Anybody else have constant issues with Pinlock?
c_dug
PostPosted: 22:27 - 04 Mar 2021    Post subject: Anybody else have constant issues with Pinlock? Reply with quote
I've had maybe six or seven different helmets with Pinlock across four manufacturers in the last ten years, and without fail they have all ended up shaking around, scuffing themselves and/or the visor, and steaming up on the inside.
The obvious thing is to say I'm fitting them wrong or maintaining them wrong, but I've actually been to bike shops and had them fitted from brand new on more than one occasion, and followed countless guides to cleaning and adjusting.
Without fail they end up loose and shaking around.
On my last visor I took to running a thin line of tape around the outside of the Pinlock which was excellent, but I don't see anybody else having to do the same? And in any case there was already damage by the time I thought to do this.
I've just bought a new visor and pinlock and this time I'm tempted to run a very thin bead of silicone sealant around the join.
Curious on if anybody else has these issues, or any suggestions?
kgm
PostPosted: 22:34 - 04 Mar 2021    Post subject: Reply with quote
Yep, every single one. Interestingly my Shoei Neotec 2 was the worst.
You can adjust them by rotating the pins but I find it hard to get a perfect seal.
It's fine most of the time but in really bad weather, particularly in the winter they do steam up a bit.
They also end up covered in microscratches really easy.
I've yet to find a better alternative though.
Weisse Schlange
PostPosted: 23:37 - 04 Mar 2021    Post subject: Reply with quote
Nope, been using them for 10 yrs or so and never had a single issue.
Mostly Schuberth.
Hing Oan
MCN
PostPosted: 00:16 - 05 Mar 2021    Post subject: Reply with quote
Nope, never, ever.
The pins have a cam on them.
If the insert is loose, pop the pins out.
Insert in the holes so the offset of the cams are facing in.
Insert the insert.
Be careful when handling the insert as the inside surface coating is easily damaged.
https://pinlock.com/support/
FretGrinder
PostPosted: 01:45 - 05 Mar 2021    Post subject: Reply with quote
I've had success with flexing the visor flat so that the pinlock can reseat itself after rotating the cams.
It seems to get a better seal once flat and allowed to return to it's natural shape.
Yamaha MT-09
ಠ_ಠ
Easy-X
PostPosted: 02:01 - 05 Mar 2021    Post subject: Reply with quote
I like to think of it as visor double-glazing. And much the same as the glass equivalent once the seal is broken the damp gets in and it starts fogging up.
I can only think that either the inside surface of the visor wasn't 100% clean when applied and/or it's not been fitted correctly. It should not be able to move at all.
PostPosted: 03:11 - 05 Mar 2021    Post subject: Reply with quote
I got a pinlock visor with my Shoei about a year and a half ago and I've never had a problem with it.
Fat Angry Scotsman
PostPosted: 09:44 - 05 Mar 2021    Post subject: Reply with quote
I got a pin lock visor for my Scorpion EXO 410 which is a alright helmet for £110. Pin lock cost me £25 online and I got it myself. I think it’s fantastic to be honest.
tom_e
PostPosted: 10:49 - 05 Mar 2021    Post subject: Reply with quote
Nope no problem here across multiple helmets/manufacturers.
Copycat73
PostPosted: 18:29 - 05 Mar 2021    Post subject: Re: Anybody else have constant issues with Pinlock? Reply with quote
i have a helmet which turned out to be a pin lock .. when the plastic plugs fell out i covered them up in clear cellotape .. fcukin donky dick chindogu idea .. if ever i saw one .. now i have no problem ..
caveat emptor
MCN
PostPosted: 18:40 - 05 Mar 2021    Post subject: Re: Anybody else have constant issues with Pinlock? Reply with quote
Are you smoking chloroquine? Rolling Eyes
Copycat73
PostPosted: 20:19 - 05 Mar 2021    Post subject: Re: Anybody else have constant issues with Pinlock? Reply with quote
only when i`m near amebiasis infected creatures .. with a reputation for colonic ulceration...
caveat emptor
c_dug
PostPosted: 20:21 - 05 Mar 2021    Post subject: Reply with quote
Glad it isn't just me, although we do appear to be in the minority.
I've done all of the things suggested here, I have always had a new visor and Pinlock as a pair, never new on to old. Done the cams too.
Honestly no clue what I'm doing wrong!
PostPosted: 21:02 - 05 Mar 2021    Post subject: Reply with quote
Yes. Every time.
They also fog up. I find they produce marginally better vision during daylight but cause so much flare and starburst at night from oncoming headlights that I'm better without them.
Useless waste of money. Emperors new clothes. People can't believe they spent £20 on a piece of plastic and convince themselves it was a good idea.
EDIT: All the disciples will try to tell you you are using it incorrectly. Last one I had on my Arai was supplied by an arai specialist in York, already fitted to a new visor because I told them there was no way I was putting a screwdriver anywhere near an new £45 visor.
It became the worlds most expensive tear-off before Scotch Corner because I was doing 100mph on a dark motorway and couldn't see where the fuck I was going.
kgm
PostPosted: 23:01 - 05 Mar 2021    Post subject: Reply with quote
Maybe depends on use. It takes really quite wet weather, usually when it's also cold for mine to fog up. I also ride a lot at night when the street lights starburst on the little scratches.
I know how they're supposed to be fitted and adjusted, even have the proper tool for the pins on Shoei one. Every one has been originally fitted by the shop (Shoei was a specialist) and I even had one visor replaced under warranty because it was that bad a fit (Shark helmet). The new one was better but still not perfect.
Like I said though, I've yet to find a better alternative and it's much better having one that not.
Incidentally the Shoei Neotec also leaks from the top of the visor in really heavy (torrential) rain leading to drips running down the inside over the pinlock. I have two mates who got the same helmet at the same time and we've all had the same issue. Shame, because it's a really excellent helmet otherwise. This was a problem with the first gen helmet but doesn't seem like they've sorted it with the mk2 either.
Pigeon
PostPosted: 00:16 - 06 Mar 2021    Post subject: Reply with quote
3 helmets and 4 pinlocks, about 80k miles. Fit Pinlock day1 and leave it in there.
The only one that steamed was the one I removed and cleaned a couple of times. Damaged the seal, but not surprising that it fogged after that.
Shoei Qwest
Shark Speed R
Spada .....something. MotoX lid.
PostPosted: 11:57 - 06 Mar 2021    Post subject: Reply with quote
Because what I really wanted was an anti-fog device that works perfectly when its reasonably warm and dry...
PostPosted: 12:22 - 06 Mar 2021    Post subject: Reply with quote
A podcast that I listen to said that they spoke to a "Well known helmet brand" that said it was possible to make a visor that did not fog up at all but people didn't trust when any helmet brand said that a visor was totally anti fog, so they were better off giving people pinlocks as standard because people trusted them more.
PostPosted: 12:41 - 06 Mar 2021    Post subject: Reply with quote
They make double-glazed visors with electrical heating elements in them in the US for use in snowmobiles. They just don't let enough light through for UK regs.
You can retrofit them to HJC lids.
PostPosted: 13:04 - 06 Mar 2021    Post subject: Reply with quote
Apparently it was a coating, and it was legal.
PostPosted: 13:49 - 06 Mar 2021    Post subject: Reply with quote
AYe, thing is, as pinlocks demonstrate, the coatings only work up to a point. That point being when you really need it to work. If the inside of your helmet reaches dew point, a coating is going to do fuck-all.
MCN
PostPosted: 16:51 - 06 Mar 2021    Post subject: Reply with quote
Im a disciple Embarassed
I used Fag-City years ago but they were a bit of DIY to fit and pernickety AF to align properly.
If you got it wrong then it was a new visor and a new insert that was required as they use/d some strong AF adhesive to stop it coming off and to maintain the air tight seal. Same principle as Pinlock.
Double Glazing.
The issue I have, that is the only criticism I can honestly level at a Pinlock insert, is that they can only deal with so much humidity and cold.
They are trying to defy the laws of fizix.
The water in humid air will condense on cold surfaces
In winter on those minging wet cold days the atmospheric conditions probably overwhelm the device.
The coating is a moisture absorber.
If it's already loaded with moisture then fitted to a visor then any air that is trapped plus the absorbed air will freeze or fog.
Winter riding and some summer riding in rain is difficult and systems are just not available that can cope with 100% of the problems.
There's device around called Precipitation Friend or something like that. Think it's crowd funded.
It's probably shite too.
Kentol750
PostPosted: 18:53 - 06 Mar 2021    Post subject: Reply with quote
The benefits of pinlock or similar far outweigh its cost. It's not perfect and needs a little adjustment sometimes. I have never used anything better and at night, in the rain, scratches on the visor can really make riding uncomfortable.
As for neotec 2 over neotec, never had serious problems with either, 2 was better. Use a Simpson carbon flip now. Much lighter and with pinlock it's excellent.
Some bikes.
DJP
PostPosted: 12:24 - 07 Mar 2021    Post subject: Reply with quote
The factory fit one on my Nolan is great but the retro fit ones I've had have been a bit iffy.
Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https
BRUN
PostPosted: 13:11 - 07 Mar 2021    Post subject: Reply with quote
their are 3 different levels of pinlock iirc
if its the lowest one your using it will be better than nothing but not as good as the higher level ones
my helmet only takes the basic one, and its not perfect but it is definitely better than without
The last post was made 5 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 132.57 Kb
