject: Reply with quote
I rarely use the clutch for upshifts. I haven't for years. First to second I use the clutch, but other than that it's clutchless all the way. You just put your toe on the lever and then flick your wrist... and the gear clicks into place.
I've never really understood why people find it difficult, but I assume they've never really been taught it? Thinking
chickenstrip
PostPosted: 15:37 - 04 Mar 2021    Post subject: Reply with quote
I just found that at some point in my riding 'career', I was barely actually moving the clutch lever most of the time, a bare squeeze on the lever, can't actually be operating the clutch. I've always blipped on downshifts, just how I learned to do things without much actual thought for it. I suppose I just figured that's what you do, and now it's something I don't give any thought to, just natural.
RhynoCZ
PostPosted: 18:58 - 04 Mar 2021    Post subject: Re: Quickshifting Reply with quote
I blip the throttle, cars/motorcycles, as it just feels right. Shifting up withtout the clutch, well there was a time I did that alot on motorcycles. When everything clicks at high revs (speed), it's just magical. But ever since I bought a slow big single, I don't shift gears without the clutch anymore (except that one time my clutch cable broke and I had to get home; wasn't nice though). It's also due to the XBR's gear shift pattern. I've always had bikes with 1 up and 5 down shifting patern. The XBR is the more commonly used 1 down and 4 up. Lifting the gear shifter up to shift up without the clutch just feels wrong to me, but that might just be that particual engine.
Just go out and try it yourself. You must build up speed or rather revs, then briefly shut the throttle (watch some 80's and 90's racing) and then you firmly with certainty kick the gear in. Now, at first, do not try this from the 1st to 2nd gear, because if you won't operate the gear shifter firmly with enough certainty the gearbox will jump out of the gear into the neutral. Try it from 2nd to 3rd to 4th to 5th to 6th. More revs you have, easier it gets. Also, do not ''preload'' the gear shifter, just kick the gear in when ready.
Thinking of it, ''back in my MZ days'' I used to shift gears with my left hand while laying down on the bike trying to be as aero as possible. I could shift gears up and down and the bike wouldn't even twich.
Easy-X
PostPosted: 19:42 - 04 Mar 2021    Post subject: Re: Quickshifting Reply with quote
Interesting, the gear shift on the XSR is nice and consistent so it was quite easy to toe it to the "preload position" I shall have to also try just kicking it Thinking
PostPosted: 19:48 - 04 Mar 2021    Post subject: Re: Quickshifting Reply with quote
That's the opposite of how I was taught to do it.
Easy-X
PostPosted: 20:03 - 04 Mar 2021    Post subject: Reply with quote
Probably better if I look into what MT-07/XSR/Tenere ppl do, gearboxes not all being created equal.
virus
PostPosted: 20:29 - 04 Mar 2021    Post subject: Reply with quote
I dont think marjay is suggesting holding the lever up all the way from the bottom of 2nd until you get to the top and want to change to 3rd. More a case of when you want to shift up you lift and hold the lever up then dip the throttle for half a second and it'l drop in.
Personally i cant remember the last time i used clutch on the way up once im past 2nd. A light dip of the clutch and a blip of the throttle on the way down always seemed smoother than fully disengaging drive and then feeding it back in too, especially when 2 up as Stinkwheel mentioned.
own: 81 xs1100g...
RhynoCZ
PostPosted: 20:46 - 04 Mar 2021    Post subject: Re: Quickshifting Reply with quote
I was taught don't ''grind the forks'' unnecessarily. Thinking
I might try the lift method, just to see the difference. Although the XBR is a typical Honda, where even after all those years, the gearbox works just perfectly, regardless of what you do (wrong).
EDIT: Either way, do not try this from the 1st to 2nd, before you get confident enough. Going from a fully span out 1st gear into the neutral or even back in to the 1st gear when you expect the 2nd gear isn't very nice.
What's also not nice, my first ride on a bike with regular shifter pattern. Taking off in the 2nd gear to only kick it back into the first gear after a few meters. The memories. Laughing
EDIT II: This might be it: https://youtu.be/viWuolNYGyI?t=184 So start with the ''preload/lift'' method, I guess. Smile
https://www.tshirtbandit.com/products/overlays/33262638.png
PostPosted: 20:47 - 04 Mar 2021    Post subject: Reply with quote
Yes, that's it because I knock off the throttle per change. I take pressure off the lever as soon as it clicks into place.
1198
PostPosted: 13:31 - 05 Mar 2021    Post subject: Reply with quote
stinkwheel wrote:
......less rocking back and forth and clashing of helmets.
Fnar fnar!
Yes, I have the humour of a child on occasion!
redeem ouzzer
PostPosted: 15:47 - 05 Mar 2021    Post subject: Reply with quote
Keeping the lever preloaded between shifts isn't a good idea. It ruins selector forks in the long term as they rub on the adjacent gear if the lever is loaded.
Be a REAL MAN!
PostPosted: 21:49 - 05 Mar 2021    Post subject: Reply with quote
To be clear, I wasn't advocating keeping the lever preloaded. That leads to all sorts of issues, not allowing it to return properly then mis-shifting being one of them. I was meaning I preload it as I want to shift then dip the throttle, when the revs match, it'll snick through. Takes a fraction of a second.
Fisty
PostPosted: 22:54 - 05 Mar 2021    Post subject: Reply with quote
Space docking?
Fatter and faster than Fret
The last post was made 5 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 110.96 Kb
