| Pedro Oz |
 Pedro Oz L Plate Warrior
| MCN |
 MCN Super Spammer
 Posted: 10:19 - 04 Mar 2021 Post subject: |
Grease paths can be weaknesses in Load Paths.
Many manufacturers fit sealed for life or 'lifetime fit.
That means, lasts until a certain mileage has been reached. (With average use)
Fitting after market could be problematic where an engineered area design excludes lube points for a reason.
Welcome to mayhem.
And you should post this sort of subject in the Workshop section.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
 Posted: 12:50 - 04 Mar 2021 Post subject: |
Had it done on my GPZ500 unitrak. Had custom made bronze bushings fitted at the same time. That bike had plastic ones as standard and it was a piece of poor budget-driven design. The bronze bush/greaee nipple combo saved having to replace bushings annually at the MOT. Although I'd expect your bike would have roller bearings?
If you do fit nipples, plan the location well so you can a) Get at them when the parts are on the bike and b) They don't foul anything in their range of movement.
All that said, greasing bearing linkages isn't a job you tend to need to do very often UNLESS you are in an extreme environment with lots of water and dust getting into the linkages. Then I'd question if you wouldn't be better stripping and cleaning it all anyway because adding more grease is no good if the bearing is contaminated. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Fizzer Thou |
 Posted: 14:48 - 05 Mar 2021 Post subject: |
Owning a Honda XR400R as I do,I can say that the needle roller bearings are caged and there are no positions where a Zerck fitting can ideally be located.If the seals are good then an annual service in the lower shock mount area does not go amiss.
The main area of attention is the swing arm pivot shaft as this passes through the frame,the swing arm and the back of the engine.The number of people that I have heard of having real difficulty removing seized components runs into double figures.Be sure to utilise high melting point grease  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| trevor saxe-coburg-gotha |
The last post was made 5 years, 235 days ago. Instead of replying here, would creating a new thread be more useful? |
