ns125r-k help please?
greenwood2000
PostPosted: 13:35 - 13 May 2021    Post subject: ns125r-k help please? Reply with quote
So i've got an ns125r-k 1989 model.
When i bought it the guy listed a few jobs left to finish, and he doesn't think it was jetted properly. Can anyone tell me what all the stock jets are, and where to find em? I can't seem to find a website that makes it easy to pick the jets out.
It's got a huge flat spot starting at about 6krpm, which just totally kills the power. If there's anything else to check/possible causes that'd be great as well. Running the stock airbox and exhaust at the moment so i presume the jetting just needs fixing?
Cheers.
PostPosted: 14:08 - 13 May 2021    Post subject: Reply with quote
You sir are the jammiest man who ever lived.
You come onto a forum which originated not as an NS125 forum, but as an NSR forum.
Arrow You find a man whose first bike was identical to your bike.
Arrow Who bought a Haynes manual back in the day
Arrow who retained said Haynes manual
Arrow Who recently retrieved it from his parents loft, not deliberately but in a box of junk his parents wanted rid of
Arrow Who then placed said Haynes manual in his library of Haynes manuals instead of getting rid
Arrow Said library is easy access from where said man currently sits
Arrow The man had the inclination to walk down to the garage to retrieve said Haynes manual and take a photo of the correct page.
https://www.bikechatforums.com/files/ns125r_carb_spec_small.jpg
greenwood2000
PostPosted: 14:57 - 13 May 2021    Post subject: Reply with quote
Brilliant!
Cheers mate
bit of a question though. It says main and slow jet sizes, but what do i need for the rest of em? there's a power jet and starter jet, and a needle jet too i believe?
thanks for your help
PostPosted: 15:06 - 13 May 2021    Post subject: Reply with quote
greenwood2000 wrote:
Brilliant!
Cheers mate
They should be standard. The needle jet is adjusted by the clip position on the needle, and if your previous owner messed with the starter jet... god help you!
It's possible the needle jet might be worn with use, but if I were you I'd start with those jets listed, forget the rest and then see how it runs.
Nobby the Bastard
Harley Gaydar
Brilliant!
Cheers mate
Needle jet is the mains, starter jet is the pilot.
Never heard of a power jet.
Triumph Sprint ST 1050
PostPosted: 15:10 - 13 May 2021    Post subject: Reply with quote
Brilliant!
Cheers mate
Two strokes have power jets so they don't lean out at the top end. Some carbs have a fixed starter jet which is just a hole in the carb opened when you pull the choke.
Also the needle jet is not the main... It's the jet that takes over from the idle jet from 20ish % to 50% throttle where the main takes over. The power jet usually makes the bike run super rich right at the top end for reliability.
greenwood2000
PostPosted: 16:00 - 13 May 2021    Post subject: Reply with quote
cheers lads that's great. I'll get it all back to stock and let you know how it goes
Robby
Dirty Old Man
PostPosted: 13:04 - 14 May 2021    Post subject: Reply with quote
I had one of them.
Check the rear shock linkage. They tended to wear and develop a lot of play 20 years ago, so will probably need their second rebuild by now.
Possibly a pain in the arse to de-restrict the exhaust. Conventional wisdom used to be to buy an aftermarket one, but it may be possible to DIY it now. Tools like welders were expensive back then and commonplace now. If you're lucky it just needs to have a washer drilled out in the collar.
stevo123
PostPosted: 19:16 - 08 Jun 2021    Post subject: Reply with quote
Can confirm, washer in downpipe section of exhaust and restrictor plate between carb and reeds. Also check exhaust port is clean - a lot of years ago when I had my exhaust off to get the restrictor out the port was really furred up. Probably caused by previous owner using shit 2T oil made for chainsaws or something not as fussy.
The last post was made 5 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 63.57 Kb
