Fuel outlet cbr 125 r 2009
RedGreenBlue
PostPosted: 12:58 - 07 Mar 2021    Post subject: Fuel outlet cbr 125 r 2009 Reply with quote
New member so Hi Smile
My engine started cutting out randomly so I wanted to check some things. New spark plug etc. But I had some trouble with the fuel hose. When disconnecting, the fuel outlet from the fuel pomp broke.
On internet I only found that I'm able to buy the full pump assembly. Kind of expensive for a (very important) plastic part while the fuel pump itself is still fully functional. Any idea where I can order the plastic part from the fuel pomp. Or what the name of this part is? I only found 'fuel outlet' But I think it has a more specific name due to the fact that it isn't just the fuel outlet but also the electrics are connected to it.
Thanks for the help!
[/img]
bikenut
PostPosted: 14:50 - 07 Mar 2021    Post subject: T Reply with quote
Of course you are not showing the "other side", the outside view of the part you are holding, with the broken off stub.
Post a picture of the other side together with the broken stub, which may be still inside the hard plastic shaped pipe ?
Expensive mistake....but you may be lucky....post some more pictures dude...
nuts about bikes
Nobby the Bastard
Harley Gaydar
PostPosted: 16:22 - 07 Mar 2021    Post subject: Reply with quote
According to Fowlers, it's all sold as one piece. You won't be able to get it seperately.
https://www.fowlersparts.co.uk/parts/4829677/cbr125rw9-2009-e-wh/fuel-tank-cbr125rw7rw9rwa
Triumph Sprint ST 1050
jeffyjeff
PostPosted: 18:55 - 07 Mar 2021    Post subject: Reply with quote
might have to get creative. do you think there is enough material around the broken area to drill and tap for a threaded barbed fitting?
The last post was made 5 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 4.07 - MySQL Queries: 13 - Page Size: 39.33 Kb
