Fast road riding skills
Milesprower
PostPosted: 22:10 - 17 Apr 2021    Post subject: Fast road riding skills Reply with quote
Just a quick one as to where everyone developed their fast riding skills on road, was it track riding, years of trial (and hopefully not) error, advanced rider training courses etc?
milesprower
PostPosted: 22:40 - 17 Apr 2021    Post subject: Reply with quote
Time on a tiddler, school boy trials, etc etc etc?
Hong Kong Phooey
PostPosted: 13:58 - 18 Apr 2021    Post subject: Reply with quote
Almost 30 years of enthusiastic driving has helped me pick up on early warnings of other road users behaviour, and some past mistakes, crashes, and some that didn't end up as crashes but were enough to 'make a note to self'.
But when you throw your leg over a bike some of this changes, obviously. You can't push the edges of tyre grip on a road bike, and get it back in line safely like in most FWD cars, you can't smash the brakes on full on older bikes and let the ABS sort it all out for you.
But you can still use your vision, recognise that overtaking near a junction can be lethal, position yourself for the best view, spot the road surface is crap, drop down a gear to tighten a line, clock the corner opening up and wind on the throttle.
If you want to go quick on any road, always limit your speed to being able to stop within the view ahead, always realise that people will make a u-turn on a blind bend, sheep will emerge from nowhere.
That's the number one rule in my book.
Bike control is something that you can also work on, learning how to brake safely and heavily is a good one for starters, then after that it's cornering confidence, but that can be a sticking point for some as they are afraid of making large steering inputs and can run a bit wide, this makes them think they're already at the limit.
Self control is another, I'm pretty much a 30mph means 30, especially in built up areas. Elsewhere I'm no angel, but I choose where to be a dick, and if a guy is a dick on a b-road in a forest and nobody is there to witness it, was he really a dick?
So for me it's experience, and over time that means less crashes. Only had one on a bike back in 2006, and the only time I was injured, totally my fault. Only one since was somebody running into the back of me while in a car, 2014.
chickenstrip
PostPosted: 14:08 - 18 Apr 2021    Post subject: Reply with quote
No skills, a refusal to admit it, and an awful lot of good luck, tempered by some chronically bad luck, have seen me to the level I'm at today Mr. Green
Milesprower
PostPosted: 15:44 - 18 Apr 2021    Post subject: Reply with quote
Some good replies there...
milesprower
pepperami
PostPosted: 17:36 - 18 Apr 2021    Post subject: Reply with quote
I’m not fast so I can’t answer.
Monkeypony
PostPosted: 17:56 - 18 Apr 2021    Post subject: Reply with quote
Ride fast on the track, ride defensive on the roads.
I'd you go trail braking into every roundabout you come across, even ones you think you know, you're going to come a cropper at some point.
Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU)
trevor saxe-coburg-gotha
PostPosted: 20:41 - 18 Apr 2021    Post subject: Reply with quote
jumpers for goal posts, rolling the ball in dog shit before crossing it for a header, etc etc etc?
MCN
PostPosted: 21:34 - 18 Apr 2021    Post subject: Reply with quote
Riding 'fast' on public roads is subjective as what you think of as fast may be me pootling.
It should take years/several 1000 miles to build skill to maintain a good pace. Where everything gets in your way.
chickenstrip
PostPosted: 21:57 - 18 Apr 2021    Post subject: Reply with quote
Where did you go wrong? Razz
PostPosted: 22:12 - 18 Apr 2021    Post subject: Reply with quote
Trial and error, starting off makign the errors on something that was fairly slow and ineffective. A not inconsiderable amount of thoery collected by osmosis over many years.
Also riding with peoiple who are really good at it. I was out at the weekend and couldn't keep up with my mate on his 250 ninja (twin). I was on a VFR750...
RhynoCZ
PostPosted: 22:30 - 18 Apr 2021    Post subject: Reply with quote
It's simple, OP.
slow bike fast = easy
fast bike fast = scary
smooth = fast
But in all seriousness, always keep the ''as long as I (you) feel safe, it's alright'' approach and you'll be fine. What also helps a lot is to have the right riding habits etched in your brain, so when you get into trouble you know exactly what to do without even thinking about it.
It's stuff like using the brakes gradually, smooth operation of the throttle, take it easy on the slippery stuff (for instance, the white markings on the road tend do be slippery as feck when wet), knowing that braking while cornering will force the bike upright (unless you loose all the grip), if the rear wheel slips under power never fully shut the throttle, reduce it accordingly (to prevent a very violent shift of momentum), and so on.
I feel very old saying this, but even if ABS and TCS means you can be very inconsiderate with the brakes and throttle, and even if ABS works while cornering now, I will probably never put my full trust into those systems while on a motorcycle.
What also helped me a lot, I went to my local unused airfield to try all the emergency stuff in a safe environment.
chickenstrip
PostPosted: 22:39 - 18 Apr 2021    Post subject: Reply with quote
RhynoCZ wrote:
It's simple, OP.
smooth = fast
Hang on, I think I got it...
Slow = fast
Fast = slow
Hard = easy
Easy = scary...
No, wait, give me a minute, I can do this! Confused
chickenstrip
PostPosted: 22:43 - 18 Apr 2021    Post subject: Reply with quote
But no one ever got better at anything by staying in their 'comfort zone'. You can't learn how to go fast by going slow all the time. Trouble is.... Razz
1198
PostPosted: 06:26 - 19 Apr 2021    Post subject: Reply with quote
Ste wrote:
Time on a tiddler....
is seldom time wasted!
I’m sure I read that somewhere.
arry
PostPosted: 08:51 - 19 Apr 2021    Post subject: Reply with quote
I’m sure I read that many, many times somewhere everywhere.
Fixed that for you Thumbs Up
Weisse Schlange
PostPosted: 08:56 - 19 Apr 2021    Post subject: Reply with quote
Riding for over 30yrs makes you a bit quick.
For me though, my pace increased dramatically when I bought a supermoto and started riding with a club racer.
Following someone fast and learning always helps.
I'll finish by saying , as far as I'm concerned, very fast road riding is dead. Finished.
I've bought a supermoto again to keep top end speeds down and will be using it on track as well.
There are times and places, but they are getting fewer and further between.
The cops will ruin your life for going fast, even if you are doing it safely. Kinda makes it too much hassle for me now.
Hing Oan
chickenstrip
PostPosted: 12:23 - 19 Apr 2021    Post subject: Reply with quote
Partly why I took more to touring. You still get your fix enough, but you get far more from it all beyond that.
PostPosted: 14:59 - 19 Apr 2021    Post subject: Reply with quote
A lot of my early riding knowledge came from the final few pages of Bike and Ride mag where they used to do little riding tips columns. I built on that, a little trial and error, a little training, a little bit of trackdays, a little bit of riding with others (both good and bad).
Diggs
PostPosted: 15:13 - 19 Apr 2021    Post subject: Reply with quote
I was quite fast in my day so I've been told. Much steadier now though.
My tip - take it easy and watch what the fast folk do, but don't try to keep up or you'll die. Slow in, fast out and you'll speed up.
As a previous poster said, fast riding in the UK isn't what it used to be...
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
chickenstrip
PostPosted: 15:17 - 19 Apr 2021    Post subject: Reply with quote
I picked up a couple of techniques from Road Racer magazine. That was a brilliant publication. I think that's what it was called. Alan Cathcart was a major contributor, plus Matt Oxley and others, interviews with racers about their technique and so on.
When I had my GSXR750, I got so I could rear wheel steer on a couple of favourite corners. Then I thought, what the feck am I doing this on the road for, it'll only end in tears Laughing One was a particular roundabout exit, but you used to get some HGV traffic there, and I thought, what if this sucker suddenly grips and throws me over the high side into the path of one of those? Shocked I stopped doing it Laughing
And as I said in another thread, I honed things a bit by riding a lot on those great Welsh roads Smile
Rusty as feck again now though. Don't think I'll ever get back to that standard. Not inclined to try tbh.
Weisse Schlange
PostPosted: 18:43 - 19 Apr 2021    Post subject: Reply with quote
https://i.ibb.co/Rz6dB9R/962-F0-EDF-948-C-434-B-AD0-A-D9-C0-AD639700.jpg
My new instructor.
Hing Oan
hellkat
PostPosted: 18:52 - 19 Apr 2021    Post subject: Reply with quote
I don't really do fast, even when I'm not on a Harley.
But the thing which I have discovered is my Thing (filtering) is just a matter of practice and red lipstick.
Mr. Green Thumbs Up
Milesprower
Yeah great stuff...
milesprower
Weisse Schlange
PostPosted: 18:58 - 19 Apr 2021    Post subject: Reply with quote
Filtering just feels sooo,, superior !
Makes my day tbh.
Hing Oan
The last post was made 5 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.03 - MySQL Queries: 15 - Page Size: 138.34 Kb
