Lacquer over polished aluminium
A100man
PostPosted: 15:24 - 15 Apr 2021    Post subject: Lacquer over polished aluminium Reply with quote
Hi All
Got a couple of jobs where I'm looking to ad some decals over polished ally then lacquer over the top. Solvol autosol leaves a residue so I'm proposing a wipe down with brake cleaner or acetone beforehand. does that sound OK?
c_dug
PostPosted: 15:33 - 15 Apr 2021    Post subject: Reply with quote
I've used pure/99% IPA before on polished brass and it worked perfectly.
This sort of thing: https://uk.rs-online.com/web/p/electronics-cleaners/2274427/?cm_mmc=UK-PLA-DS3A-_-google-_-CSS_UK_EN_Facilities_Cleaning_%26_Maintenance_Whoop-_-Electronics+Cleaners_Whoop+(2)-_-2274427&matchtype=&pla-299936613816&gclid=Cj0KCQjwyN-DBhCDARIsAFOELTlfpl--kPXunhZyd-Sk-N83b4GQ4KEys8oyU81vWE0MufQYX_ssu-EaAmf7EALw_wcB&gclsrc=aw.ds
Pretty sure you can buy actual surface prep wipes specifically designed for the purpose, never looked but I'd bet they're IPA based anyway.
MCN
PostPosted: 18:55 - 15 Apr 2021    Post subject: Reply with quote
Aluminium needs an 'acid etch' (really) to ensure the paint doesn't slough off.
Normally the acid etch has a pigment to let you see where it is.
But the chemical is probably available as a clear coat.
Aluminium and alloy is normally overpainted after smoothing but acid etched before any primer is applied.
Islander
PostPosted: 21:56 - 15 Apr 2021    Post subject: Reply with quote
Yep this^^
Aluminium has a very high affinity for oxygen and oxidises rapidly (the oxide actually protects the surface from further reaction). The layer of oxide is what prevents paint from adhering properly.
The last post was made 4 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 40.76 Kb
