Broken kickstart
The Learner
PostPosted: 23:57 - 14 Mar 2021    Post subject: Broken kickstart Reply with quote
I was trying to start my CB100 and the kickstart snapped clean at the base of the shaft (30+ year-old bike). Can this be repaired (i.e. welded) or does it require full parts replacement?
PostPosted: 00:15 - 15 Mar 2021    Post subject: Re: Broken kickstart Reply with quote
So the kickstart shaft snapped, not part of the kickstart lever? A very good welder might be able to drill, slug and weld it but I doubt I'd ever trust it again. You'd also need to strip it down to remove it. At which point you may as well just fit this £25 one off ebay. Don't forget to fit a new oil seal.
https://www.ebay.co.uk/itm/Honda-cb100n-kickstart-shaft-1983-/324073972123
Easy-X
PostPosted: 00:39 - 15 Mar 2021    Post subject: Reply with quote
Alternatively if you mean the kickstart arm has snapped (effectively leaving behind a splined ring on the kickstart shaft) then yes, you can weld that back together but a new one would look nicer Smile
The Learner
PostPosted: 01:02 - 19 Mar 2021    Post subject: Reply with quote
Yes, sorry, the arm/lever! Thanks for your advice.
PostPosted: 13:25 - 19 Mar 2021    Post subject: Reply with quote
Just get a new (used) one. Knowing Honda, they will be the same splines on multiple models. I'd have a look at CG125 ones first off.
The last post was made 5 years, 95 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.11 - MySQL Queries: 13 - Page Size: 43.47 Kb
