Hornet 600 2001
Fair weather rider
PostPosted: 19:22 - 08 Apr 2021    Post subject: Hornet 600 2001 Reply with quote
Honda Hornet 600 2001 model.
Have a flat spot at low revs, when starting off actually, power coming in with a rush, difficult to control at low speeds.
I have noticed that the original silencer has been changed for a Delkevic, would this cause the flat spot?
Help appreciated.
If it seems to good to be true, then it probably is, but buy it anyway.
PostPosted: 19:26 - 08 Apr 2021    Post subject: Reply with quote
Could be, yeah. Has it got any other mods? Is the airbox present? No extra holes in the lid? No leaks in the exhaust etc?
Anything that is not standard in the drivetrain could well cause running issues - but check the small stuff first.
Tdibs
PostPosted: 01:34 - 09 Apr 2021    Post subject: Reply with quote
Are you sure its running on all 4 cylinders? Does it sound rough? Does it cough and splutter hard then kick into some power?
Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000
boundy
PostPosted: 12:37 - 09 Apr 2021    Post subject: Reply with quote
I had a similar problem on my 2000 cbr600f, after much faffing I found 1 of the coil sticks a split in its side, does hornet run the same coil stick set up, might be worth a check
droog
PostPosted: 13:10 - 09 Apr 2021    Post subject: Reply with quote
Are the headers original Honda or are they also Delkevic?
Original Honda headers will have link pipes between 1 & 2 and 3 & 4 down pipes.
Some after market headers don't have the link pipes - I remember hearing that this could result in flat spots/tuning issues.
F18
PostPosted: 15:12 - 09 Apr 2021    Post subject: Reply with quote
And the later Hornet headers (600) had a link between 1-4 & 2-3.
- Odd really as I'm sure the firing order was the same.
Summer is just around the corner
The last post was made 5 years, 194 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 46.47 Kb
