Honda CG125 won't start
WheelieKid
PostPosted: 18:10 - 09 Mar 2021    Post subject: Honda CG125 won't start Reply with quote
Just bought a 2007 Honda CG125.
Rode it at the weekend nothing was wrong with it except when I came home it did not want to idle.
Same problem today except when I stopped at a junction it cut out and now won't start (electric start only model).
I was told the starter was replaced last year by the previous owner.
A̶p̶r̶i̶l̶i̶a̶ ̶M̶X̶1̶2̶5̶ Honda CG125
bikenut
PostPosted: 18:29 - 09 Mar 2021    Post subject: T Reply with quote
Purchased from a dealer ? So has a warranty...
I assume it has fuel ( petrol ) and the starter whizzes the engine over ?
How is the engine oil level ?
nuts about bikes
WheelieKid
PostPosted: 19:41 - 09 Mar 2021    Post subject: Re: T Reply with quote
Hi, not purchased from a dealer.
Has fuel, spark plug is black but still sparks, starter did sound like it was gonna go but just tried again now and it just makes a buzzing sound (maybe I flattened the battery?).
Engine oil was fine when i bought it (literally bought it 4 days ago).
Right now I am charging the battery so I will see of that solves the starting issue.
bikenut
PostPosted: 19:59 - 09 Mar 2021    Post subject: T Reply with quote
So no warranty...
How many amps is the battery drawing on the charger gauge ?
Is the battery getting warm in one area and does it need topping up with distilled ( called deionised these days ) water.
You have a digital multi meter and wiring diagram ?
When the battery is back on and the plug cleaned, gapped and refitted, check choke operation.
When engine running and at idle, with no multimeter, turn on headlights and increase engine revs, do light grow brighter ?
No need to rev it till it explodes, just increase revs and watch lights.
Some research necessary as lights may be ac rather than DC on this bike, and does it have a carb ?
If not known check via CMSNL...
nuts about bikes
KiwiBob
PostPosted: 21:50 - 09 Mar 2021    Post subject: Reply with quote
Plugs black .. you have not left the choke on have you?
MCN
PostPosted: 05:29 - 10 Mar 2021    Post subject: Reply with quote
It will run with the choke on half.
They have two positions.
Full choke for starting.
And a half choke. For no apparent reason.
Start on full choke.
Flick it off after a few minutes.
If you flooded the engine. Most probably now.
Too much fuel and the spark won't light it. Because there is not enough oxygen in an over-rich fuel mixture.
You need to remove the excess fuel from the engine.
Choke Off
Throttle held fully open on the stop.
Crank the engine over for a couple of second.
That will blow the excess fuel out.
Choke full on.
Hold throttle just a baw hair off fully closed.
Crank the engine.
It should then start.
Let it run on the choke until it can run without choke.
Takes about 5 mins.
If it still won't start then you should check spark is good.
Spark is generally good enough to start even the most shit engine.
Robby
Dirty Old Man
PostPosted: 13:00 - 10 Mar 2021    Post subject: Reply with quote
Last time I was working on one of these there were two main problems:
1. Water in the fuel. Quite a lot of it. Turn the fuel off, pop the fuel pipe off the carb and into a plastic bottle, turn the fuel to reserve, let about half a litre run into the bottle. Water will settle to the bottom. You don't want any water in the fuel. If you see any, drain it all out and then also drain the carb - little screw on the bottom.
2. You're probably using the choke the wrong way round. I hate the carbs on those bikes, I always get things back to front.
The battery should recover from charging, but it might just need to be replaced.
WheelieKid
PostPosted: 19:02 - 10 Mar 2021    Post subject: Reply with quote
Choke Off
Choke full on.
Crank the engine.
Takes about 5 mins.
Hi so after charging the battery today and it started but won't idle.
I have put the choke in every position.
Leaving it fully up and holding revs for 30 sec - 60 sec
Then halfway still holding revs 30-60 sec
Then all the way down and held revs for 30 sec again
It still wouldn't idle.
I will try again with full choke for 5 min see if that works.
MCN
PostPosted: 19:48 - 10 Mar 2021    Post subject: Reply with quote
Remove the air filter, if it has one, and try.
Plugged air filter will increase fuel mixture and could cause the issues you are having.
Robby
Dirty Old Man
PostPosted: 10:57 - 11 Mar 2021    Post subject: Reply with quote
There is an idle adjuster screw on the side of the carb. Screw it in to raise the idle, out to lower it.
Before you fiddle with that though, check over the basic service parts. For a CG that just means checking/changing the air filter, changing the spark plug, making sure it has some oil in the engine.
As as I said last time, check for water in the fuel.
CG125s can get seriously neglected, because they keep on working in a state that other bikes would have given up. It also means that diagnosis over the internet is less straightforward, because I have no idea what state your bike is in.
WheelieKid
PostPosted: 17:08 - 11 Mar 2021    Post subject: Reply with quote
Got it to idle after adjusting the screw (and also I may have been using the choke the opposite way round). Since there is no tach I tried to match the rpm to my car which sounded about right (1500 rpm)
By the way, does water in the fuel tank occur from just sitting for a while?
Easy-X
PostPosted: 17:52 - 11 Mar 2021    Post subject: Reply with quote
This is a subject for debate. The simple answer is "yes, since the introduction of ethanol in fuel" but as to how long it would take to be a problem is another matter altogether.
Water can get in other ways of course like a blocked drain leading to water pooling around the filler cap.
Robby
Dirty Old Man
PostPosted: 22:00 - 11 Mar 2021    Post subject: Reply with quote
A bit of water in the fuel tank happens from sitting, particularly if the tank is not full. Condensation from the air collects on the steel sides of the tank, and rolls down into the petrol and sits underneath it.
However, the amount of water you get from this is negligible. If the tank has sat long enough for water to be a problem to the bike running, the fuel has gone off and the tank has probably rusted quite a bit as well. Multiple years.
More typical, the rubber sealing ring under the fuel filler cap goes hard and stops making a good seal, combined with the bike living outside in the rain, without a cover. Leave a bike like that for a couple of months over winter and you'll have a pint of water in the bottom of the fuel tank.
Ethanol is a whole different bag of issues. On the one hand, it's hygroscopic so it absorbs water out of the air and eventually allows the water to separate out. On the other hand, it's hygroscopic so it will absorb small amounts of water without affecting its viability as fuel. For daily use, that means I prefer it - water doesn't get to accumulate at the bottom of my fuel tank, it gets absorbed and burnt with the petrol/ethanol mix.
WheelieKid
PostPosted: 11:50 - 13 Mar 2021    Post subject: Re: T Reply with quote
bikenut wrote:
So no warranty...
So I took the bike out and within 2 minutes it just died on me. All the lights on the gauges went off. I could not get it restarted, tried to bump start but it wouldn't fire.
Could this be an alternator problem? I haven't got a multimeter (yet!) but once I do what should I look out for?
Easy-X
PostPosted: 13:41 - 13 Mar 2021    Post subject: Reply with quote
With a multimeter the basic checks are:
Voltage of battery (should be >12V, 13~14V ideal)
Voltage of battery when turning over (if it turns over) it'll drop a bit and dance around but give us a rough idea of what it does.
Voltage of battery while idling and with some revs (again, if you can even start it!) just to get an idea of what the charging system is pushing to it.
After that you can do things like checking fuses with the continuity check feature of the multimeter, use the voltage function to trace the path of the hot wire, e.g. "hmm, red wire goes from battery to ignition but I'm not seeing any voltage there..." and so on.
A whole world opens up! Just remember that the frame of the bike is used as a common earth (i.e. connected to the negative terminal of the battery.)
Nobby the Bastard
Harley Gaydar
PostPosted: 13:54 - 13 Mar 2021    Post subject: Reply with quote
I'd be looking at the connections to the ignition switch and rh switchgear.
Triumph Sprint ST 1050
bypass2
PostPosted: 19:50 - 13 Mar 2021    Post subject: Reply with quote
is the petrol tap working.
WheelieKid
PostPosted: 11:47 - 24 Apr 2021    Post subject: Honda CG125 won't start Reply with quote
After taking it to the mechanic I had found out that the valve was mushroomed and also a new valve seat was needed.
PostPosted: 12:09 - 24 Apr 2021    Post subject: Re: Honda CG125 won't start Reply with quote
Which valve? A cylinder head valve? Or the needle valve in the carb.
The latter I could see, the former seems highly improbable.
WheelieKid
PostPosted: 12:22 - 24 Apr 2021    Post subject: Re: Honda CG125 won't start Reply with quote
A cylinder head valve. Obviously, I had revved the bike too much, in the car I go by the rev counter, but the CG doesn't have one.
PostPosted: 14:19 - 24 Apr 2021    Post subject: Reply with quote
I still find that improbable, I'd have expected it to throw a pushrod first. They usually just bounce the valves if you over-rev them.
I think that must be some sort of record.
WheelieKid
PostPosted: 16:42 - 24 Apr 2021    Post subject: Reply with quote
Record for?
PostPosted: 16:57 - 24 Apr 2021    Post subject: Reply with quote
WheelieKid wrote:
Record for?
Being the first person I ever heard of to damage a valve on an OHV honda by thrashing it too hard.
WheelieKid
PostPosted: 17:42 - 24 Apr 2021    Post subject: Reply with quote
stinkwheel wrote:
WheelieKid wrote:
Record for?
What can I say I'm one of a kind Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 18:33 - 24 Apr 2021    Post subject: Reply with quote
My experience of cg125s is that they refuse to be thrashed by design.
The last post was made 4 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 130.45 Kb
