Broken rollers
bazzaboy2010
PostPosted: 13:23 - 04 May 2021    Post subject: Broken rollers Reply with quote
August 2020 I bought some new rollers and belt from max Honda spares on eBay. Well yesterday I broke down and at full throttle I have hardly any revs and no drive. Got the bike back home and took a look if the belt was broken which clearly would not of being any thing to do with the Rev problem anyway. But the belt was ok. But wha5 I could not believe which you will see in the picture is the state of the rollers that was removed. So now I am worried that because they look like this it is now ruined my engine.
WD Forte
PostPosted: 15:10 - 04 May 2021    Post subject: Reply with quote
How has that ruined the engine?
I only see 4 rollers where's the other two?
looks like a case of buy cheap buy twice to me
Best case, new rollers
Worst case, just buy a new cvt set and fit it.
bikers smell of wee
steve the grease
PostPosted: 00:22 - 05 May 2021    Post subject: Reply with quote
Cheap parts off ebay. Tell meall about it.
New lower arms for my car "Quinton Hazell" brand ( used to be a respected parts brand) Original arms> 18 years. Replacement arms 8 months - rubbers perished to fuck.
Motorbike fork gaiters- perished away before I even finished doing the bike up.
Conclusion The Chinese have some way to go where rubber products are concerned.
Bazzaboy09
PostPosted: 09:15 - 05 May 2021    Post subject: Reply with quote
Why would I have no revs after this happen?
Only took photo of the 4
WD Forte
PostPosted: 14:54 - 06 May 2021    Post subject: Reply with quote
is the subframe OK?
bikers smell of wee
Robby
Dirty Old Man
PostPosted: 17:07 - 06 May 2021    Post subject: Reply with quote
Because your engine was trying to spin a transmission full of broken parts. Replace all the broken bits with decent bits and it should be fine.
On a scooter, stuff going wrong in the gearbox will not affect the engine. Two different things bolted together. They don't even share an oil supply, because the gearbox runs dry.
Bazzaboy09
PostPosted: 19:32 - 06 May 2021    Post subject: Reply with quote
There must be another problem then that has happen at the same time. Bike will not start now and it seems it's running to rich. That's why in thought it was maybe of knocked my timing out has you have to turn the variator to get the correct timing
Nobby the Bastard
Harley Gaydar
PostPosted: 21:29 - 06 May 2021    Post subject: Reply with quote
The crank and valve gear are not dependant on the variator The variator is just a convenient way to turn the crank and thus the valve gear
Its the the same as using the back wheel to turn the engine.
Triumph Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 11:57 - 07 May 2021    Post subject: Reply with quote
Is the transmission all fixed? If not, fix that before you go looking for problems with the engine. If the variator is in pieces then you're trying to start it with a seriously light flywheel. Engines don't like to run at low speed with little or no weight in the flywheel.
Always fix the problem you know about before you go hunting for more. Otherwise you go down the slippery slope and end up with a bike in its component pieces strewn across your garage floor, and up with the fun or daunting task (depending on your point of view) of putting it all back together.
Bazzaboy09
PostPosted: 12:00 - 07 May 2021    Post subject: Reply with quote
Put back together and still got the problem
Easy-X
PostPosted: 14:15 - 07 May 2021    Post subject: Reply with quote
Let's go back to basics: with the belt/variator off take out the spark plug and turn over the engine by hand. Rotating smoothly? After that it's check for spark and fuel...
Bazzaboy09
PostPosted: 10:26 - 09 May 2021    Post subject: Reply with quote
Well looks like the broken rollers did fxuk the engine.
Nobby the Bastard
Harley Gaydar
PostPosted: 10:51 - 09 May 2021    Post subject: Reply with quote
Holy fuck.
There's no chance that the rollers did that.
Bazzaboy09
PostPosted: 13:04 - 09 May 2021    Post subject: Reply with quote
Well if they jammed when I was going around 50mph. Then maybe it did.
Nobby the Bastard wrote:
Holy fuck.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:31 - 09 May 2021    Post subject: Reply with quote
No it wouldn't. The top end would have stopped at exactly the same rate as the crank.
Easy-X
PostPosted: 16:29 - 09 May 2021    Post subject: Reply with quote
Slight bit of stress on the engine... pop! there goes the Chinesium casting Wink
£20 for a rocker arm assembly?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:07 - 09 May 2021    Post subject: Reply with quote
It would rely on the valve and rocker being stronger than the casting for the piston to twat it and the casing break before the valve and rocker.
This wouldn't happen.
I'm betting the fucker siezed due to bad manafacturing/luck and the rollers getting twatted as a result.
sickpup
Old Timer
PostPosted: 01:07 - 11 May 2021    Post subject: Reply with quote
The flat spots on the rollers are a normal wear pattern for rollers that didn't roll but were sliding instead. Out of interest did you grease the rollers before fitting? There are two sides to the argument, one says to grease and one says not and to be honest I'm not sure which is right.
The top end damage wasn't caused by the rollers, it was caused either by the piston hitting a valve or lack of lubrication to the top end. As the cam caps look like they are bolted down fine it is unlikely caused by a bad casting.
Nothing here really helps you out, you will only find the cause as you strip the engine.
What scooter was it?
jeffyjeff
PostPosted: 07:01 - 11 May 2021    Post subject: Reply with quote
Perhaps at or immediately prior to failure, the disintigrating rollers allowed the engine to overspeed. No rev limiter on a CVT scooter. It's a credit to fine Chinese craftsmanship that it did not suck a valve. Upon disassembly, inspect for piston to valve contact, bent connecting rod, camshaft and pushrod damage. You might consider finding a used engine rather than address the collateral damage. Wink
sickpup
Old Timer
PostPosted: 09:16 - 11 May 2021    Post subject: Reply with quote
Except that doesn't work. Engine speed controls how far the rollers are flung out, the rollers do not control the engine speed.
jeffyjeff
PostPosted: 13:27 - 11 May 2021    Post subject: Reply with quote
Consider the mechanism beyond the rollers. The rollers control the position of a sliding sheave which drives the belt at various ratio dependent on engine speed. The sheave in turn drives the rear wheel which is the load that limits engine rpm. Once the rollers are destroyed, all load on the engine was lost. Without load, the engine is permitted to accelerate uncontrolled until kapow!! (bad things happen) Crying or Very sad It is a balanced system, and I agree that rollers do not control engine speed directly. But the speed ratio of the variator and rolling resistance do limit engine speed.
wr6133
PostPosted: 13:35 - 11 May 2021    Post subject: Reply with quote
Limiter should stop it passing redline though, they do have them when I built up shite-ped the limiter was what stopped my dreams of going really fast/blowing the thing up Laughing
I lunched many rollers in that ped too without killing anything else. Just loss of power and embarrassing limp home.
Wonder if the rockers are standard, you can get some shockingly shit "perfomance", parts for GY6 clones. I've seen oval barrels and pre-cracked heads. Gash grade metal for rocker blocks wouldn't surprise me.
sickpup
Old Timer
PostPosted: 14:26 - 11 May 2021    Post subject: Reply with quote
It can't happen, the belt will slip instead.
The last post was made 5 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 120.33 Kb
