Aprilia RS125
JLovesey96
PostPosted: 18:09 - 07 Mar 2021    Post subject: Aprilia RS125 Reply with quote
Hi there,
I've had my Aprilia Rs for about 8 years now, I must say I haven't used it for about 3 years now and sort of neglected it.
I thought I'd fix it up as it had a few issue's before. I've put a new battery on it and checked all fuses about 5 times, when I turn the ignition on, I'm getting no power what so ever. I've got a multimeter and checked that's there's power from the ignition, and earthing is fine, checked a lot of things, am I right in thinking, it could be the regulator please?
In need of some help if anyone could help please
Nobby the Bastard
Harley Gaydar
PostPosted: 18:14 - 07 Mar 2021    Post subject: Reply with quote
The regulator only does anything once the engine is started so no.
Triumph Sprint ST 1050
JLovesey96
PostPosted: 18:20 - 07 Mar 2021    Post subject: Reply with quote
So do you know what it would be as I'm confused
Nobby the Bastard
Harley Gaydar
PostPosted: 18:45 - 07 Mar 2021    Post subject: Reply with quote
No lights or anything but power to the ignition switch?
Is power coming back out of the switch?
jeffyjeff
PostPosted: 18:48 - 07 Mar 2021    Post subject: Reply with quote
Use your multimeter to verify that you have power to your fuse box.
JLovesey96
PostPosted: 18:57 - 07 Mar 2021    Post subject: Reply with quote
Literally no power what so ever, no lights come on, absolutely nothing, I used the multimeter back to the ignition switch and that's all good, I will test if there's any power going to the fuse box and see what happens.
Thanks for helping as well
xX-Alex-Xx
PostPosted: 19:13 - 07 Mar 2021    Post subject: Reply with quote
Might be a stupid question, but the battery is definitely connected the right way and actually has a charge in it?
DILLIGAF
Easy-X
PostPosted: 19:18 - 07 Mar 2021    Post subject: Reply with quote
Should at least have a neutral light. It only relies on the main power being on, fuse(s) intact and the battery earth connected to the frame and/or engine.
JLovesey96
PostPosted: 19:30 - 07 Mar 2021    Post subject: Reply with quote
Yes battery is fully charged, and fitted correctly mate Easy - X I'm getting nothing, nto even a neatrul light, really don't know what it is at this moment
xX-Alex-Xx
PostPosted: 19:33 - 07 Mar 2021    Post subject: Reply with quote
Is there a secondary fuse box anywhere, or some other inline fuse on the main circuit? Might be worth digging out a service manual online if you dont have one.
DILLIGAF
JLovesey96
PostPosted: 19:39 - 07 Mar 2021    Post subject: Reply with quote
I've tried looking for one but couldn't find 1 and I've just ordered a manual which is a downloaded 1, so I'm just waiting for the seller to send it to me on ebay
Nutty
PostPosted: 20:45 - 07 Mar 2021    Post subject: Reply with quote
This might help your cause , but dont know your bikes year
JLovesey96
PostPosted: 20:52 - 07 Mar 2021    Post subject: Reply with quote
Thanks for that, sorry its a 2005. I'll have a look at what I can do and see if I can figure anything out
Nutty
PostPosted: 13:56 - 08 Mar 2021    Post subject: Reply with quote
Have a look at your ignition Switch and the 2 wires coming from it
JLovesey96
PostPosted: 14:26 - 08 Mar 2021    Post subject: Reply with quote
I looked at the ignition switch and unplugged it and there's power coming from there, I'll have a little look at the bike once I'm home after work, if I can I'll take a few pictures and a video of everything and post it on here
Nobby the Bastard
Harley Gaydar
PostPosted: 14:58 - 08 Mar 2021    Post subject: Reply with quote
If you unplugged the ignotion and tested it you found power going to and not from the ignition switch. The two are not the same.
JLovesey96
PostPosted: 17:22 - 08 Mar 2021    Post subject: Reply with quote
If you unplugged the ignotion and tested it you found power going to and not from the ignition switch. The two are not the same.[/quote]
Just got home and reconnected the battery, now all the electrics are working, I thinking the electric fairy's came and gave me a helping hand last night
Nutty
PostPosted: 17:43 - 08 Mar 2021    Post subject: Reply with quote
Laughing Laughing well done
JLovesey96
PostPosted: 17:46 - 08 Mar 2021    Post subject: Reply with quote
Just need a few new things and then hopefully it will start, does anyone know how to get the head off, I've taken the top bit and taken off the reeds and all the nuts but it won't budge. Sprayed WD40 over the bolts but it still won't budge
Easy-X
PostPosted: 18:06 - 08 Mar 2021    Post subject: Reply with quote
Just the main barrel I take it, you've had the 4 nuts off. Is the engine seized BTW?
I'd probably try and get the piston about half way up and give it some love taps with a rubber mallet from the intake and exhaust sides. DO NOT be tempted to jam a screwdriver between the barrel and the bottom end.
JLovesey96
PostPosted: 18:14 - 08 Mar 2021    Post subject: Reply with quote
[quote="Easy-X"]Just the main barrel I take it, you've had the 4 nuts off. Is the engine seized BTW?
All off now, everything seems alright, just gonna order a new gasket set, for some reason though, every time I turn the ignition on, the 15 fuse keeps blowing, not to sure why that is, I need to go get some more fuses but it blew through 2 of them
Robby
Dirty Old Man
PostPosted: 18:17 - 08 Mar 2021    Post subject: Reply with quote
Standing for years.
Wouldn't show any electrical life, then suddenly did.
Blowing fuses.
Look through the wiring for the one a mouse tried to chew through that is now shorting. Also see if there is a mouse nest in the airbox. Wear gloves.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:20 - 08 Mar 2021    Post subject: Reply with quote
The 15 A fuse does all the lights amongst other things. Try removing all the bulbs.
JLovesey96
PostPosted: 18:38 - 08 Mar 2021    Post subject: Reply with quote
The bikes stripped mate, literally just got the back light connected. I'll have a look at the manual and see what happens
JLovesey96
PostPosted: 19:10 - 12 Mar 2021    Post subject: Reply with quote
Finally got it running after 6 years, few new things and it's all good Very Happy
The last post was made 5 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 121.39 Kb
