Honda CBR F4i & Hornet Speed Sensor Compatibility
Campbell SOUP
PostPosted: 17:49 - 11 May 2021    Post subject: Honda CBR F4i & Hornet Speed Sensor Compatibility Reply with quote
Hi all! It looks like the speed sensor on the CBR has gone. At first it couldn't read speeds over 40 mph, and now it just reads 0 everywhere.
Problem is, some retailers are asking for £200+ for a new one! That's 10% of the bike's value spent on a sensor..
I've found some other Honda speed sensors on ebay going for less, namely from Hornets, I'm wondering if anyone has any experience with whether or not a sensor from a Hornet (or any other Honda bike from that time) would fit? The part numbers are different, but they look very similar.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:54 - 11 May 2021    Post subject: Reply with quote
If the part number is different the odds are it won't work.
Triumph Sprint ST 1050
Campbell SOUP
PostPosted: 18:03 - 11 May 2021    Post subject: Reply with quote
Yeah I don't think I'd bother rolling the dice, just thought it was worth seeing if any tight arses like me had tried in the past
Hong Kong Phooey
PostPosted: 14:19 - 15 May 2021    Post subject: Reply with quote
In theory, it would work if it's a Hall effect sensor, but whether the bolt holes line up in the correct position is another question.
As they're so reliable, what makes you think it's the sensor and not the wiring?
Campbell SOUP
PostPosted: 20:25 - 15 May 2021    Post subject: Reply with quote
Are they reliable? I've read on forums that speed sensor failures are common. Forum posts are anecdotal though obviously.
I reckoned it was the sensor after taking a look at the connector and finding it to be clean. A general wiggling of the wiring didn't improve anything.
I did manage to find a sensor off Ebay going for £30, which I've fitted today. I'm able to read speed again with the wheel off the floor spinning the wheel by hand, which is good, but it needs a proper road test before I call it job done. The last sensor was working below speeds of 40mph for a bit before failing completely, so I need to make sure it's not doing the same.
jeffyjeff
PostPosted: 00:58 - 16 May 2021    Post subject: Reply with quote
Don't forget to make sure the sensor-tone wheel air gap is within specs. Too much gap = erratic sensor performance.
Hong Kong Phooey
PostPosted: 10:21 - 16 May 2021    Post subject: Reply with quote
Campbell SOUP wrote:
Are they reliable? I've read on forums...
Anecdotally yes, it's always the ring, wiring or connector on the ABS, crank, or speed sensors I've ever dealt with.
The sensor is very simple, no moving parts, and is sealed from the elements.
Glad you got it sorted. Thumbs Up
Campbell SOUP
PostPosted: 16:37 - 16 May 2021    Post subject: Reply with quote
I'm not sure how I'd adjust the gap on this speed sensor setup. It bolts into the gearbox above the output shaft I think, with an o-ring around the sensing 'tube' to seal the gearbox. Any shimming would screw with the o-ring seal, and there's no obvious way to measure the gap without basically taking the engine apart.
Cheers! Not a bad result for thirty quid and an afternoon in the garage. Took the bike for a spin just now and it's reading speed like a dream Thumbs Up
PostPosted: 18:54 - 16 May 2021    Post subject: Reply with quote
I'd hope it's reading speeds like a CBR. Honda Dreams read speed highly erratically and not much over 70mph. Laughing
jeffyjeff
PostPosted: 19:06 - 16 May 2021    Post subject: Reply with quote
Sorry, I guess when you said you got a reading by spinning the wheel, I assumed front wheel. Most ABS speed sensors are adjusted with shims, and that's what came to my mind. My VFR had a mechanically driven speed sensor, off of a coupling on the countershaft sprocket. You might have something similar to that.
Campbell SOUP
PostPosted: 20:10 - 16 May 2021    Post subject: Reply with quote
Ah, I've never had a bike new enough to have to deal with an ABS sensor Laughing
jeffyjeff
PostPosted: 17:38 - 17 May 2021    Post subject: Reply with quote
Ah! Well, my bike is 19 years old, and has aged, clunky ABS. Works when needed, though. Wink Never gave ABS much thought until junior put himself in the hospital in a situation where ABS might reasonably have altered a bad outcome.
Campbell SOUP
PostPosted: 18:00 - 17 May 2021    Post subject: Reply with quote
It would have saved me from sliding my first bike down the road the day after I bought it Laughing Hope he recovered ok!
jeffyjeff
PostPosted: 00:49 - 18 May 2021    Post subject: Reply with quote
He's OK now. Been a long recovery though. Thanks for the thought.
The last post was made 5 years, 77 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.44 - MySQL Queries: 13 - Page Size: 84.37 Kb
