| Anthonyyb |
 Anthonyyb L Plate Warrior
 Posted: 22:17 - 19 May 2021 Post subject: Yamaha YBR 125 - Instant stall after replacing clutch plates |
Hi, I was getting a lot of slip on my YBR 125 so I had a look at my oil and clutch plates. They were pretty bad and the oil didn't look like it had been changed in ages... I only recently bought the bike.
I ordered the new plates and they are an identical fit. Removed the casing, the clutch basket, popped in the new plate, then metal plate, and so on (4 plates + 3 metal plates between each). Tightened the basket back down with the 4 springs until they were snug. Put the casing back on, starter motor and kick-start.
Just put new oil in. When I start in neutral all sounds fine, as soon as I shift into first with the clutch lever fully in it stalls quite badly and I go flying forward.
I didn't play with the clutch cable or adjustment, do you think it could be this? Or maybe I've tightened the basket too much which means it won't release even when the lever is pulled?
Any thoughts on what to check would be appreciated. I'd prefer to try things outside of the casing first as I don't want to waste the oil I just put in by opening it up again
Thanks ____________________ Yamaha YBR 125 2010 |
| Easy-X |
 Easy-X Super Spammer
| Pete. |
 Pete. Super Spammer
| jeffyjeff |
 jeffyjeff World Chat Champion
 Posted: 07:01 - 20 May 2021 Post subject: |
In all probability, the oil looked so bad because it had a lot of burnt clutch plate material floating around in it. It's a good thing you changed it. As for your clutch, here are a few thoughts:
It is not likely that overtightened pressure plate bolts are preventing the clutch from releasing if the other parts are correct; the bolts bear against the springs, not the pressure plate directly.
Did you replace the metal plates as well as the friction plates? Old metal plates could be warped from heat, affecting the thickness of the clutch pack. Discoloration is a sign of overheat.
Are the springs correct? The previous owner might have swapped the clutch springs in a misguided attempt to correct a slipping clutch. Wrong springs can bind on assembly, preventing the fresh clutch pack from releasing (unlikely, but possible). Likewise, the clutch could have bound up on assembly if you were inattentive, or did not tighten the assembly evenly as it went together.
Also, problems with the push lever assembly, bellcrank, or push rod might not be allowing proper action of the push rod against the pressure plate. ____________________ History shows again and again how nature points out the folly of men - BOC |
| Anthonyyb |
 Posted: 16:09 - 20 May 2021 Post subject: |
Thanks for all the replies, you responded a lot sooner than I thought anyone would!
| Easy-X wrote: | Did you soak the plates in oil before fitting or just lob 'em in dry? People have various opinions on this point...
It sounds like the clutch isn't disengaging when you pull the lever. Quick test you might try without the engine running is to lob it in gear and try rocking the bike back and forth. Obviously the back wheel will lock up but if you pull the level does anything happen - slightly less resistance?
If the lever does nothing effectively you'll probably have to take the clutch apart again and see if there's something you've missed. |
Yes I soaked them for about 18 hours (I had read it should be 24 but wanted to start while there was a gap in the rain so did it early).
I will give it a go at rolling in gear while the engine is off as that requires little effort to test. I won't force it in case I break something else!
| Pete. wrote: | Anthony, presuming that you have not assembled it wrong it's likely that fitting a new clutch has increased the stack height and added clearance to the pushrod gap which means that pulling the lever isn't pushing the plates apart enough. If you remove the cover you'll find a screw and locknut in the middle of the clutch pressure plate. Loosen the nut wind the middle screw in until you feel it touch the pushrod. Back it off about 1/2 to 3/4 of a turn (the manual will tell you the proper amount but at least some clearance is required) and tighten the nut. Now try the lever before re-fitting the cover.
BY the way looking at the parts diagram it seems that the design is such that as the clutch wears the clearance will disappear. It's quite possible that this was the cause of your slipping and that your clutch onle needed some adjustment in the firt place, rather than replacement.
I had tried to do a search on how to adjust the 'pushrod' (also not knowing that was what it was called yesterday as this is my first manual bike... I've had a few scooters before but never really did any engine work apart from oil/filters/belt) the clearance was something that entered my mind when I was looking at the difference between the old and new plates but I wasn't sure I needed to adjust something or if the springs would do that for me. I think this is probably the issue and I will just have to put some fresh oil in again after taking a look.
That also makes a lot of sense with adjusting it as they wear as the spacing becomes greater... It was fairly cheap and no harm in me getting new plates but it is good to know that on each service I should check the spacing to reduce the slip.
| jeffyjeff wrote: | It is not likely that overtightened pressure plate bolts are preventing the clutch from releasing if the other parts are correct; the bolts bear against the springs, not the pressure plate directly.
I only replaced the friction plates, I had seen a video showing that the if the metal plates look fairly good you can just clean them a bit to get slimy oil off and they should be ok. These didn't look too bad actually compared to the rest.
I will try to look at each component in detail when I open it up again to see if anything doesn't look as per the manual i.e. springs, the length of the 4 bolts that hold the springs in etc.
Just to note on thoughts that it might be another problem - the bike was running fairly smoothly for the week or so that I have had it bar the clutch slip so I think it is likely only something connected to me taking it apart and the bits that I removed... I'm thinking it is the pushrod now and then I guess I will need to adjust the clutch lever as well. I will wait for the wind and rain to die down a bit to prevent crap blowing into the casing!
I did take some pictures as I was re-assembling so when I work out how to attach those I will. You will probably spot that there is some sort of chewed up washer behind the pushrod which it was like before and didn't cause any issues, might be worth me ordering a replacement before I open it up again though?
Thanks!
Edit: I think I've attached the pic now, this is 3 friction plates and 3 metal plates, just before the final friction plate went on the end.
Do you know if it is easy to replace and adjust that washer in the middle myself or best to leave it if its not causing any harm? ____________________ Yamaha YBR 125 2010 |
| bikenut |
 bikenut World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 19:00 - 20 May 2021 Post subject: |
Leave the tab washer along it's doing it's job now. If you have to work on it again order a new one.
BTW the pushrod gap does not open up as the plates wear it gets smaller until the pushrod is eventually touching the release bearing all the time and that's what makes your clutch slip.
So many people fail to grasp the fundamentals of adjusting cable clutches. I've posted it here many times but once more won't hurt.
There are usually two things to adjust on a cable clutch - the pushrod clearance and the cable free-play (some cable clutch bikes don't have a pushrod and those mostly only have cable adjustment). Sometimes adjusting the cable free-play can have the effect of adjusting the clearance but it's not the proper way to do it.
First you loosen the cable adjusters. Usually this means screwing in the threaded adjuster at either the engine end or the lever end so that there's a lot of slack in the lever.
Next you adjust the pushrod clearance. This varies from bike to bike - on your bike it's the adjuster under the clutch cover, on other bikes it can be the other end (a Bandit for instance has the screw and locknut under a rubber grommet in the sprocket cover). Once you have adjusted the pushrod you then go and set the cable free-play by winding the cable adjuster back out until you are happy with the lever action. You MUST have some free play and it gets less when you turn the bars full lock so check that you're not losing all your slack when you turn full lock both ways.
After that you just make sure the locknuts are tight and you're all set. ____________________ a.k.a 'Geri'
| jeffyjeff |
| Pete. |
 Pete. Super Spammer
 Posted: 19:18 - 20 May 2021 Post subject: |
Brand new clutch. Why would the plates be warped? ____________________ a.k.a 'Geri'
| jeffyjeff |
| Anthonyyb |
| Pete. |
 Pete. Super Spammer
 Posted: 22:36 - 23 May 2021 Post subject: |
Well done. Not being able to select neutral from 1st is a common fault. You might be able to improve it a bit by re-adjusting the pushrod for less clearance or even reducing the cable free-play, but it could equally be a sign of warped steel plates or it might even be the wrong grade of oil. My guess is that it will repidly improve.
You could get into the habit of snicking it into neutral from second as you approach a stop. You shouldn't need to find neutral from first that often anyway. ____________________ a.k.a 'Geri'
The last post was made 5 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
