Steamy windows?
pepperami
PostPosted: 10:25 - 06 Mar 2021    Post subject: Steamy windows? Reply with quote
Nothing to do with bikes.
One of the windows in my house has condensation between the panes.
How the Hell do you get rid of condensation that’s inside the double glazing?
I seek your wisdom oh mighty BCF Thumbs Up
PostPosted: 10:32 - 06 Mar 2021    Post subject: Reply with quote
The seals are fucked and you can either faff around trying to repair them or you just replace the whole unit.
pepperami
PostPosted: 10:37 - 06 Mar 2021    Post subject: Reply with quote
Sadly you gave me the answer I already knew but didn’t want to hear Sad .
Thank you anyway. Thumbs Up
I was hoping someone might have a magic trick up their sleeve.
F*kk it! It’s the utility room window, it can stay like that if the worst comes to it.
doggone
PostPosted: 11:28 - 06 Mar 2021    Post subject: Reply with quote
Usually it's because the unit is sitting in water then affected by freeze/thaw cycles - because the drainage below is blocked or it was installed poorly without a spacer so it doesn't sit in a puddle.
If the frame is wood you need almost annual attention to stop water penetrating along the bottom.
You might be (almost) pleasantly surprised how easy and relatively inexpensive it is to replace.
They can eventually grow green algae inside which is harder to ignore than condensation.
PostPosted: 12:01 - 06 Mar 2021    Post subject: Reply with quote
This. ^^
If it's a PVC frame in any case. Buy a putty knife and a thin prybar. One of those big sucker pads with a handle is helpful too, I think I got all three in a "kit" off ebay. Order a double glazed unit the correct size, watch a how to on youtube then go and fit it.
Then sit down and wonder why they bother putting locks on houses.
Easy-X
PostPosted: 13:04 - 06 Mar 2021    Post subject: Reply with quote
What you need to do is save all those little silica gel bags that things get packed with, pop off one pane, drop a few in the gap and pop the pane back in. Simples Laughing Laughing Laughing
MCN
PostPosted: 17:11 - 06 Mar 2021    Post subject: Reply with quote
Hoi.. it says on those wee baggies, Do Not Eat
WTF have you been up to?
Very Happy
virus
PostPosted: 17:59 - 06 Mar 2021    Post subject: Reply with quote
More modern UPVC windows have the trim bevels on the inside so that the window cant be removed from the outside. Not that it'll stop anyone armed with a brick mind.
own: 81 xs1100g...
Freddyfruitba...
PostPosted: 18:34 - 06 Mar 2021    Post subject: Reply with quote
FWIW I recently got a quote for replacing a blown sealed unit, 770 mm x 690 mm - ie materials only, no fitting cost - from an outfit called https://www.sealedunitsonline.co.uk - it was £34 incl VAT. Can't vouch for them as I haven't followed up (yet). They aren't particularly hard to fit bit easy to fcuk up the plastic frame if you don't know what you're doing.
There are also companies about who claim to specialise in fixing blown units by drilling a tiny whole in the inner pane, injecting some sort of hygroscopic liquid into the gap to absorb the moisture, and plugging the hole. Sounds an unlikely fix to me though.
Raffles
PostPosted: 22:11 - 06 Mar 2021    Post subject: Reply with quote
As others have said, double glazed units are not expensive. I recently purchased 3 units with frosted glass for £142.
I would recommend using one of these for removing the beads. It'll set you back around eight quid and will be money well spent.
MCN
PostPosted: 14:21 - 07 Mar 2021    Post subject: Reply with quote
Double Glazed units can be difficult to knock out even with a brick.
Spring loaded Centre Punch (stolen) is the scrotes weapon of choice.
hellkat
PostPosted: 21:00 - 07 Mar 2021    Post subject: Reply with quote
Are they Harmful to the Environment?
Cos I have to do two Lateral Flow tests a week, and every test package comes with one of them in.
... been just throwing them out in the bin.
Shifty
Islander
PostPosted: 21:33 - 07 Mar 2021    Post subject: Reply with quote
Shifty
No, it's inert. It's just porous silica (silicon dioxide) the same stuff that quartz is made of.
BigTim
PostPosted: 21:47 - 07 Mar 2021    Post subject: Reply with quote
A spark plug works just as well I'm told, obviously with assistance from a hammer.
MZ S50B, Suzuki GP100, Honda CBF1000, Honda Blackbird (I like my Blackbird)
ThunderGuts
PostPosted: 08:56 - 11 Mar 2021    Post subject: Reply with quote
If you're really not bothered about it being obscured, you could just get some frosted window film and apply it; you'll never see the condensation from the inside then.
I have three windows which need dealing with in our house in the same state . . . so much for "fit and forget" double glazing.
TG.
The last post was made 5 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 88.81 Kb
