| nook6 |
 nook6 L Plate Warrior
| Hong Kong Phooey |
| nook6 |
 Posted: 22:49 - 04 Jun 2021 Post subject: |
| Hong Kong Phooey wrote: | I'll presume the fault was there before you went near the clutch plates, but if you cleaned them with something incompatible that's not going to help. |
Yes the problem was there before i touched it, when i say cleaned the clutch plates i mean i wiped them over with some paper and made sure they werent stuck together with dry oil
| Hong Kong Phooey wrote: | I'll also presume it's not stuck in neutral, and the brakes are not binding, and this is a clutch issue. |
the brakes are fine (i have rolled the bike and tried the brakes all work as should) it isnt stuck in neutral because when i put it in gear and let clutch out it does move forward it seems like its slipping really badly.
| Hong Kong Phooey wrote: | Have you changed the oil recently or added anything like friction modifiers to the oil? |
i havent changed the oil but i have changed the clutch fluid and bled that, and i havent added anything to the oil.
| Hong Kong Phooey wrote: | If the plates are excessively worn then it won't bite, so is the width of the plates in spec? |
i havent measured the plates but they seem as though there is plenty of meat on them,
| Hong Kong Phooey wrote: | The other thing would be loss of clamping force, but for six springs to come loose is a bit improbable, but the push rod that the clutch slave actuates may be sticking so have you looked at that? |
when i looked at the clutch plates after putting it together again i pulled the clutch lever in and the springs all compressed and the plates went loose then i let the clutch out again and it all tightened up again.
Thank you for your reply and i hope this helps a little
Nook6 |
| Hong Kong Phooey |
 Posted: 23:20 - 04 Jun 2021 Post subject: |
It would have to be very bad for the oil to slip that much with car oil (modified for efficiency and reduced friction).
This is the parts stack for that bike, I was hoping it would show how many friction plates were in use.
https://www.cmsnl.com/honda-vtr1000f-firestorm-2003-3-englandasv_model6315/partslist/E__0700.html#.YLqkdCLTWDY
The important part is that the friction plates are on both the outer most ends and the middle alternates with friction, steel, friction etc.
If there were some plates missing, or the parts are not fitted like in the diagram then the final drive would would lose power. Might be an idea to double check. Also get hold of the service manual online if you can.
I take it that it's never worked since you've had it? Or you've not noticed slipping in the past that got worse?
Otherwise, measurement of the clutch pack is going to be necessary. Both how much thickness is on the plates and steels, and if in spec (from service manual) and what the gap is when closed to fully open from the pressure plate. ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| nook6 |
| Irezumi |
 Irezumi Nitrous Nuisance
| nook6 |
| to v or not to v |
 to v or not to v World Chat Champion
The last post was made 5 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
