Chain slack help
Ducky95
PostPosted: 16:14 - 13 Mar 2021    Post subject: Chain slack help Reply with quote
I'm new to bikes and have delved into trying to fix my chain slack - each time I try something is always skewiff.
I have the Honda MSX 125 with a chain slack of 30-40mm. Today my slack was at 40mm and decided to try and tighten it up, I loosened the nut on the right side and then fixed the adjusters 1/4 turn at a time.. I got it down to 32mm but when tightening everything back up it was at 27mm, I try a second time and the result is 37mm however after a test ride to make sure everything feels right the chain has loosened up again to 42mm.
I'm not exactly sure what I'm doing wrong. Any ideas?
**All fixed, fourth times the charm it seems, thank you!
yen_powell
PostPosted: 16:52 - 13 Mar 2021    Post subject: Reply with quote
Are you measuring it at lots of different places so you measure the tightest spot each time? Are you measuring it when it is still warm after a ride? Is it shagged and stretching like some non O ring chains I have had in the distant past? Are you tightening the axle nut as it should be tightened?
XT1200Z and a DR350 in bits
Easy-X
PostPosted: 17:07 - 13 Mar 2021    Post subject: Reply with quote
Indeed, the wheel should not be moving about in any way to create slack Shocked
If the chain's stretching that bad and you're getting a new one don't forget to check the sprockets for wear, might be worth doing chain + front & back all at the same time.
Ducky95
PostPosted: 17:09 - 13 Mar 2021    Post subject: Reply with quote
I haven't been measuring it in different places but will do that next time. It's being measured cold - how should the axle nut be tightened? When I tighten it I have a spanner on the opposite bolt to keep it from moving and tighten the nut up the same amount it took to loosen.
Easy-X
PostPosted: 18:08 - 13 Mar 2021    Post subject: Reply with quote
Shouldn't one use a torque wrench and tighten to spec or am I being too precious?
Skudd
PostPosted: 18:38 - 13 Mar 2021    Post subject: Reply with quote
Too precious. Although it is a slight skill to not use one.
jaffa90
PostPosted: 19:12 - 13 Mar 2021    Post subject: Reply with quote
I would leave it at 40mm min, if you set it at 32mm it will stretch, more so on uneven surfaces.
It has a long swing arm travel that`s why it has a rubber pad/ strip on top off the swing arm.
I have had many trail bikes and non had less than 40mm slack.
WD Forte
PostPosted: 19:58 - 13 Mar 2021    Post subject: Reply with quote
Check the sub frame isn't bent
bikers smell of wee
Easy-X
PostPosted: 21:25 - 13 Mar 2021    Post subject: Reply with quote
Is a Grom a trail bike?
to v or not to v
PostPosted: 21:47 - 13 Mar 2021    Post subject: Reply with quote
chains have a tight spot. you need to turn the wheel and measure the movement in the chain until you find the point with the least slack. this is where you take your measurement from.
look for how to videos on youtube if in doubt.
jeffyjeff
PostPosted: 22:14 - 13 Mar 2021    Post subject: Reply with quote
+1 Thumbs Up
jaffa90
PostPosted: 01:33 - 14 Mar 2021    Post subject: Reply with quote
A mini one. Razz
The Honda Grom is a 124.9 cc (7.62 cu in) air-cooled motorcycle made by Honda Motor Co. ... Honda Grom 125 at Birmingham 2014.jpg ... It is styled to resemble the Honda Z series Mini Trail (commonly known as "Monkey Bikes").
Next question!
The last post was made 5 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 72.53 Kb
