Valve clearance slighty off. Should I worry?
hornet_guy
PostPosted: 16:57 - 14 May 2021    Post subject: Valve clearance slighty off. Should I worry? Reply with quote
Hello,
I checked the valve clearances of my 2000's Hornet 600 for the first time and discovered 3 out of 4 cylinder exhaust valves (6 valves) are off. The workshop manual indicates 0.22 +- 0.03 mm and I measured around 0.28 mm in all of the 6 valves. I know this is out of spec, however I'd like to know, in your experience how bad is this. Should I worry? How much would you say is too much?
Thank you.
PostPosted: 17:12 - 14 May 2021    Post subject: Reply with quote
That would not bother me at all. Too tight would be a concern, too loose not so much.
jaffa90
PostPosted: 17:14 - 14 May 2021    Post subject: Reply with quote
I agree,
https://www.manualslib.com/manual/1068381/Honda-Cbf600sa.html?page=79#manual
The CBF 600 SA is the same as your reading.
hornet_guy
PostPosted: 17:17 - 14 May 2021    Post subject: Reply with quote
Hmmm, really? Take into account that in my bike (shims) the greater the gap, the tighter the valve is. Does this change your answer?
PostPosted: 17:26 - 14 May 2021    Post subject: Reply with quote
Nope. when we refer to valves being 'tight' it's the gap we're referring to not the closing pressure. A tight gap (less clearance) shortens the time the valve is seated thus reducing thermal transfer from the valve head to the seat. A loose gap allows for greater cooling and longer valve lifespan.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:46 - 14 May 2021    Post subject: Reply with quote
Thats so wrong. You have it completely back to front.
Triumph Sprint ST 1050
hornet_guy
PostPosted: 17:57 - 14 May 2021    Post subject: Reply with quote
jaffa90 wrote:
I agree,
That's a good point for reference, although it's not the same block. Thanks.
hornet_guy
PostPosted: 18:00 - 14 May 2021    Post subject: Reply with quote
Thanks for the detailed explanation. It makes all the sense.
hornet_guy
PostPosted: 18:02 - 14 May 2021    Post subject: Reply with quote
Yeah, sorry you're right.
droog
PostPosted: 19:24 - 14 May 2021    Post subject: Reply with quote
If you're interested in this kind of stuff, check out this video on valve clearances - the guy uses a model to explain the relationship between cams, buckets, shims and valves and what creates a tight/loose valve condition.
Good way to visualise what is going on.
https://www.youtube.com/watch?v=Ou_3Qo8wTec
MCN
PostPosted: 20:35 - 14 May 2021    Post subject: Reply with quote
If there is no gap between the top of the valve stem and the valve drive (cam linkage) then the valve will not seal effectively.
If not sealing effectively then cylinder compression is reduced.
Reduced cylinder compression reduces engine power.
High power from internal combustion engines rely on high cylinder compression.
This is the main symptom of tight valves.
In addition, contrary to what some folk imagine, as the engine runs and wears the gap is reduced.
Until zero gap.
It also can have a minor effect on timing.
How well a cylinder is charged with fresh air and then purged of exhaust.
hornet_guy
PostPosted: 21:29 - 14 May 2021    Post subject: Reply with quote
Until zero gap.
Thanks. I am very inclined to leave it alone after all the comments. If the wear produces tighter clearances then I think, I won't bother with the pain of reshimming.
The last post was made 4 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 75.97 Kb
