| -Savage- |
 -Savage- World Chat Champion
 Posted: 16:49 - 11 Mar 2021 Post subject: MOT, adapted brake pedal pass/fail? |
Hi Folks,
Quick question.
Would this fail an MOT?
Due to the exhaust I have fitted, the brake pedal is now quite low, and because of the screws in my ankle I find it hard to activate the rear brake with any heavy force.
This extension makes it much easier.
It's on securely and has no extraneous movement when operated, but I understand how dodgy it looks.
Do you reckon it will pass mot? And if not, what would you recommend I do?
Thanks.
[Edit: it's on a Royal Enfield 500 with a sidecar so its not as bad as you might think lol] ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
| rpsmith79 |
 rpsmith79 World Chat Champion
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| -Savage- |
| WD Forte |
 WD Forte World Chat Champion
| Nobby the Bastard |
| Ste |
 Ste Not Work Safe
| WD Forte |
 Posted: 19:04 - 11 Mar 2021 Post subject: |
I think it needs some developing cos
It could work loose and spin ( blue arrows)
The clamp could rock off the pedal ( yellow arrows)
I'd prefer a more triangular bracing ( red lines)
not reliant on clamping on a single axis (white line)
https://imgur.com/cZFR4Et.jpg ____________________ bikers smell of wee |
| Pete. |
 Pete. Super Spammer
 Posted: 19:10 - 11 Mar 2021 Post subject: |
Two through holes and a rubber block would be less prone to failure, but I see no ground for it not to pass the MOT. ____________________ a.k.a 'Geri'
| Ste |
 Ste Not Work Safe
| stinkwheel |
| jeffyjeff |
 jeffyjeff World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 10:36 - 12 Mar 2021 Post subject: |
Talk to your MOT tester The guy I use has Leg Issues and knows exactly what is OK and what is not
I prefer to see it bolted though but if it is secure I would expect him to be fine with it ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Skudd |
 Skudd Super Spammer
| Ste |
 Ste Not Work Safe
| Shaft |
 Shaft World Chat Champion
 Posted: 01:06 - 13 Mar 2021 Post subject: |
| Ste wrote: | | WD Forte wrote: | It could work loose and spin ( blue arrows)
not reliant on clamping on a single axis (white line) |
Are any of those reasons why it wouldn't pass an MOT?
There's room for improvement aesthetically but assuming it's secure and the brake still works properly, adapting the brake pedal so that his disability doesn't hinder his control of the bike isn't a reason to fail.
As it's going to be a permanent thing, I'd look at getting it welded up as that would help make a better first impression when the tester sets eyes on the bike. |
This.
With my tester's hat on, we aren't allowed to hit things with hammers or yah away on stuff with a pry bar anymore, so we can't test it to destruction, like they used to do in the bad/good old days.
I tend to test the brake light by pushing the pedal with my hand (we haven't got a mirror, so doing that allows me to either lean round and look, or put my other hand over the light) so if it felt insecure in any way under hand pressure, I might have a concern, but I don't think I could justify anything more than an advise and pass, unless it moved substantially.
In saying that, NI tests are a bit more draconian than mainland and it does look a bit temporary, so I would be working out a more permanent looking solution. ____________________ Things get better with age; I'm close to being magnificent........
WooHoo, I'm a Man Point Millionaire! https://www.bikechatforums.com/viewtopic.php?t=234035 |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
 Posted: 10:02 - 13 Mar 2021 Post subject: |
Probably worth asking NABD - I''m sure they'd know even if it's in NI.
https://www.nabd.org.uk/contact-us/ ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| MCN |
 MCN Super Spammer
 Posted: 10:21 - 13 Mar 2021 Post subject: |
| WD Forte wrote: | I think it needs some developing cos
https://imgur.com/cZFR4Et.jpg |
MS Paint diagram illustrative but depicts shocking mouse control skills.
Were you on the bike when you did this?
OP Whip it off before the test.
Or, if you are on good terms with the test centre, ask them before the test.
If they are cagey and say you need to pay for a test first then take the beast somewhere else. (Finding a bike MOTer is a PItA)
Or.... Visit Timpsons and ask the cobbler to coble you a massive build-up under your boot. Like a Surgical Shoe. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| jaffa90 |
 jaffa90 World Chat Champion
| Skudd |
 Skudd Super Spammer
| -Savage- |
The last post was made 5 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
