Boiler Plus compliance for luddites..
A100man
PostPosted: 13:02 - 09 Jun 2021    Post subject: Boiler Plus compliance for luddites.. Reply with quote
Installing a new combi.. Gas man tells me (since 2018) all new ones need to have one of four energy saving 'add-ons'.
Most people opt for a Nest or other such WiFi wireless gubbins.
but they are costly and too techie for me.
Can I just install external temp sensor for so called 'weather compensation/loading' ? is it as easy as connecting the appropriate sensor into the swish new boiler?
Hong Kong Phooey
PostPosted: 16:06 - 09 Jun 2021    Post subject: Reply with quote
I fitted Hive to a dual channel gravity feed back boiler, that was a rats nest of wires and took a good hour to sort out.
Then a few weeks later I changed over to a combi boiler, two wires for power and one other for switching. It's simple, if you're not confident any heating engineer could do it in ten minutes. Mine is the dual channel model but I only use the heating side now, the water switching relay is just redundant but I could add a low power outside light or equivalent to that circuit if I wanted to.
The AA battery powered control on the wall is simple, turn the dial to change the temperature. You can also set the heating off/on cycle. I've yet to change the batteries, been in over a year.
The app is intuitive and lets you switch and program heating while you're away. You can turn the heating on an hour before you're due home if you forgot to program it or were outside of your usual routine.
I would highly recommend it over a traditional wall mounted thermostat.
PostPosted: 16:33 - 09 Jun 2021    Post subject: Reply with quote
So, you have to "have" one.
I "have" a noise reducing baffle for the micron exhaust on my VFR.
PostPosted: 16:43 - 09 Jun 2021    Post subject: Reply with quote
On the other side of the coin, I sacked off the wireless, programmable, super-duper room-stat because it was an unreliable, unpredicatable piece of shit which seemed to randomly decide when and if the heatin g would be turned on regardless of how it was programmed and replaced it with a simple 5+2 day timer and electromechanical wall 'stat.
I did however have thermostatic valves fitted on all the radiators so the wall 'stat is really just an end-game cut off switch, most of the rads are off by the time the 'stat trips.
The best thing I did for heating efficiency was let the Mrs pay for the last two fills of 1,000 litres of heating oil. Amazing how much less frequently I come home to find the heating on and windows/doors open now.
A100man
PostPosted: 21:33 - 09 Jun 2021    Post subject: Reply with quote
Yeah I'm not happy having tech foisted on me.. but yes you 'have' to have something.. to notionally improve efficiency, either: flue heat retrieval system or outside temp 'compensator' or fancy smart stat. I guess it's for the morons who open widows when it gets too hot in the house in winter. The outside temp thing looked cheap and easy as it apparently dictates the boiler burn rate dependent on in/out temperature differential... lower burn rate are more efficient on a condensor they tell me.
PostPosted: 23:49 - 09 Jun 2021    Post subject: Reply with quote
You could ask him which one is most easily removed within five mionutes of him walking out of the door?
They all sound like excellent ways of needlessly over-complicating something that is relatively simple and (should be) broadly reliable.
When I said have it. I was meaning in the same way I have a baffle for the exhaust on my bike. I know I have one, it's in a box in the workshop. If you can show you've bought one, is anyone checking it's been fitted?
In my experience, having a burner going less than flat-out is a good way to soot up the sensors.
Hong Kong Phooey
PostPosted: 09:47 - 10 Jun 2021    Post subject: Reply with quote
On the other hand, you could have gone smart thermostat and kept turning it to 7 degrees every time she adjusted it. Or if you don't value your marriage that much, just lock her out of the controls and not divulge the password. Laughing
MCN
PostPosted: 18:52 - 10 Jun 2021    Post subject: Reply with quote
What was more efficient than having to humph a bucket of carbon rocks up the tenement stairs twice a day and then poking the glowing pile now and again with an iron stick?
t121anf
PostPosted: 21:01 - 10 Jun 2021    Post subject: Reply with quote
What are the four options and where does it say you must have it fitted?
Robby
Dirty Old Man
PostPosted: 12:32 - 11 Jun 2021    Post subject: Reply with quote
If flue heat recovery is one of the options, that may already be worked into the new boiler/flue package. I know my new boiler has it. It means it burns less gas to heat my house, which is a good thing.
I also have a smart thermostat, which is great for laziness, I can control the heating from my phone when I'm in bed. The wife has mostly stopped touching the thermostat now, but in the early days I could use it to turn the heat down when I was out and she had turned it up to something silly. For ultimate geekiness I could even automate it so that it automatically goes back to default every time she ties to push it too high.
The tech is there to keep your home at a comfortable temperature for less money and less effort. It works.
MCN
PostPosted: 14:21 - 11 Jun 2021    Post subject: Reply with quote
All domestic CH boilers must be condensing type now. (Or of that type of efficiency.)
Madness to not fit that type as the economics speak for them self.
Only major deal is that a drain line for condensate must be fitted to drain to ground drains/gutter drains.
The other thing is I am not qualified to remove and install a new GCH Boiler at my gaff.
Though I am more than competent to do so.
Something about GasSafe training (Expensive training)
That makes it almost impossible to even buy a GCH boiler at retail and have sum kwalifyed kunt to install, test and certify.
Thats what puts me off replacing my 2006 GCH boiler.
It works perfectly fine but I know it could be 20% more efficient if I fitted a new boiler. But that would cost £1000+ to save what over the years?
I don't run all my rads in the house and trap as much heat as possible. And wear two pair of underkrackers. Cool
I estimate £500 per year on gas as Im not here all the time. (Vague Guestimate.)
PostPosted: 14:47 - 11 Jun 2021    Post subject: Reply with quote
You need to make sure the fuckers route it to an inside drain. It constantly drips water so it it gets cold, the end can freeze over with a plug of ice and your boiler will conk out.
Really common to have outdoor oil boilers here and the lazy fuckers just vent the condensation pipe onto the ground or into a downspout. Which is fine until it's frosty and you land up standing outside in the pitch black and snow blowing a hairdrier on your new boiler you just spent £6k to have installed.
MCN
PostPosted: 15:01 - 11 Jun 2021    Post subject: Reply with quote
In Kazakhstan winter temps get down to -40º Centipede as normal. Our shop air compressor would sometimes shut off and hours of troubleshooting would ensue.
We found the condensate line was plugged by ice.
The sparky and I wrapped a length of Heat Trace cable around the condenser housing and it's drain then wrapped that in some fire blanket and silver tape as insulation.
Sparky fitted a timer/breaker box so it would work when temps dropped to below mental in the winter.
It provided a fairly simple fix to a constant problem.
https://www.heat-trace.com/admin/files/31.pdf
This is standard notation in extreme climes.
A100man
PostPosted: 21:50 - 11 Jun 2021    Post subject: Reply with quote
Yep.. My last house boiler install 20 yrs ago was condensing... but now you ALSO need one of these extra things.. The fitters (sorry, engineers) want whats easiest and with the most margin so that's a 'smart-arse' controller.
They really have you by the short hairs with this gas safe business. Between 500-1000 quid to install 1k boiler in less than a day..
Raffles
PostPosted: 18:00 - 12 Jun 2021    Post subject: Reply with quote
MCN wrote:
....I am not qualified to remove and install a new GCH Boiler at my gaff.
Who says that you can't do your own remove and install?
MCN
PostPosted: 19:36 - 12 Jun 2021    Post subject: Reply with quote
Its illegal to even remove a screw from a boiler cover unless you are Gas Safe certified.
Too many Kuntz have caused gas sploshuns due to tamperfering with gas appliances.
It's a fairly serious issue and reports of cowboys is not infrequent.
https://www.gassaferegister.co.uk/
"Gas Safe Register is the official gas registration body for the United Kingdom, Isle of Man and Guernsey. It replaced CORGI registration and by law all gas engineers must be on the Gas Safe Register. Our role is to act as a licensing body."
I can't even remove and fit a boiler as it would require isolation at the supply and that work is regulated too.
(Unless for emergency where a leak is suspected. Gas can be closed at the meter by anyone.)
https://www.google.com/amp/s/www.bbc.co.uk/news/uk-england-lancashire-57232373.amp
Tragic.
Raffles
PostPosted: 20:50 - 12 Jun 2021    Post subject: Reply with quote
Over the years, I've ripped out and replaced boilers in many of my properties. Even though I've never been on The Gas Safe Register, I haven't broken any laws.
MCN
PostPosted: 01:01 - 13 Jun 2021    Post subject: Reply with quote
When someone dips you in or someone asks for a cert you might find yourself in court.
It's chased up.
https://resources.hse.gov.uk/convictions/breach/breach_list.asp?SN=S&ST=B&SF=IS&SV=3
FYI it IS breaking the law.
You should read up on it for your own benefit.
Freddyfruitba...
PostPosted: 13:15 - 13 Jun 2021    Post subject: Reply with quote
The relevant law (The Gas Safety [Installation and Use] Regulations 1998, as far as I'm aware) states: "No person shall carry out any work in relation to a gas fitting or gas storage vessel unless he is competent to do so."
No. What's specifically illegal is to represent yourself as a gas engineer and charge for doing gas work. It's not illegal per se for an unqualified person to do gas work in their own home. But the issue is defining exactly what "competent" is in the eyes of the law. Being on the Gas Safe Register would obviously normally fit that criterion. And if someone's not qualified to work on gas fittings and does something stupid which results in harm, then they will have demonstrated themselves not to be "competent", and will rightly have the book thrown at them.
MCN
PostPosted: 15:11 - 13 Jun 2021    Post subject: Reply with quote
Them's not my rules M8.
https://documentcloud.adobe.com/link/review?uri=urn:aaid:scds:US:7c0155c4-65a7-45b9-a2d9-71d5bbe5e729
The sort of attitude is equivalent to the attitude of the two cheap cunts who killed a little boy by electrocution at a shite hole pub in England
https://www.pbctoday.co.uk/news/health-safety-news/david-bearman-jailed/92035/
Sometimes we can't muddle through and hope things will be fine.
Sometimes things that are inherently and immediately dangerous have controls and legal barriers in place to keep fools at bay.
Freddyfruitba...
PostPosted: 17:17 - 13 Jun 2021    Post subject: Reply with quote
MCN wrote:
Nor mine - I linked to the relevant law on my last post (I don't know what the above link is, but it's broken).
I made no judgement about unqualified people doing their own gas work (and I certainly don't condone it); I was merely stating the correct legal position on the subject.
MCN
PostPosted: 21:09 - 13 Jun 2021    Post subject: Reply with quote
U do U.
In the meantime, I have taken the opportunity to report your posts to the relevant authorities.
The last post was made 5 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 129.22 Kb
