| t121anf |
 t121anf World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 21:28 - 28 Apr 2021 Post subject: |
Simple.
Buy a premixed glycol based coolant. Ensure it has minimum 2% inhibitor in it. Some have many haven't. Rule of thumb, if it has it will say on the container if not it won't say.
Drain the old coolant into a container for disposal at your local recycling place/landfill.
Fill with clean tap water and drain again to remove all the old coolant and any detritus. Tap is fine for a cooling system. (Not good for batteries.)
You might feel like adding a flushing chemical and running the engine with that. Up to you.
Make sure the system is drained.
There may be areas that can collect a bit of dead cool a t. Bends of hoses. You should try to get as.much old coolantnout as practical.
Then make sure all the plugs are back in, hoses connected and any drain cocks closed.
Fill the radiator slowly with the new premix.
If you fill slowly it helps prevent air bubbles forming and collecting in the 'high points' of the engine.
Air doesn't transmit heat energy as well as liquid so it creates Hot Spots. Hot Spots can lead to thermal damage to the metal of the head or block. Cracking. £££.
Fill until the radiator is full. Squish the hoses to push any air bubbles out. Top up if the level drops.
Fit the radiator pressure cap.
Fill the expansion tank to the Max Level.
Make sure you set the level cold.
Run the engine up to temp. If there's a fan it should come on as the thermostat opens and cool the coolant.
You should switch off and allow it to cool down a bit until you can put your hand on the metal without getting toasted.
Check the expansion tank level.
Job Jobbied.
I was interested in trying this waterless coolant.
https://en.m.wikipedia.org/wiki/Waterless_coolant
No water so won't evaporate at normal temps.
https://www.eurocarparts.com/p/evans-power-cool-180-waterless-coolant-2ltr-993778002
You don't have to buy from Eurocarparts of course.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| Robby |
 Robby Dirty Old Man
| Easy-X |
 Easy-X Super Spammer
 Posted: 12:48 - 29 Apr 2021 Post subject: |
For the money you can't beat basic de-ionised water (+ antifreeze + rust inhibitor, i.e. bog standard coolant) for removing heat. I'd be wary of Evans, I don't think it plays well with non-ferrous metals in the long term. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| MCN |
 MCN Super Spammer
 Posted: 14:12 - 29 Apr 2021 Post subject: |
| Easy-X wrote: |
For the money you can't beat basic de-ionised water (+ antifreeze + rust inhibitor, i.e. bog standard coolant) for removing heat. I'd be wary of Evans, I don't think it plays well with non-ferrous metals in the long term. |
No need for fancy wahtur, as I said.
Ive filled engines that survived for years on Best Yorkshire tap. Its 9 on the Richter scale. (Scale as in gauge not as a pun)
Yorkshire Water Quality Report
Calcium 105.6 mg Ca/l
Magnesium 5.1 mg Mg/l
I found that the hardest thing in Hull was the tap water there. And some of their wimin.
Scottish Water Quality Report
'Less than 60mg of calcium per litre' Icouldn't find levels for calcium in reports for Glasgow area.
Manganese 52 µgMn/l
You can have a great/the greatest cup of Tetley at my bit if you visit. (I only buy Leaded milk.)
I bet your the type of man who puts water in a Single Malt.
Waterless coolant won't be a problem in non ferrous engines as it's glycol. If glycol was an issue then it wouldn't be used as coolant by the OEM. With inhibitors on board.
I don't care what you say. I'm fecking going to fill my bike with waterless coolant..
A study.
https://www.hindawi.com/journals/ijc/2019/9020489/ ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Easy-X |
The last post was made 4 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
