Suzuki GSX1100G Carburetors
gandy666
PostPosted: 18:41 - 25 Apr 2021    Post subject: Suzuki GSX1100G Carburetors Reply with quote
Hi there
I've had problem with my Suzuki GSX1100g idling, for some time.
Carbs came off last week and it turns out the air mix screws were put in by Popeye. Trying to get them drilled out at the moment, but if this is not possible, does anyone know which other carbs will fit?
They are 36mm Mikinu BST36 CV's. Set of four. Any suggestions as to what I can do to get the screws out, or recommend an engineering firm who can remove without destroying the bodies?
Even better, has anyone got a set they may wish to part with? I'll swap the jets etc over. Mines are perfect, apart from the airmix screws being jammed in.
Thanks.
redeem ouzzer
PostPosted: 19:54 - 25 Apr 2021    Post subject: Reply with quote
If the air screws have been tightened that hard then the carb bodies will be f@@ked anyway as the tapered part of the screw will have spread the hole in the body,
GSXR1100 K/L, GSX1100F all use 36mm bodies.
Be a REAL MAN!
sickpup
Old Timer
PostPosted: 21:30 - 25 Apr 2021    Post subject: Reply with quote
Doesn't the L have 40mm? not certain just checking.
redeem ouzzer
PostPosted: 10:11 - 26 Apr 2021    Post subject: Reply with quote
They started with the 40mm on the M model as far as I know. My L has BST 36's for certain.
Be a REAL MAN!
virus
PostPosted: 19:59 - 26 Apr 2021    Post subject: Reply with quote
Ive got a set of bandit 12 carbs on my G.
own: 81 xs1100g...
JackButler This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
virus
PostPosted: 18:06 - 27 Apr 2021    Post subject: Reply with quote
JackButler wrote:
Teflonian waffling bollocks
Im amazed, you managed to type so much and have almost NONE of it be anywhere near the truth... maybe you should stick to bullshitting in random banter not the workshop section. Rolling Eyes
own: 81 xs1100g...
TaffyTDM
PostPosted: 18:27 - 27 Apr 2021    Post subject: Reply with quote
Where is the teffers out of interest? Has he got the covids? We should be told (in less than 500 words ideally)
The last post was made 4 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 56.83 Kb
