I plan to ride my bike to work instead of car
WilsonBishop
PostPosted: 09:07 - 21 May 2021    Post subject: I plan to ride my bike to work instead of car Reply with quote
Top Tips For Working With Fleece
The best thing about the fleece is that no matter what body type you have or no matter how choosy you are, this fabric is suitable for everyone. It is one of the most versatile fabrics you can find in the store and can make almost any kind of project out of this. The fleece fabric is made up of the polyester fabric that is stretchable, warm and soft in nature to provide comfy feeling to your skin.
These amazing properties of this fabric are attractive but due to these qualities, this fabric behaves differently as compared to the rest of the fabrics. If you have the best sewing machine for beginners then it will be quite easy for you to handle fleece in the best possible way. Let’s have a look at some of the tips and tricks you can apply at the time of sewing fleece.
1 - Decorative Stitches:
Fleece comes in different types and whenever you are working on this kind, you have to analyze what type of stitches and embellishment this fabric is capable of taking? In some of the cases, you may feel that you can’t use embellishment or long stitches on the fabric. In this case, it’s a time to use decorative stitches from your sewing machine and let your machine show the skills.
Before using decorative stitches, take a small piece of fleece fabric and test out the settings of decorative stitches of your sewing machine. As fleece is a sensitive fabric so you better check the settings of the decorative stitches than regret in the end. Once you are satisfied with the tension and quality of the stitches, then you can move on.
2 - Embellishments:
Of course when you are sewing something fancy then how your work can be done without using embellishments on the fabric. Some fabrics have the ability to handle embellishments really well no matter if they are heavy in weight. Fleece looks tough but it can’t handle too many embellishments and you have to take care of it while sewing to save fabric from damage.
If you have to use some buttons and snaps on the fabric then the best way to use them is to apply to interface and then attach whatever you want to. Even if you are attaching snaps and studs to the fabric, then fleece is not able to support these either. You definitely have to use interfacing to make sure the embellishments are going to hold the place strongly.
3 - Nap Direction:
When working with the fleece, you can see the fluffy and brushed look and at the time of sewing, it’s important to analyze the direction of the nap. The fibers of the fabric must be running in one direction and when you are laying this out, make sure that the line of the fiber is straight. When you are about to sew fleece then always mark the fabric from the right side with the help of taping.
Note the direction of a nap before cutting and in all the pieces, the direction must be the same. A small change in direction is going to change the cutting pattern and you have to trim it later. If a nap is going to be different then you will be able to see a disturbance in the nap in the end. You can keep tame the fiber of the fleece while using best rated sewing machines for beginners and achieve the desired results.
4 - Eliminate Bulk:
As fleece fabric is a bit thick in nature so once you are done with the sewing, you may see the bulk layers of the fabric. Now you have to use the grading seam technique to trim the bulk and make it close to the stitching line. The best way to reduce the bulk from the fleece fabric is to keep an eye on the number of layers you are sewing inside.
Once you see how the layers are getting thick then you can trim them down with the help of pair of scissors and the seams must be crisp and thin. It should not be uncomfortable in wearing. If you will swap woven cotton then this trick will reduce the weight as well as the bulk of the fabric.
5 - Needle and Thread:
While working with the knitted fabrics like fleece, you need a ballpoint needle which has rounded tip at the front and it has the ability to pierce the fabric for the quality stitching. If you will go for the normal needles then you can see how it can damage the fiber of the fabric, as well as the stitching quality, will be worse. Ballpoint needle is going to extend the life of a fabric.
When it comes to choosing the thread for the fabric then always check if the properties of the fabric and thread are the same or not? If the properties are same then it can work out in the best possible way. I prefer to use the polyester thread even for the upper and bobbin area.
6 - High Heat:
If you are an experienced sewer and if you can analyze the making of the fabric then you can see how fleece is made up of the polyester. There will be a small ratio of the other fabrics blended in this one. This is the reason why fleece is soft and cozy in nature but this quality also makes this fabric heat sensitive.
If you are using a too hot iron on the fleece fabric then you can see the burning and melting of the fiber of this material. You can work with the finger pressing as well but if you have already used the interfacing then I recommend using the heat cloth over it to save it from huge damage.
Conclusion
Fleece is one of the fabrics you are going to have fun when sewing something out of that. The thing which can also help you in sewing a perfect project is a sewing machine. If you are struggling to find the right machine to create a masterpiece out of it then read Which Is The Best Basic Sewing Machine For Beginners And Home Sewists To Buy and get ultimate guidance about sewing machines.
kgm
PostPosted: 09:11 - 21 May 2021    Post subject: Reply with quote
This is a motorcycle forum.
Otherwise, 2km is nothing. Walk or cycle. Such regular short distances are not good for any motor vehicles, car or bike.
KiwiBob
PostPosted: 09:12 - 21 May 2021    Post subject: Re: I plan to ride my bike to work instead of car Reply with quote
WilsonBishop wrote:
I have moved to a new land, where my commute is a big road, I see people cycling a lot, maybe the distance from home to work is 2 km. I find driving a car polluting the environment, and quite inconvenient. I am planning to go to work by bike. What do you think about this idea, please give me some suggestions.
2Km? .. You may as well walk!
wr6133
PostPosted: 09:31 - 21 May 2021    Post subject: Re: I plan to ride my bike to work instead of car Reply with quote
https://live.staticflickr.com/65535/51194040930_0a2e4e13af_o.jpg
PostPosted: 09:34 - 21 May 2021    Post subject: Reply with quote
Get an electric scooter, ride it like a cvnt and join the thousands of entitled bastards that litter our society. Thumbs Up
trevor saxe-coburg-gotha
PostPosted: 09:38 - 21 May 2021    Post subject: Reply with quote
954 blade
xX-Alex-Xx
PostPosted: 09:49 - 21 May 2021    Post subject: Reply with quote
trevor saxe-coburg-gotha wrote:
954 blade
Lowered Hayabusa with a stretched swingarm and a 300 tyre on the back, polished frame, loads of strobes, and a mini fridge under the rear hump.
DILLIGAF
A100man
PostPosted: 09:52 - 21 May 2021    Post subject: Reply with quote
Aaargh Evil or Very Mad I detest these dratted contraptions -into the sea with the lot of them and the smug w@nkers 'riding' them - they are properly a cvnts trick and no mistake - worse than iPads and fitness watches and Peleton bikes combined.
Fat Angry Scotsman
PostPosted: 10:49 - 21 May 2021    Post subject: Reply with quote
100% totally agree with you mate. I see a load of them around Glasgow now. Some of them are really fucking fast, I was doing 40mph and one was keeping up with me!
Also how come I need to do tests and get insurance to take my motorbike on the road but these cunts just buy something online for less than £3k and then just go for it. What happens when one of them yeets themself into me and because they have no insurance I am fucked?
Fucking hate these cunts.
pepperami
PostPosted: 11:10 - 21 May 2021    Post subject: Reply with quote
And a nutter turbo, and supercharger, and nitro injection Thumbs Up
We don’t want to be late for work do we? Wink
pepperami
PostPosted: 11:15 - 21 May 2021    Post subject: Reply with quote
Hurt them and continue to hurt them repeatedly until someone drags you off Laughing Laughing
xX-Alex-Xx
PostPosted: 11:28 - 21 May 2021    Post subject: Reply with quote
They're supposed to have insurance etc, but no cvnt bothers cos there's no enforcement of it. Fine + points if they go ever get caught though.
https://i.dailymail.co.uk/1s/2021/03/25/11/40925262-9401537-The_e_scooter_rider_can_be_seen_wearing_a_high_vis_vest_while_ri-m-39_1616671240354.jpg
Rolling Eyes
DILLIGAF
Fat Angry Scotsman
PostPosted: 11:50 - 21 May 2021    Post subject: Reply with quote
It's an absolute joke mate, the one's I see act like cyclists and jump red lights, switch between pavement and road at whim and wear absolutely no fucking gear at all.
Unfortunately it's going to take a load of pedestrians getting seriously injured and disabled for life and being unable to get compensation for injuries, etc because they were mown down by uninsured, non-registered scumbag on a scooter before anyone forces action on the issue.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:09 - 21 May 2021    Post subject: Reply with quote
Classed as motorvehicles so MID will pay for the damage.
Triumph Sprint ST 1050
pepperami
PostPosted: 12:32 - 21 May 2021    Post subject: Reply with quote
How long before moped/scooter crims switch to these types of scooter?
Zipping through the pedestrian areas and shopping centres to get away?
Fat Angry Scotsman
PostPosted: 12:51 - 21 May 2021    Post subject: Reply with quote
Does the Motor Insurance Bureau also pay for life-long permanent disabilities, etc that the uninsured scrote gives someone or is it literally just repairs? I never even heard of MIB until today.
PostPosted: 12:59 - 21 May 2021    Post subject: Reply with quote
From earlier this year:
https://www.bbc.co.uk/news/uk-england-tyne-56203516
MCN
PostPosted: 13:18 - 21 May 2021    Post subject: Reply with quote
I can't remember any details of the time I may have stuck my paw out and tweeked the handlebar of a cnut who was bombing doon Buchanan Street swerving through pedestrians on a bike.
The Ex-Mrs and I helped the prick up off the slabs too.
I could hardly contain my laphter.
xX-Alex-Xx
PostPosted: 14:29 - 21 May 2021    Post subject: Reply with quote
Always best to keep a stick handy to shove in their front wheel. Then take it out and beat em with it.
DILLIGAF
PostPosted: 14:40 - 21 May 2021    Post subject: Reply with quote
Yes, basically it's the same as if the claim was being paid for by an insurance company.
"The MIB (Motor Insurers' Bureau) is here to help people involved in road accidents where the normal routes to compensation might not exist or be difficult to trace. We will consider claims for vehicle and property damage as well as injury where compensation cannot be claimed from another source such as an insurance company.
MIB's obligation is to handle claims in accordance with The Uninsured Drivers' Agreements and The Untraced Drivers' Agreements produced in collaboration between MIB and the Government. MIB is restricted to paying compensation in circumstances where compulsory motor insurance should have been in place. In summary this means MIB can pay compensation for property damage, death or injury arising from the use of a motor vehicle on a road or a public place in accordance with the Road Traffic Act 1988."
https://www.mib.org.uk/making-a-claim/what-we-do/
Easy-X
PostPosted: 16:05 - 21 May 2021    Post subject: Reply with quote
What are these things a solution for? "We want a greener world!" Get a push bike, get an electric push bike if you're unfit. "We want to encourage ppl out of cars?" How about a motorbike or, dare I say it, even a petrol scooter?
"Yes, yes. But all those other things have a high barrier to entry."
For a reason Rolling Eyes
Fat Angry Scotsman
PostPosted: 17:35 - 21 May 2021    Post subject: Reply with quote
Total legend mate well in! I despise walking around Buchannan Street, Sauchiehall Street and Argyle Street because of these bastards and those fucking Deliveroo fannies on pedal bikes. Deliveroo biker almost hit my wee boy a couple months back now, he gave absolutely zero fucks and pedalled off as if he did nothing wrong.
Jmoan
PostPosted: 19:25 - 21 May 2021    Post subject: Reply with quote
If people are being arses on the pavement then that's what matters not whether they are on a scooter,pushbike, skateboard or a monkey riding a dog.*
because your getting mugged off by whoever thought up and profits from those regulations as other EU countries do it differently and it wasn't like that in the past either.
* https://www.youtube.com/watch?v=aRakRrVsQrs
The last post was made 5 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.87 - MySQL Queries: 13 - Page Size: 131.08 Kb
